flaphoto
MI, USA Status: offline
The flutter occured in shallow dive, not high speed, not under propeller power. It appeared that it might have been occuring in both the aileron and the flap. The bird is a Stork E, 3 meter moldie (as seen on Esprit website). Motor is a Hacker B50, but the flutter was not occuring under throttle (that we noticed...could be wrong). The entire trailing edge was trimmed down several degrees, as one might to to provide addtional lift on launch(right or wrong, it was done to eliminate me, newbie, from scrambling to find the right switch if I need to add power to get out of trouble...I am eliminating that setup prior to next flight). The servos are brand new, Hitec HS5125MG digital wing servos (41.66oz.in torque at 4.8Vand .17sec to 60 degrees) quote:
ORIGINAL: Allie33 BTW, With all the discussion. there has been no mention of how the flutter was evidenced. Also, what was the model and how was it powered? Tell us about it. AW
< Message edited by flaphoto -- 8/15/2006 12:09:33 AM >
