RE: were to find a turbo or supercharger kit
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: were to find a turbo or supercharger kit Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: were to find a turbo or supercharger kit - 10/16/2006 6:19:49 AM
supertib
Status: online
quote:
ORIGINAL: downunder
quote:
ORIGINAL: supertib
okay my Sh 28 P6 has a crank induction timing of 194 degrees, and intake duration of 120 degrees and an exhaust duration of 163 degrees.,.
Surprisingly (to me anyway because I haven't had much to do with car engines) these figures are very close to those in my Super Tigre S45 (the '80's ringed engine). Crank timing is 40/50 or 190 degrees, intake is 120 and exhaust 160 degrees.
Supertib is correct. Even if the supercharger forced 16psi into the crankcase (which is one heck of a lot of boost!) while the crank port was open then the descending piston will increase that pressure yet again (it's how a 2 stroke works after all ) before allowing it to pass up through the transfer ports into the cylinder. The only rider here is that because this much pressure in the crankcase now allows a much faster flow rate through the ports then some alteration to port timings could be needed to prevent charge loss out the exhaust due to a much higher pressure differential (the exhaust being basically at ambient pressure).
The problem is people seem to think a 2 stroke has one straight pasage from carb to exhasut port, and dont realise 2 stroke induction happens in two separate phases....initial induction happens with the crank window open and low pressure in the crank case, and once the crank case is filled the crank window closes and the piston itself then pushes the mixture up into the sleeve ports, they dont realise that when the crank port is open the port windows are closed, and when the port windows are open the crank window is closed.. the motor actualy has 2 separate valve systems
_____________________________
seeing is believing !
(in reply to downunder)
       Post #: 51
RE: were to find a turbo or supercharger kit - 10/16/2006 1:28:07 PM
125cchyperman
Status: offline
I dont ever know why this has gotten to page 3. The fact of the matter is they may work very little but the power that is needed for the supercharger to be turned over takes away any and all extra power that the supercharger has given you. The air/fuel mixture is simply pushed out. Anybody who has owned one will tell you that they do not work. Look at the BBB site and look at all the complaints against the supercharger from rbinnovations. There is all the proof you will ever need, they do not work.
For all the people, that no matter what we have said and they still do not believe us . Go ahead and buy the supercharger and waist your hard earned moneyon something that does not work in giving you any additional power at all. If they workes so well I;m more then sure just about every basher and some racers would have them. The tuned pipe works and just a ton of people have them. Barely anybody has the supercharger and there's a reason why, go ahead and waist your money if thats what you want. Then when it doesnt work you can come back here, but dont complain as we have told you.
So for those that asay it works go ahead and buy it and lets see what you say after you buy it.
Go eat a grape there cowboy
(in reply to supertib)
       Post #: 52
RE: were to find a turbo or supercharger kit - 10/16/2006 3:09:52 PM
supertib
Status: online
quote:
ORIGINAL: 125cchyperman
hey there young guy, read the thread...we have already 100% discounted the RB unit as being viable, it is not a supercharger, its a dam little plastic fan.....We already know it doesn't work..... But we are discussing supercharging/turbocharging a 2 stroke.... And yes you can boost a 2 stroke, we have been building boosted snowmobiles since the 90's.... we are discussing engine theory as most you you dont even understand how these things work...... Anyways read before you speak, as we are not even discussing the RB unit LMAO at you !
(in reply to 125cchyperman)
       Post #: 53
RE: were to find a turbo or supercharger kit - 10/16/2006 8:02:39 PM
axisrc
Status: offline
yea
       Post #: 54
RE: were to find a turbo or supercharger kit - 10/16/2006 8:17:09 PM
125cchyperman
Status: offline
For one I did read a ton but did not read it all. And this was a overall statment about the Rb supercharger. I know how larger 2 strokes work as I am around very high dollar 2 stroke engine all the time. So dont tell me that I dont know how they work as I have seen more 2 stroke engine's that most people dont even really know exist. Such as the Honda rs engine's that cost 2 grand when there used and not exactly the newer year model.
Believe me I have been around high end 2 strokes along with some high end 4 strokes. So dont say that I dont know what I am doing, as I know more then what you probably think that I do. So you can Lmao all you want at me I dont care.
(in reply to axisrc)
       Post #: 55
RE: were to find a turbo or supercharger kit - 10/16/2006 9:00:29 PM
supertib
Status: online
       Post #: 56
RE: were to find a turbo or supercharger kit - 10/16/2006 11:50:10 PM
125cchyperman
Status: offline
Ok!!! I don't know what you mean by doing that. But I did some reading earlier and it seems as if you didn't discount the rb supercharger. In fact you got talking about port timing and port duration and you talking about you drag racing snow mobiles. I didn't see where you discounted the supercharger, but that you just got side tracked by the port timing issue.
As for axiscr. Whats ea about, about the only thing I have seen you say about anything is when you argued with me about a turbo being different then a supercharger and how the turbo forces air into the intake and how the supercharger sucks air.
I do know what I am talking about when it comes to these things and just because I'm young (I'm 20) doesn't discredit what I know and the info I have given.
