tippy
AL, USA Status: offline
quote:
ORIGINAL: datchineseguy thanks guys... should it be pitched back or forward? And by pitch do you guys mean the right stick moving it up (forward) or down (reverse) In heli parlance, "pitch" refers to the angle of attack of the rotor blade ... not the orientation of the nose (ie nose up / down or elevator). "pitch" is measure at the cord of the blade. When the cord line is parallel to the ground (assuming the heli is sitting level), this is 0° pitch. If the leading edge of the blade is angled upward from level by say 5° this is called +5°. Go back a read this: quote:
tippy:: ... Two things make lift. RPM & AOA (pitch). You have to generate enough lift to lift the weight of the heli. If you have plenty of RPM ... look at pitch next. If the pitch is at 0°, you're not going to generate the lift needed to fly the heli ... regardless of rotor RPM. If the rotor blade is flat bottomed air foiled in shape, you may make lift but not enough to fly. What is your main rotor blade pitch at low, mid, and high collective stick. If this is a fixed pitched heli, then what is your pitch setting? Does the walkera 60 have fixed pitch or collective pitch? What is your pitch settings (angles of attack at each stick setting ... lo, mid, hi)? You will only have one setting if FP. Pitch is measured with a pitch gauge attached to the rotor blades to determine the angle of attack (pitch). Example: Image from www.raptortechnique.com Good Luck, d.tipton
