RE: New Wild Hare Sukhoi ready to fly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: New Wild Hare Sukhoi ready to fly
Page: <<   < prev  60 61 [62] 63 64 65 66 67 68 69   next >   >>
Login
RE: ... - 9/18/2007 1:43:09 PM
mbinkley
Status: offline
I have the baffels in the cow. I will post some pics with it on tonight
(in reply to Tired Old Man)
       Post #: 1526
RE: ... - 9/19/2007 1:07:09 AM
sweetpea01
Status: offline
I'm having to move my batts back because I put servos in the tail for the rudder.
_____________________________
www.propnuts.org
www.hobbiesxtreme.com
(in reply to mbinkley)
       Post #: 1527
RE: ... - 9/19/2007 1:37:29 AM
RustyTumbles
Status: offline
quote:
ORIGINAL: mbinkley
What materials did you use to make the baffles??
       Post #: 1528
RE: ... - 9/19/2007 2:43:22 AM
mbinkley
Status: offline
Rusty,
I used a peiece of R/C Blimp Productions carbin balsa plate and some fiber glass cloth with goop glue to hold. It is very light
Here are some pics. I will post some with the cow on the plane tomorrow. I also cut the lowvers open on the cow to help keep it cool
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to RustyTumbles)
       Post #: 1529
RE: ... - 9/19/2007 7:00:37 AM
bgold
Status: offline
Looks great, I like the job you did cutting the louvers open, what kind of tool did you use and how long did it take.
PS. I don't think the front end of you plane is going to give milk anytime soon. Push harder on the L.
       Post #: 1530
RE: ... - 9/19/2007 1:58:12 PM
Dangerous Dan
Status: offline
Looks great I will do something similiar
when inverted down=up and up=$$
(in reply to bgold)
       Post #: 1531
RE: ... - 9/19/2007 9:04:37 PM
sweetpea01
Status: offline
quote:
ORIGINAL: bgold
I've done this before on my Russian brand R/C 32% Su-26...it was long and tedious with a dremel and diamond cutting bit.
I have not baffled my WH Su-26 yet or cut the louvers....I hope to not have to do either. Once the shootout is over I'll fine tune my Su-26
www.propnuts.org
(in reply to bgold)
       Post #: 1532
RE: ... - 9/20/2007 1:22:30 AM
mbinkley
Status: offline
Hi ,
Here are final pics of the Sukhoi.
I put 6oz in the nose you can see in the last pictures .I will not get a spinner till i see how it flys.
Thanks to RTK, Pat Roy, Texomamser, and the rest who posted it was and is a big help!!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to sweetpea01)
       Post #: 1533
RE: ... - 9/20/2007 2:10:11 AM
RustyTumbles
Status: offline
That looks great. Did you modify the bottom cowl attaching bolts so you can get access to them?
       Post #: 1534
RE: ... - 9/20/2007 2:25:01 AM
mbinkley
Status: offline
Rusty,
There are 3 bolts on the inside of the cow and a hole in the bottom of to get the one the bottom.
I will take a picture.
       Post #: 1535
RE: ... - 9/24/2007 4:01:46 PM
Dangerous Dan
Status: offline
Mine isnearing completion:
BME 110
PT 28x10
2 5955 elevator
1 5955 pull pull rudder
4 5945 aiklerons
1 5475 throttle
1 645 choke
3 2600 fromeco
3 fromeco regulators
smart fly power expander
I read most of this thread and took in a lot. A few things I done a little different.
The tank is on a platform over the CG and Wing tube this makes the forward wing bolts a lot easier to get to. The throttle and choke servos are in the fuse sides in the upper triangle cut out just aft of the former in front of the wing tube. Rudder pull pull. Baffling is similiar to mbinkley but made with balsa. The standoff was just under 3" and Made frome dowells and wrapped in fiberglass. To get the CG on the tube the batteries are forward of where the tank would have been. I am not using a spinner.
       Post #: 1536
RE: ... - 9/25/2007 2:29:35 AM
mbinkley
Status: offline
The plane ended up at 26.8 pounds. I checked the weight after the 1st flight. WOW! I did not know what you all ment about throttle control!! This thing has sick power! and it is still rich. The BME is very solid , has a low idle and super smotthe.
I sould be able to fly it some more this week. I will keep you up on how it goes.
Mike
(in reply to Dangerous Dan)
       Post #: 1537
RE: ... - 9/25/2007 3:54:26 AM
RTK
Status: online
Have fun Mike, I know you will Everyone here including myself are glad we could all give you a few different and hopefully good ideas.
       Post #: 1538
RE: New Wild Hare Sukhoi ready to fly - 9/26/2007 1:15:32 PM
sovietthunder
Status: offline
fantastic looking plane you got there, did you document the whole build? if you wanna send me details and a few pics i will post them on my site and a link to where your kit is available, www.sovietthunder.com
Russian aerobatic homepage www.sovietthunder.com
