RE: Brison 3.2 numbers
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> RE: Brison 3.2 numbers
Page: <<   < prev  1 [2]
Login
RE: Brison 3.2 numbers - 2/6/2004 10:58:58 PM
JohnnyJ
Status: offline
Hello,
More 3.2 numbers
Same equipment and gas.
I removed the 5/8" exhaust pipes and soldered 1" pipes to the Bisson muffler.
200 RPM boost!
I use Amsoil Series 2000 2-cycle racing oil mixed as directed at 50-1.
This time at an OAT of 32 degrees F giving me a density altitude of 1500 ASL.
Beautiful February day!
Measured with a TNC tach.
Menz 22x10 "S" 6800 RPM
24 lbs thrust as measured with my spring scale known to be accurate in rough water weighing freshly caught fish!
This is in my Sig Sukhoi that weighs 16.25 lbs.
Nice performance!
John
< Message edited by JohnnyJ -- 2/6/2004 4:06:28 PM >
(in reply to Geistware)
       Post #: 26
RE: Brison 3.2 numbers - 2/7/2004 12:16:56 AM
krayzc-RCU
Status: online
JohnnyJ
any pics sounds like some we all can benifit from?
_____________________________
smooth as silk!
(in reply to JohnnyJ)
       Post #: 27
RE: Brison 3.2 numbers - 2/16/2004 3:07:48 AM
GalenB
Status: offline
My 3.2 is well broken in and has a J&A Engineering Peacekeeper muffler, and I run Amsoil 100:1 at 100:1...
Here are my readings:
Mejzlik 21X10 7500
Mejzlik 22X10 7260
Bambula 22X8 ? I just put in on today and have not had a chance to run it...
Cheers!
(in reply to krayzc-RCU)
       Post #: 28
RE: Brison 3.2 numbers - 3/1/2004 4:20:22 AM
GalenB
Status: offline
I finally started flying with the Bambula 22X8. RPM is 6780 as measured with my spiffy new 9ZAP! My trusty Cermark tach had a dead battery...
Cheers!
(in reply to GalenB)
       Post #: 29
RE: Brison 3.2 numbers - 3/1/2004 10:49:41 AM
Geistware
Status: offline
Is this a new engine or used that gets that speed?
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 30
RE: Brison 3.2 numbers - 3/1/2004 6:13:16 PM
GalenB
Status: offline
quote:
ORIGINAL: Geistware
It's well used. It's serial number is 0002 which means it was made in 2000... I've only owned it since last September, but it has done nothing but impress me since then...
Cheers!
       Post #: 31
RE: RE: Brison 3.2 numbers - 3/2/2004 2:23:13 AM
Geistware
Status: offline
Not only 2000 but the first one built that year!
It is an antique
       Post #: 32
RE: RE: Brison 3.2 numbers - 3/2/2004 7:21:15 AM
JohnnyJ
Status: offline
Hi,
Photo of 1" pipes on my 3.2.
I changed the angle to suit the Sukhoi.
A little more noise...doesn't matter where we fly.
200 rpm boost in power.
John
Click to see fullsize image.
Click for fullsize
       Post #: 33
RE: RE: Brison 3.2 numbers - 3/2/2004 9:03:43 PM
krayzc-RCU
Status: online
that sounds like a plan did you notice the increase in noise or power?
smooth as silk!
       Post #: 34
RE: Brison 3.2 numbers - 3/16/2005 1:58:49 PM
torqmeister
Status: offline
I talked to Gary at Brison before I bought my first 3.2.He said the 3.2 needed to run around 7500 rpm to obtain maximum performance. He tunes them at the factory; my first one's tag said 7550 rpm on MSC 20/10, and my second one said 7660 on a MSC 20/10. Can I assume that this is where we need to be running this engine? Can you share your personal experiences on this?
AMA 8051
       Post #: 35
RE: Brison 3.2 numbers - 3/16/2005 4:39:00 PM
JohnnyJ
Status: offline
I had a Menz 21x10 Std on the Sukhoi for a while before switching to a Menz 22x10 Std.
The 22x10 seemed to pull harder on take-off, climb, and verticals.
The 22x10 is a lot quieter too...less rpm!
I would like to see a torque curve for this engine.
I suspect that the max power(torque) is in the mid 6000's rpm.
Anyway the Menz 22x10 Std works well for me on this airplane and someday I'll try a muffled can or a tuned can.
So little time, so little money and so many things to do!
Good Luck
John
(in reply to torqmeister)
       Post #: 36
RE: Brison 3.2 numbers - 3/17/2005 11:32:52 PM
krayzc-RCU
Status: online
prop the brison for 6500-7500 on the ground and she is a beast
smooth as silk!
       Post #: 37
RE: Brison 3.2 numbers - 7/24/2005 5:48:37 PM
Diablo-RCU
Status: offline
New 10 year old Brison 3.2 with the 2-ring piston.
1.5 gallons of gas through it.
With J-tec Slimline Pitts muffler and Mobil MX2T at 32:1
Mejzlik 22x10 @ 7200-7300 rpm.
       Post #: 38
RE: Brison 3.2 numbers - 2/12/2007 2:01:13 AM
Buteos
Status: offline
Can someone give me the "book" settings for the needle valves on a newer 3.2. I can't seem to locate my owners book......wife put it away and I may never see it again
May your sails always be full
(in reply to Diablo-RCU)
       Post #: 39
RE: Brison 3.2 numbers - 3/8/2007 4:40:01 AM
krayzc-RCU
Status: online
Per the manual:
"The idle mixture or low needle setting are between 1 1/2 to 2 1/2 out on the 3.2. The high speed mixture is set between 5/8 and 1 on all single cylinder engines. Use a tachometer to adjust the high speed mixture for maximum RPM and then open the needle about 1/16 turn for initial flights.
I just ordered a header and carbon fiber pipe to check out what kind of boast the 3.2 will see. I only have one Brison 3.2 left now the last one that i put on the WH Extra flew so well my buddy wanted this one and i wanted to see it stay around. Anyway it was sold to my buddy who loved it and then later someone else had to have it from who, who in turn crashed the WH.
smooth as silk!
(in reply to Buteos)
       Post #: 40
