Joined: 9/26/2005 From: sherman, TX, USA Status: offline
Heres my 3.5 cents worth (due to high gas prices). . Tom. Can you perhaps make the Extra 260 gear work on the plane or similar? The original has a horeshoe type gear on it...But..Im not complaining. Its an awesome plane. But I think throwing that gear on her would make it look even more scale...Whadu u think?
GA, USA Status: offline
quote:
ORIGINAL: rctom
Pocket hinging is similar to what Comp-arf uses on elevators and rudder, except we do it on ailerons as well.
The fixed surface (e.g. the wing) has small pocket built into the trailing edge. Spaced along inside that pocket are phenolic tabs that act is the fixed part of the hinge. the moving surface (aileron) fits into the pocket with the phenolic tabs going inside the surface through a small slit.
Then a CF tube is inserted through the whole length.
TF
Ok I got it now,,I wasn't sure what it was,,,and now looking at that picture it make sence,,,,that's a great idea of hinging. and I guess you are right it makes the hole thing looks sooth.
What would the price be? will it come with some kind of hrdware pack?
one more,,,which one flies better a YAK 54 or a this Sukhoi?
This plane, although it's 35% scale, costs me almost as much as the 41% Extra because of the covering job and the hinging, etc. I think it's going to be $895. Still, compared to the other planes on the market that's a pretty good price.
We of course will have a hardware package for it.
And surely you cannot expect me to say that a Yak flies better, but who will believe me if I say the Sukhoi is the best flying plane out there?
I think they are very close to identical. The layouts are almost the same, same radial cowl, same huge control surfaces. The Sukhoi wing is slightly below the centerline and the tail is slightly above.
quote:
ORIGINAL: rctom
TF
I have been looking for a 35% for a while and at this price I think I found it!!! also for what you mention on earlier post at only 26 +lb it's pretty light also,,,right????
When it's the maiden flight due,,,,I'd love to see a video of it i nflight!!!!
Joined: 2/25/2002 From: Central, CA, USA Status: offline
Picture Note;
I take and post large file size pictures so they can be downloaded and used again without going to a website. If you want to use this stuff later, build a file somewhere on your computer and label it something you will remember. Right click the pictures and then click on "save as" or "save picture as" and move them to the file. Later you can go into them, open them up with Microsoft Picture Manager or something that will let you enlarge them to full screen and still have good resolution. ************* I just went and picked up the prototype at a UPS terminal center in Sacramento, CA. After losing the first one to Greyhound thieves, there was nooooo way I was taking a chance with the second one and let them deliver it. Let alone the thought of some delivery dude walking on top of it in the aisle space of his brown truck.
This baby is BIG!! It comes in the usual box inside a box, each part of the contents individually plastic wrapped, and then wrapped again in that thin packing foam. The main wings and the fuselage are shipped separately due to their size. The primary box, the fuselage, is currently about 73 inches long, 18-1/2 inches wide, and 16-1/2 inches deep. If you decide to get one of these later I suggest you step up a little and go for priority shipping via Greayhound so you have a useful tracking number and a hard delivery date, or use UPS airfreight (Ocean/Air services) and pick it up at a terminal if you can. That will reduce the chance of transit damage considerably. I had no damage on this one at all. It may cost a little more, but IMO it's well worth it and eliminates a lot of delays and hassles later.
I'm not going to go into the finish in any detail since the prototypes are done in Chinacote to reduce the developmental costs. It's absolutely beautiful and everthing matches very well, but I believe the production planes will be done in Ultracote/Orocover. Most of you already know that Orocover is the same as Ultracote so that should be a pretty easy way to get more if you ever need it.
I haven't done any type of weight stuff since I don't have a scale at the house, but this big girl is light. The constructon methods and techniques have changed tremendously since the initial introductions of the Giles and 28% Edges and Extras. It looks to be extremely well done, with lots and lots of room for about anything you may want to put in there. For those interested, the inside width of the cowl is a tad between 11-1/2 and 11-3/4 inches. It comes with C/F wing tubes for the main wing and horizontal stab, so that little bit we have all been spending for the C/F products has already been taken care of.