       Post #: 57
RE: were to find a turbo or supercharger kit - 10/17/2006 1:24:36 AM
savagecommander
Status: offline
wait... let me go get some popcorn.... this is getting good....
its funny, he said "I am the dread pirate roberts" long live andre the giant
       Post #: 58
RE: were to find a turbo or supercharger kit - 10/17/2006 4:05:39 AM
SAVAGEJIM
Status: offline
I thought through how nitro engines work and I realiaze I will have to edit alot of what I said prior. After a more thorough thinking about the physical positions of nitro engine parts, I came to the conclusion that nitro engines will benefit very little from super charging.
I made a rudimentary degree wheel with a round cardboard piece and marked off special angles in 15degree increments. Supertib, I concede to you this: when all the ports are open simultaneously, I discovered big blocks with stock timing profiles will present very little openings.
Anyways, lets discuss why nitro engines cannot benefit much from super charging. You say that nitro engines have two phases when taking fuel-air into the engine. We will look at both phases, especially the second phase. We will assume the 16PSI charge you mentioned previously. We will assume that induction port in the crank is NEVER open when the sleeve ports are open.
Before any of these 2 phases, the air pressure in the card is increased by the super charger, say to 16PSI. See the first illustration below.
Phase 1: The crank induction port opens and allows the fuel-air charge to enter the block. The piston is still up and the sleeve ports are fully closed. The fuel-air charge retains its 16PSI pressure. See the second illustration below.
Phase 2: This is where the charge will lose its pressure! Again, the crank induction window is still fully closed. As the piston goes down, the exhaust opens first. Then, the Schneurle (lateral intake ports) and open and the boost finally opens too. ALL SLEEVE PORTS ARE OPEN! The fuel-air charge in the case still at 16PSI moves into the cylinder, of course the fluid flow of the charge is pushed away from the exhaust, but since the charge has more energy in the form of the 16PSI pressure, the charge expends alot of this energy (maybe about 3, 4, or maybe even 5PSI depending on the ambient pressure) by pushing some (maybe alot!) of the fuel-air charge out the open exhaust unburnt. This is where the aditional pressure is lost as the 16PSI pressure tries to balace itself with the ambient pressure since the charge is no longer in a fully enclosed system. Even with the crank port fully closed, you cannot stop this excess discharge. See the 3rd illustration below.
Worse yet, the energy the engine epended to turn the super charger is pretty much wasted.
Lets review. The super charger increases (boosts) the pressure in the carb neck; this is a fully enclosed sub-system. No pressure loss here. (The super charger itself stops the air from coming back out it and the closed crank window prevents the charge from entering the engine).
Phase 1: The crankshaft allows the charge to enter the case; again no pressure loss here because the charge is still fully enclosed (the crank closes behind it and the piston has all sleeve ports closed.
Phase 2: Pressure loss! Even with the crank induction port fully closed! As all sleeve ports (intake and exhaust ) are open simultaneiosly, no solid object stops the charge from flowing out. The charge will flow from the crank case into the cylinder, out the exhaust port, and out the stinger into the ambiant suroundings without any sort of solid obstruction.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SAVAGEJIM -- 10/17/2006 4:37:00 AM >
I hate stray Tomcats
       Post #: 59
RE: were to find a turbo or supercharger kit - 10/17/2006 5:00:38 AM
supertib
Status: online
quote:
ORIGINAL: SAVAGEJIM
I made a rudimentary degree wheel with a round card piece and marked off special angles in 15degree increments. Supertib, I concede to you this: when all the ports are open simultaneously, I discovered big blocks with stock timing profiles will present very little openings.
Before any of these 2 phases, the air pressure in the card is increased by the forced induction unit, say to 16PSI. See the first illustration below.
Phase 2: This is where the charge will lose its pressure! Again, the crank induction window is still fully closed. As the piston goes down, the the exhaust opens first. Then, the Schneurle (lateral intake ports) and open and the boost finally opens too. ALL SLEEVE PORTS ARE OPEN! The fuel-air charge in the case still at 16PSI moves into the cylinder, of course the fluid flow of the charge is pushed away from the exhaust, but since the charge has more energy in the form of the 16PSI pressure, the charge expends alot of this energy (maybe about 3, 4, or maybe even 5PSI depending on the ambient pressure) by pushing some (maybe alot!) of the fuel-air charge out the open exhaust unburnt. This is where the aditional pressure is lost as the 16PSI pressure tries to balace itself with the ambient pressure since the charge is no longer in a fully enclosed system. Even with the crank port fully closed, you cannot stop this excess discharge. See the 3rd illustration below.
Lets review. The super charger increases (boosts) the pressure in the carb neck; this is a fully enclosed sub-system. No pressure loss here. (The forced induction unit itself stops the air from coming bak out it and the close crank window prevents the charge from entering the engine).
Phase 1: The crankshaft allows the charge to enter the cas; again no pressure loss here because the charge is still full enclosed (the crank closes behind it and the piston has all sleve ports closed.
