Walkera 60 Cnc Head Setup
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> Walkera 60 Cnc Head Setup
Page: [1]
Login
Walkera 60 Cnc Head Setup - 8/11/2006 10:46:37 AM
paulp01
Status: offline
Does anyone know how to adjust the servo throws to accommodate the cnc head. I have fitted three TowerPro servos (9g) and with the new head, full travel is reached when the throttle is only half way. Also the front servo moves more than the rear one causing the head to tip forwards when throttle is applied. I would imagine the whole swash assembly should move in a uniform manner?
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Walkera 60 Cnc Head Setup - 8/11/2006 1:11:55 PM
paulp01
Status: offline
Ok, another two hours playing with this and I seem to have fixed the servo throw distances by adjusting the pit values. Also the front servo linkage was one hole out on the arm which was causing the pull on the front.
Spins up ok, the only thing now is to adjust the pitch of the blades. At stop they are about -5, 0 at half throttle and +11 around full. Is there a way to change them to 0 to +11 through the range to stop the thing slamming downwards when below half throttle and keep the full range of servo movement?
(in reply to paulp01)
       Post #: 2
RE: Walkera 60 Cnc Head Setup - 8/11/2006 1:13:07 PM
soneebee
Status: offline
What do you have? is that a DF60C? or just updated the DF60
       Post #: 3
RE: Walkera 60 Cnc Head Setup - 8/11/2006 1:16:23 PM
soneebee
Status: offline
I have my settings on -1°, 3°, 11° and it is not binding. on the head set teh travel on the TX to halfway only increasing it will increase the throw of pitch to above 15°. I think you have to check and set all the mechanicals equal and the electrics to all center
quote:
ORIGINAL: paulp01
       Post #: 4
RE: Walkera 60 Cnc Head Setup - 8/11/2006 1:25:42 PM
paulp01
Status: offline
Hi
This is a DF60 upgraded to brushless with cnc head, cnc tail, carbon blades and an align 315 tail boom.
I set the swashplate so that the flybar ball was at half way travel in the head. Then I set the servos level and adjusted the linkages and pit values so that throttle min to max pulls the ball to the bottom of the head assembly and with inverse flight selected throttle min to max pulls the ball to the top of the assembly to give it the full range of motion without the servos struggling. Problem is, there dosn't seem to be any play in the linkages as they are at the minimum setting on the head?
       Post #: 5
RE: Walkera 60 Cnc Head Setup - 8/11/2006 1:38:53 PM
soneebee
Status: offline
What are you getting at 3D mode? I set my swashplate also to center to make the travel equal to both 3d and normal mode. currently I have it at -1°,3-4°, 11° and at 3D it is -10°,-1°,11° havent really made any adjustment yet to center 3D mode but just a few turn will do the centering. I also got the TP servos as setup on my DF60 complete with all the CF and tail assembly for testing, but I dont have the same problems as you encountered it..
quote:
ORIGINAL: paulp01
Hi
       Post #: 6
RE: Walkera 60 Cnc Head Setup - 8/11/2006 2:03:01 PM
paulp01
Status: offline
Have now adjusted the rotor head ball linkages to the top most (inner link) and the inside link(flybar link) which seems to give around -1,-2 degrees at throttle off. At full throttle pitch is around +12 but this seems far better than before. Will replace the cf blades and balance them before giving it a test run as they have a nasty chip in one of them which makes balancing impossible. At least the pitch angles are in the same ballpark as yours now.
Thanks again
       Post #: 7
RE: Walkera 60 Cnc Head Setup - 8/11/2006 2:12:34 PM
soneebee
Status: offline
When I adjusted the pitch to make it correct and set all the links as equal as possible. I loosen up the screws on the blade grips and turned the grips until i got the correct pitch angle and also made the tracking equal. so my links are all equal in length and even my swash is 90° flat okay.. so it is running very stable. Had a good flight this morning and all seems to be right on the dot.. better tru adjusting the blade grip holder screws and set all the links as equal as possible.. also the ball snaps only one way so you have make sure youll make full 360° turns on the links
quote:
ORIGINAL: paulp01
Thanks again
       Post #: 8
RE: Walkera 60 Cnc Head Setup - 8/11/2006 4:18:44 PM
paulp01
Status: offline
Hi,
The blade grips have a flat at the bottom, so this stops me rotating them. I assume your head must be different?
This would have been a great way of adjusting the blade pitch and probably saved me having to reset all the links on the head again.
       Post #: 9
RE: Walkera 60 Cnc Head Setup - 8/11/2006 5:19:31 PM
soneebee
Status: offline
I am not sure of the flat on the bottom that your head has.. but the last time i mades changes on the pitch I just rotated the blade grips i just loosen the screws that holds it and the mixing arm and made chages to it.. well that is what i did this morning when I checked my pitch it was not correct but after using the pitch gauge and rotated on of the grips that was off.. now it is okay
this is the one that i loosen and adjusted.. mine does not have a flat bottom so i can rotate it 360°
Where did you get you alum head? did you get it from Walkera?
quote:
ORIGINAL: paulp01
Hi,
       Post #: 10
RE: Walkera 60 Cnc Head Setup - 8/11/2006 6:15:19 PM
paulp01
Status: offline
My head looks identical to that, only the blade holders have a flat edge which stop it rotating.
The head is supposed to be a genuine Walkera part, mind you I only received it a few weeks ago. Perhaps they have changed the design slightly?
As an aside, do you know where, and if you can get parts for them?
Click for fullsize
       Post #: 11
RE: Walkera 60 Cnc Head Setup - 8/12/2006 12:46:33 AM
soneebee
Status: offline
Yup the parts are available already if you want you can got to eHirobo.com for the replacement parts on this head. here ill post the link for you
http://www.ehirobo.com/shop/index.php?cPath=82_113&page=2
quote:
ORIGINAL: paulp01
       Post #: 12
RE: Walkera 60 Cnc Head Setup - 8/12/2006 7:48:28 PM
paulp01
Status: offline
Thanks for the link.
Have just ordered a spare rotor head, more blades and one of those dinky little elf motors & esc. I did read a post somewhere that stated, flying electric helicopters as a hobby is more of a mechanical pastime and I wouldn't disagree with that.
       Post #: 13
RE: Walkera 60 Cnc Head Setup - 8/13/2006 3:12:37 AM
soneebee
Status: offline
If you need the manual for the ESC i finshed making it give me a PM and your email Ill send you a copy so you can program the ESC. its quite simple to program it and it will run the outrunner motor better. I think youll love the power of the small outrunner motor. Waht blades did you get? I think the CF blades are good made some review of those in the pasts. the manufacturer kinda made good matching of those CF's and for its price its good.
       Post #: 14
RE: Walkera 60 Cnc Head Setup - 8/13/2006 11:48:37 AM
paulp01
Status: offline
I ordered the carbonhobby main, tail and flybar paddles. I already had a pair which are far superior to the foam ones, which are of a poor quality. Unfortunately, the end split whilst hovering a little too close to a tree! The spare foam set they included in the box actually exploded on spinup which did wonders for the old plastic head assembly. I did order a replacement set of foam originally, but was a little sceptical as they rattle if you shake them so there's no chance of putting these on.
The manual for the esc would be great though. Will pm shortly.
