RE: New Wild Hare Sukhoi ready to fly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: New Wild Hare Sukhoi ready to fly Page: <<   < prev  61 62 [63] 64 65 66 67 68 69 70   next >   >>
Login
RE: ... - 9/27/2007 2:41:11 PM
Dangerous Dan
Status: offline
2 more
Click to see fullsize image.
Click for fullsize
_____________________________
when inverted down=up and up=$$
(in reply to Dangerous Dan)
       Post #: 1551
RE: ... - 9/27/2007 2:42:21 PM
Dangerous Dan
Status: offline
last one
Click for fullsize
       Post #: 1552
RE: ... - 9/27/2007 2:47:08 PM
texomalaser
Status: offline
Dan..I dont like the way that fuel line is ran through the fiberglass..Better put something around it so it wont cut into it...
       Post #: 1553
RE: ... - 9/27/2007 2:48:52 PM
Dangerous Dan
Status: offline
It don't touch there is silicone on the backside
(in reply to texomalaser)
       Post #: 1554
RE: ... - 9/27/2007 3:15:54 PM
Greg Cothern
Status: offline
Dan, I see in one of the PICs a inline fuel filter on the bird. If you dont mind may I share an experience I had.......I lost a cylinder on a twin due to a inline fuel filter, one of the nice fancy ones VERY similar to what you have. It was leaking air even thought it was threaded together nice and tight and the O-rings were in great shape. I have since changed to a different method of filtering my fuel, I put a fuel filter in my field fuel container so that is filters going into the bird. I personally after having to spend over $300 to have the cylinder rebuilt will NOT install a filter in my bird, atleast not between the tank and the engine.
LOOKS great!
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
       Post #: 1555
RE: ... - 9/27/2007 3:40:06 PM
Dangerous Dan
Status: offline
I had one almost burn up because the screen in the carb got clogged with debri, I was running a filter on the gas can. I will be sure to check the tightness of the inline filter when I tear it down each flight and inspect for Air. I also have a vent line filter. I live on and our field is on a gravel road. I get a lot of dust on my planes even though the trailor is sealed, so I have to filter well!
(in reply to Greg Cothern)
       Post #: 1556
RE: ... - 9/27/2007 3:52:36 PM
Greg Cothern
Status: offline
Dan, I completely agree that fuel system needs to be clean and filtered. It took awhile to find my air leak, I tore into the poor carb more than once looking for a leak. As well as replaced the fuel system, only when I had the hatch off running the engine trying to get the needles set right did I see the bubbles after the inline filter and not before it. I never thought about it being the source as I had it squared away, or so I thought!
Looks like a fun bird!!!
       Post #: 1557
RE: ... - 9/27/2007 3:58:39 PM
Dangerous Dan
Status: offline
I'll definatly check for bubbles
       Post #: 1558
RE: ... - 9/27/2007 4:12:54 PM
Sukhoi4Me
Status: offline
Dan, are you goig to make it to Tulsa for the IMAC at Turf Flyers?
       Post #: 1559
RE: ... - 9/27/2007 4:18:07 PM
Dangerous Dan
Status: offline
No next contest will be Regionals in Ft worth. Hate to miss Tulsa they put on a great event and have the greenist and best maintained grass I have ever seen. I won't Maiden until Sat morning and it will take me 15 or so flights to dial her in.
(in reply to Sukhoi4Me)
       Post #: 1560
RE: ... - 9/27/2007 4:51:33 PM
jack1933
Status: offline
Hi Dan do you know who makes the mufflers for 3w? Jack Strickland
       Post #: 1561
RE: ... - 9/27/2007 5:39:40 PM
mbinkley
Status: offline
Dan,
Your plane looks grate. I like the tail set up that is a good idea. Hope you dont mind me using it?
these planes fly so nice I sure you will love it. Fly hard and have fun!
Mike
       Post #: 1562
RE: ... - 9/27/2007 5:50:38 PM
Dangerous Dan
Status: offline
quote:
ORIGINAL: jack1933
3W
(in reply to jack1933)
       Post #: 1563
RE: ... - 9/27/2007 5:52:03 PM
Dangerous Dan
Status: offline
quote:
ORIGINAL: mbinkley
Dan,
Mike
Which part of the Tail? I trashed the 8-32 all thread and drilled out the Dubro washers and traingle nuts to accept 10-32.
(in reply to mbinkley)
       Post #: 1564
RE: ... - 9/27/2007 6:24:23 PM
mbinkley
Status: offline
Me too. But I liked the tail wheel hook up looks like fishing rigs?
