Lets See Some Fun Fly Plane Pics
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Lets See Some Fun Fly Plane Pics
Page: <<   < prev  10 11 12 13 14 15 16 [17] 18 19   next >   >>
Login
Lets See Some Fun Fly Plane Pics - 11/9/2002 11:50:04 PM
da king
Status: offline
and one more
Click to see fullsize image.
Click for fullsize
_____________________________
hello...my name is Dennis and im an rc addict.
(in reply to rrpech)
       Post #: 401
Fazer - 11/10/2002 2:33:26 AM
Wh00ps
Status: offline
Here's the new Fazer:
Ailerons are slightly enlarged, H-stab/elevator is slightly enlarged and re-designed with balance tabs and opened up to 45 deg. of rudder throw, rudder is greatly enlarged.
I also built up my own fuse for it. Instead of the stock 1/2" solid balsa fuse, I built it up with 3/8 sq. and 1/4x3/8 balsa, and 1/4x3/8 spruce for servo rails and a couple longerons for strength. Moving the servos to the tail eliminated the Fazer's nose-heaviness with the 46-class engines. End result: EXACTLY the same weight as the solid balsa fuse. To the tenth of an ounce. *sigh* : Some weight savings did come, however, in being able to use 1/16 ply for the fuse doublers instead of the heavy 1/8 ply that came with the kit, since my fuselage was inherently stronger, and needed less reinforcement. Also put flying wires on the tail.
If I could hover, I'm sure it would do it quite nicely with the GMS .47 on the nose. Takeoff roll with a 12/4 prop is about 3 feet, and it goes straight up like a rocket at full bore. Was practicing some knife-edge today. It'll almost knife-edge loop, just doesn't have quite enough rudder throw to bring it out from the vertical downline. I can increase it a little more, hopefully that'll do the trick.
Click for fullsize
       Post #: 402
Lets See Some Fun Fly Plane Pics - 11/10/2002 2:34:41 AM
Wh00ps
Status: offline
Here's the bottom view:
Click for fullsize
       Post #: 403
Lets See Some Fun Fly Plane Pics - 11/10/2002 2:35:36 AM
Wh00ps
Status: offline
And a nice picture of the new bird sunning itself...
Click for fullsize
       Post #: 404
Lets See Some Fun Fly Plane Pics - 11/10/2002 4:22:40 AM
da king
Status: offline
thats the best looking fazer I have ever seen. The fuse is too short(hieght) thats why it doesnt knife loop like it should. so what was the final weight on it. Ive had a couple of fazers but they had .32 in them. good job.
       Post #: 405
Lets See Some Fun Fly Plane Pics - 11/10/2002 4:30:45 AM
Dansy
Status: offline
Another one of my profile, this one was my number two Thunger Tiger Extra. I flown this one for two season, it die last in 2001.
Daniel D.
I forgot, I won the funkiest aroebatics with this little plane, modified stab/elevator.
Click for fullsize
       Post #: 406
Lets See Some Fun Fly Plane Pics - 11/10/2002 5:56:13 AM
coony2787
Status: offline
here's my gs540 , havnt even flown it yet
Click for fullsize
build to fly, fly to build
       Post #: 407
Lets See Some Fun Fly Plane Pics - 11/10/2002 7:42:34 AM
Wh00ps
Status: offline
[QUOTE]Originally posted by da king
thats the best looking fazer I have ever seen. The fuse is too short(hieght) thats why it doesnt knife loop like it should. so what was the final weight on it. Ive had a couple of fazers but they had .32 in them. good job. [/QUOTE]
Thanks I don't have an AUW on it. Wish I did, I'm curious myself. When I checked the fuselages, I just took 'em over to the deli dept. in the grocery store and had them weigh them on a digital scale. They'd prolly freak if I brought the whole plane in...
I'd like to build another one at some point and put a 32 in it to see how it does with the much lighter engine. That's about 8 projects down the road though..
       Post #: 408
Done building .40 siize funfly planes! - 11/10/2002 7:56:28 AM
DKjens
Status: online
I think I've built my last .40 size funfly plane, well, untill I forget that I made this statement. I will probably build funfly planes for .40 size 2-strokes or .53/.63 size 4-strokes though, but it will be enlarged .40 size planes. I think I can build an enlarged Aerone (60" wingspan) which will weight the same as the stock Aeron. Since the whole hardware-electronics-engine package weighs the same, the wing loading will be significantly reduced, for a much more fun plane. My Aeron came oout a little heay for my taste, it flyes great, does some funky stuff in the air, some times extremely fast waterfalls, and with the not very light wing loading, it is very easy to land. Much of its ability in the air, I think, comes from my +/- 70-80 degree throws on basically all controll sufaces, plus its SHORT tail moment and thick wing. I do think however, that I could build a 20% larger Aeron, that would weigh the same in the bones. This means that I could have a 60" wingspan Aeron, with a YS53 on the nose, weighing about 4.5-5 lbs., now that would be funny.
After flying larger planes (Morris .60SuDoKhoi, S2G Extase and Great Planes UCD3D), I realise how much better the larger planes behave in the air (read Reynolds number here). Well, just my humble opinnion about this crazy hobby he he.
DKjens
       Post #: 409
DKJens- Been there - Done That! - 11/10/2002 7:11:55 PM
kevin4hsrcm
Status: offline
DKJens - I built a larger version of the Aeron. It is a 65" wing span with removable wings (aluminum wing tube & sleeves). I increased the width of the fuse to accommodate the elevator and Rudder servos in the tail section. I am posting a couple of pics for you. - Kevin
Click for fullsize
Kevin
http://www.hsrcm.com
       Post #: 410
Another Pic of the Big Aeron - 11/10/2002 7:13:24 PM
kevin4hsrcm
Status: offline
Here is a pic so you can see the relative size.
Kevin
Click for fullsize
Kevin
       Post #: 411
Fun Fly - 11/10/2002 7:24:42 PM
Henri
Status: offline
Fully self desinged and builded. Extreme good flyer Hoooovers with ease...
Click for fullsize
Jep
       Post #: 412
?????? - 11/10/2002 8:55:50 PM
philfun
Status: offline
Hi Henri,
Very nice bird
Can we get some details like span ,engine size etc ,is the wing taper ?
Phil
       Post #: 413
Edge - 11/11/2002 12:47:07 AM
Henri
Status: offline
Nice you like it Phil.
Specs:
Span: 121cm(48"
Engine: OS 46fx prop: Apc 12.25*3.75
Weight: eh , havent weighted it yet, though I have flyed it the hole summer, but near 1,6-1,7kg(~3,7pound) is not far from correct.
And the wing is rectangle and, only ailerons are taper.
UC was veneer plywood, now they are pianowire.
Radios are Futaba(fast mini hitec on trhottle)
Im planning to draw the drawings in to cad mode some day.
Jep
       Post #: 414