It came with hardware, but I want to do this one different from Tom's to illustrate some latitude in set up arrangements. My intentions have been to use the new BME115 twin, barring that, a Brison 6.4 (105cc) twin. I have an RCBlimpro titanium tailwheel and a sheet of his composite sandwhich for an engine baffle. Great products that can be ordered from all the good places. Of course SWB and Fromeco products will play a big part, along with JR 8611 servos all around except throttle. You will need some loooong servo extensions for the elevator servos. I'll post some lengths and quantities as I move along.
Here's a few pics of the plane as it's coming out of the box for the first time. I would expect that there will be a few changes between the prototypes and production planes, but so far it does not look like much will be needed. Oh, one other thing. Out of the box with the hinges in place I have 60 degrees of deflection at the elevators, both directions Note that some of the shipping plastic wrap is still on some of the parts in the pictures, so don't get excited about wrinkles. It came out of the box with none.
Pardon any typos. I'm kind of excited. Now enough of this writing stuff, I have some real work to do
< Message edited by Silversurfer -- 8/19/2006 7:05:18 AM >
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
sweet!!!! more pics would be nice
So it looks like you could remove the control surfaces if you wanted to after the plane it's built right???? instead of having to cut a robart tipe hinge????
The removal of the surfaces after assembly would be determined by how you secured the C/F hinge tubes, but absolutely yes. I'll do a few more pics but you guys have to understand I want to fly this thing, not make love to it I'll see what the aileron deflections are in a few.
Speaking of hinge tubes, unlike a Comp Arf the tubes are only accessable at one end of each flight surface. That's very good. That eliminates any concerns of them working their way out to the outside and dispenses with any means of securement. The elevator tubes are locked in when the stabs are installed on the fuselage. The rudder tube will either need to be secured with a dollop of silicone on the bottom, or as I intend to do, which is make and install a tailwheel steering tiller that will mount directly over the tube access hole. The tubes in the main wing panels can be easily secured by installing a removable lite ply cap over the access hole. Even if you did nothing at all, they would not come out.
Note: The tailwheel will block the removal of the rudder hinge tube. It will be a bit of a chore to remove the rudder to make it shorter for transport. Removal of the horizontal stabs will be dependant on how the owner arranges the servo extension lengths and connectors. The extension run for the elevators is quite long, so try to eliminate as many connectors as possible to maintian higher current levels.
OK, pictures speak louder than words. The tape measure is on the root of one of the ailerons, and there are pics of both the elevator and aileron deflections as it came out of the box. I've done nothing with it other than fondle and photograph it so far.
< Message edited by Silversurfer -- 8/18/2006 7:40:29 AM >
One more set of pics and I'm going to have to start on her.
Tom and I discussed my not using a hardware kit on this one. Both from my personal choices and for letting people know of different options that they may decide to go with. I guess one of the factory hardware packages slipped though with this one so I thought I'd include a couple of pictures of how it's been done. There is a whole bunch of other stuff that would be part of the optional hardware kits but that will not be part of my end of this prototype build/fly/review/discussion.
A side note here is kind of important. Going with any hardware kit that Tom provides with his kits will ALWAYS be less expensive than doing it my way. He does look out for his customers by providing high qualiity parts in the hardware kits that always work and are durable. Both methods are fully functional and completely safe.
I included a pic of the RC Blimpro 40% titanium tailwheel above the stock tailwheel for comparison purposes. Pretty close to the same length, but man is it light! The main gear are in two parts, similar to many of the larger planes on the market. They are pretty well polished and appear to be quite stout.
Looks like that BME 115 might just be a happening!! My wife is going to do some very, very bad things to my anatomy over that, so I'd better go hide out in the shop right now!
< Message edited by Silversurfer -- 8/18/2006 7:44:13 AM >
