Dave McDonald
Joined: 1/4/2002 From: Eldon, MO, USA Status: offline
jmulder, The fiberglass boom lays into a slot cut into the plywood engine pod, which all gets sandwiched between the wing halves. Simple and easy! If you have built any planes at all, then building a Stickit won't be a problem. In fact, it would make a perfect first time scratch build. If you don't want to scratch build a Stickit type plane, Air Flair makes and sells kits of the Stickit V, the Smith Super Special, and the Diamond Tea. Here is their URL: http://www.airflair.com/ If you've never had one of these Competition Fun Fly planes before, you have no idea what you've been missing out on!
_____________________________
McDDD ProBro 415
