supertib
quote:
ORIGINAL: SAVAGEJIM Pressure ia not density, but pressure IS required to increase density; it is not a byproduct, it is an integral component. Given an ambient pressure, if you want a given volume of gas to be denser, you will have to do two things: cool it or presurize it. You MUST have pressure to obtain a higher density given a set temp and ambient pressure. In the case of forced induction, PRESSURE is required to get more density. You can cool the air (like an intercooler for some tubocharger and supercharger set-ups) too, but cooling the air for a nitro engine is totally impractical. Straight physics: P1V1=P2V2. This is translated as pressure1 times volume1 is equal to pressure2 times volume2. Density is mass per volume. To get increase density, you need pressure to squeeze more air mass into a given volume. Take that pressure away, and density will reduce back to its equilibrium state (i.e. ambient pressure and ambient density). This formula will not work without pressure at all. Now, I'm not a fluids engineer. This debate has really made me think and now I am inspired to learn more about the fuild dynamics than what I already know. The pipe question again. As I said before, the increased pressure and volume of gas entering a fuel pipe when the supercharged fuel/air enters the pipe will do a number on the harmonic resonance in the pipe. The resonance will either be agvanced or retarded (phased) out of syncronization with the engine's timing. The supercharged fuel/air miture will definitely epend some of its energy into the pipe as the 16PSI (I'm assuming 16PSI boosted charge) back down closer to ambient pessure. The pipe will retain and provide back pressure as it is intended to do, but more gas will be pushed out the stinger, even with the harmonic resonance of the pressure wave in the pipe providing back pressure. To get the backpressure you are mentinong a pipe will have to make forced induction to work properly, you will have to choose a different pipe. The stock one will not work, nor similar pipes for the engine in question. These pipes are designed to generate their harmonic pressure resonance for naturally aspirated engines. I am guessing you will have to use a more flow restrictive pipe to help offset the increased pressure of a supercharged fuel/air miture. You built 4stroke race engines with forced induction; you therefore know that the cam profiels are different for that of a naturally aspirated race engine. Now, nitro engines do not have a valve train so its timing (assuming a non-modded engine) can be changed only by the pipe chosen, the pulg, even the header to a degree and the fuel chosen. With these factors in mind, you might be required to change all of these to make forced induction work on a nitro engine. Jim air volume not pressure.... if 14.7 atmospheric is not enough to to properly charge the crankcase, you will not see any PSi by forcing more air in.... PSI is only generated when the moitor cannot consume the volume of air being forced into it.... therefore untill you throw more air at it you will not know if it will create boost or not...if the engine is filling the crankcase 100% under NA the of course you'll see boost, but if the engine is only filing to 50% capacity you will not register boost till the crancase reaches 100% capacity....boost is read from the intake tract..... When we mod boosted engines we dont worry about PSI, it means nothing to us, we calculate air volume being pushed... if you have two motors each spinning the same blower at the same speed, and one engine is registering 14 psi and the other 7 PSI, it just shows one motor can pump air easier then the other..... I gues what I am trying to say is the crankcase doesn't need to be able to hold pressure, and you dont need to be able to produce PSI to make more HP...... Basically the SC is acting like a denser atmosphere pushing air into the engine... it is nothing more, as well the SC used for these applications are not positive displacement superchargers, they do not compress the air....
_____________________________
seeing is believing !
