piper_chuck
Joined: 6/13/2004 From: Pittsboro, NC, USA Status: offline
quote:
ORIGINAL: tanzi411 what do i do for a prop size???? I need one that will fit on a 1/4inch shaft. Did you already buy the shaft? If not, buy one with a stub shaft that's stepped down to 3/16". That gives you a wider selection of props. I think most props for the .60 size range would be for a 3/16" shaft. As far as prop sizes, you may have to do some experimentation to find the right size. Octura X457, X457/3, or x460 are a few possibilities. You may even be able to go larger, but it would require experimentation.
_____________________________
AMA 87959, IMPBA 19650 CD, IBDBG #2, local 12 There's A Reason I'm Behind You. You're About To Be Lapped!!!
