JWN
Joined: 3/26/2002 From: Florence, TX, USA Status: offline
Hydroguy, No, you cannot use the crank vent to pressurize the tank. It is after all, a vent, not a pressure tap. The vent is needed to vent off excess oil from the crank. If you use it to pressurized the tank, you will accumulate too much oil in the crank and performance will suffer drastically. Also, the idea of needing more oil for larger engines is not true. If it were, then why to the big Supertigers like LESS oil? With a larger engine comes higher fuel consumption. With higher fuel consumption comes more oil. John