Phase 2: Pressure loss! Even with the crank induction port fully closed! As all sleeve ports (intake and exhaust ) are open simultaneiosly, no solid object stops the charge from flowing out. The charge will flow from the crank into the cylinder, out the exhaust port, and out the stinger into the ambiant suroundings without any sort of solid obstruction.
okay Jim your starting to understand..... but your still missing a few things.... first thing is that you have to quit looking at PSI as power, PSI means nothing..instead of looking at PSI look at air volume and even better yet mixture density... The supercharger will increase the density of the charge in the crank case, plain and simple, it will allow a much more tourough crankcase filling...resulting in more mixture being forced into the chamber....
Second thing is you have to realise the mixture from the crankcase is forced into the combustion chamber by pressure, the more pressure in the crank case the more mixture enters the combustion chamber..The piston traveling down after combustion is what creates the presure required to force the mixture from the crankcase up into the combustion chamber..... THis pressure is required for a 2 stroke to operate..it is perfectly normal to have blow thru on a 2 stroke, and in fact it is desired and leads to making more power....
The tuned pipe of a 2 stroke operates by returning that blow thru back into the chamber, which allows a 2 stroke to operate up and beyond 100% volumetric efficiency.... And the timing of the tuned pipe will not be afected by volume of mixture pushed into the header, but rather by the timing of the return pulse, more mixture in the header, the more extra mixture is forced back into the combustion chamber.....which means more power. A tuned pipes effect is based off timing, and as I say having a denser blowthru mixture will only increase the tuned pipes effectiveness..
Another thing to consider is these motors currently operate under 14.7 PSI, the only thing adding PSI is going to do is increase the volume and density of the mixture stored in the crank case and allow the motor to run much cvloser to 100% volumetric efficency, and possiblt beyond, as these 2 strokes do not operate anywhere near 100% volumetric efficiency, and the higher the RPm the harder and harder it is for the motor to fuly charge the crankcase..... As at 10 00 rpm the motor has 14.7 psi of force pushing the air into the engine, but at 40 000 rpm they still only have that 14.7 psi, So their efficiency begins to drastically drop off, as it cannot fully fill the crankcase between strokes at higher RPMS.... The supercharger is going to help the engine properly charge the crankcase between strokes, as it provides a larger volume of air available to the engine.... A nitro engines limiting factor for making power is its ability to pump air, actualy this is true for any internal combustion engine.... Porting a nitro engine increases its ability to draw air into the motor, as you cannot make more power without air..... SO supercharging allows you to increase the volume of air, nothing more and nothing less.... think of things in relation to air volume not PSI... PSI is just a by-product of higher air volume
ANother anlogy to look at is operate one of these engines at 20 000 feet above sea level, and you will see the engine makes very little power and alot less RPM, as it now has much less air pressure to work with, the motors ability is now limited to the volume of air available to the engine..
then take this same motor and operate is at sea level, and all of a sudden the motor makes tons of power, and much more RPM, as now it has much more air available to the engine, everything works better, the motor take smore charge between strokes and the tuning effect of the tuned pipe makes a more dramatic increase, as well as the motor scavenges alot more efficiently...consider the supercharger as the same as operating at seal level but one step further, all it does is gives the engine more air(oxygen) to burn fuel with, and the key to making HP is pumping more air thru the engine...
Anyways I am rushing so forgive any spelling mistakes...
(in reply to SAVAGEJIM)
       Post #: 60
RE: were to find a turbo or supercharger kit - 10/17/2006 6:20:09 AM
125cchyperman
Status: offline
quote:
ORIGINAL: supertib
I understand what you saying about the higher charger at the higher rpms and it make sense. But the the way I'm thinking is that the extra force with that charge at the higher and lower rpm's will push out. Ok now this is where the tuned pipe comes in right, but the way I'm thinking is the extra force from the charge will simple overide the returning the pressure wave. Now the returning pressure wave will slow up the exiting air/fuel mixture but it will not stop it and return the charge that has exited. Now the pressure wave as stated will slow up the fuel/air mixture and will allow some of the air/fuel mixture to stay in and combust.
This is where we get the "yes the supercharger does work, But it provides very little power" and all the power that it does give is taken away from all the power that is needed to turn over the supercharger and negates any power that the supercharger had given you. I understand what you are saying about the higher altitude and the lower altitude but what you have forgotton that the air/fuel mixture is not being pushed into the engine at higher pressure then the outside atmospheric pressure which allows the charge to exite through and enter the exhaust which is where the tuned pipe theory originates.
       Post #: 61
RE: were to find a turbo or supercharger kit - 10/17/2006 2:27:32 PM
supertib
Status: online
quote:
ORIGINAL: supertib
sorry but it works...as i say we have been building turbo snowmobiles since the 90's.... they make well over double the HP as their NA counterparts.....
125 guy you dont seem to understand what your saying, i realise your 20, but I have been working on 2 strokes for over 20 years.....
atmoshpheric pressure has nothing to do with exhaust on these, only intake..... i'm sorry but your not understanding, you can say you do, but you do not..
