Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
I doubt it. As a rule I first flight a plane with just myself and one other person. One will be busy flying and making comments while the other takes notes on trims, balance, incidences, and mixing. It rarely leaves much time for filming if you're serious about a maiden flight on a prototype aircraft. These are more of a shakedown series of flights rather than pleasure flights. You're going out with a plane that is one of a kind. It has no construction manual, guesswork for control travels, a C/G that's iffy at best, and you don't know if it will stay together. Just basic flying has to be done for several flights just to get a decent feel for the plane and make determinations about what is good or needs to change. All this stuff absolutely must be done as quickly as possible in order to notify the factory of any necessary changes before the production run is due to start. If you don't do all the work in the beginning, you end up with a lot of really mad customers later, a very delayed delivery schedule, or both. All the fun, wringing out stuff comes a little later in the process. Now that's the stuff worth filming.
_____________________________
If you can''t fix it with a hammer, you have an electrical problem.
