RE: were to find a turbo or supercharger kit
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: were to find a turbo or supercharger kit
Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: were to find a turbo or supercharger kit - 2/3/2007 8:37:46 PM
steven16
Status: offline
savagejim i agree i went to there site and looked at whats in there superchargers then went out to my garage and made one my self out of a old pull start housing, plexy glass and a fan blade that looked identical to the rb one. And it did blow air but supercharging a two stroke wouldnt work so i threw it some where i dont remember where
(in reply to SAVAGEJIM)
       Post #: 126
RE: were to find a turbo or supercharger kit - 2/5/2007 12:49:37 AM
spencer_mcgrew
Status: offline
Oh em gee! i have the perfect idea- instead of using a supercharger, be it crankshaft driven or exaust gas driven, we should put power directly back into the crank- use a turbocompund! just like the Napier nomad or the R3350. we all know that when u scale down the actual engine u also scale down the flame front burn rate and all that stuff....a turbo compound is bound to work, after all if it works in full size it will work in a model too.....
waste ur money kiddies lol
scale down that ****..haha
(in reply to downunder)
       Post #: 127
RE: were to find a turbo or supercharger kit - 2/5/2007 1:39:23 AM
downunder
Status: offline
That's a PRT (Power Recovery Turbine) which has a turbine much the same as in a turbocharger except the turbine then drives the crankshaft through a gearbox and one way drive kind of like a pull start on an RC car engine. They work quite well on aircraft engines tha basically run almost full throttle all the time.
I've never quite figured out why they aren't used in car racing where an unsupercharged engine is required.
(in reply to spencer_mcgrew)
       Post #: 128
RE: were to find a turbo or supercharger kit - 2/5/2007 2:50:51 AM
heli-kid
Status: offline
yeah when you get a nitro car get familliar with the engine assembly and how it works before you go to big mods to it!!!!
its not hard once you get the hang of these engines there easy to work on. im only 13 and i rebiuld my engines with ease.
< Message edited by heli-kid -- 2/5/2007 2:51:21 AM >
_____________________________
if u can read this its 2 windy 2 fly
(in reply to supertib)
       Post #: 129
RE: were to find a turbo or supercharger kit - 2/5/2007 3:55:00 PM
spencer_mcgrew
Status: offline
kudos to "downunder" for knowing what Im talking about, a turbo compound is impractical on anything smaller than an automobile engine.
btw, The Formula One race car league has banned turbo compounds, the rules specify the car must have only "one" engine....hehe
PRT=parts recovery turbine
< Message edited by spencer_mcgrew -- 2/5/2007 3:56:42 PM >
(in reply to heli-kid)
       Post #: 130
RE: were to find a turbo or supercharger kit - 3/2/2007 6:22:28 AM
SAVAGEJIM
Status: offline
!!!!NOTE!!!! I am not bringing this thread back to resurrect the arguement; I am bumping it up because the question this thread addresses keeps on coming up.
As you can see, forced induction on model engines is a very heated subject and based on the dozens of posts contained in this thread, you can see that the subject is literally beat to death and argued over with great conviction from both sides.
I agree with Apollo, the subject is rally best left alone, so please do not bring back the arguments. I just want this thread to be available strictly for informational purposes.
Again, I am not bring up this argument again, I just want all who have questions concerning this (especially the folly that RB Innovations calls a "supercharger" to have this thread ready at hand so they can read the long and drawn out explanations of both sides without having to continually create a new thread every month that says "Turbo or Super Charger?"
This is a long read, but it is exhaustive for most RC purposes. For all who have questions concerning forced induction on model engines, plese take the time to read this thread as much as possible.
I hate stray Tomcats
       Post #: 131
RE: were to find a turbo or supercharger kit - 4/14/2007 3:09:16 AM
type-R-mad
Status: offline
im a supercharger rs3 owner, and i'm also a mechanic and any other mechanics on here will know that no engine can run with out the proper cycle, and one of them being compression, any engine produces compression, so how can the inlet air of the SC go in the inlet and be forced out before the stroke? it doesn't....but the pressures are not going to be great with an engine of such a scale, and the RB innovations supercharger like mine aint the best way to make one, i'm looking into modifing my engine to make a procharger, to those that don't know what that is its a crank driven method of boosting the engine, and with such high rpm the results could be good, i am also thinking about removing the heat sink and making the engine a sealed unit and have a fuel rail more like a normal car rather than the carb option, this can also make fuel management digital if i'm right, and i'm thinking on a new way to keep the engine cool, maybe water cooled, weight might be a problem though....as far as the supercharger goes RB's supercharger is not a bad product, although expect alot of messing around with fueling to get it going right.
........Supercharged Hpi Rs4 3 evo.......
www.falkirkcruise.net www.rc-drift.com
       Post #: 132
RE: were to find a turbo or supercharger kit - 4/15/2007 3:39:46 AM
hpi apollo
Status: offline
you cant just overcool the engine, you'll kill it, you will run it lean and burn it up, 2 strokes supercharge themselves, and we also throw a highly volatile thing in there called nitro
95% of statistics are made up on the spot
(in reply to type-R-mad)
       Post #: 133
RE: were to find a turbo or supercharger kit - 4/15/2007 4:14:36 AM
JetTech101
Status: offline
Bah, glow plug fuel is a ****cat comparied to other fuels. Try jet A fuel, that will put hair on your sack.
Type R Mad: Fuel injection sounds like a nice idea. Water cooled is efficent too but then there is always the chance of damage while running, and loosing all fluid, but the big boys use it, so why not.
Vintage Kyosho Ultima's,Vintage Team Associated RC10's, TC3 , Tamiya F-150, Jammin CRT , OFNA 9.5 ,
(in reply to hpi apollo)
       Post #: 134
RE: were to find a turbo or supercharger kit - 4/15/2007 3:27:21 PM
type-R-mad
Status: offline
yes it does seem a good idea but the cost of building it will not be so good lol, this won't be happening the now but i do have plans on making more of a real working engine to fit in a 1/10 scale car, with proper exhaust, so more down the lines of a 4 stoke, or a v4/flat 4.
(in reply to JetTech101)
       Post #: 135
RE: were to find a turbo or supercharger kit - 4/15/2007 3:52:21 PM
downunder
Status: offline
quote:
ORIGINAL: JetTech101
Jet A would work well in a model diesel because they use kero, ether and oil....and Jet A is just a good kerosene.
       Post #: 136
RE: were to find a turbo or supercharger kit - 4/15/2007 4:00:11 PM
Anthoop
Status: offline
quote:
ORIGINAL: type-R-mad
Erm,where do i start?Any crankcase pressure built up by the super charger is lost as the transfer ports and exhaust port are open at the same time!Quote"with such high rpm the results could be good"?How many cylinders will you have if your using a fuel rail?A fuel rail distributes fuel to the separate injectors!Digital fuel management,so your fitting a battery,ecu,crank posistion sensor,ego sensor,etc.?Please don't mislead people,if you know something i don't then i look forward to your project slapping me in the face.
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
       Post #: 137
RE: were to find a turbo or supercharger kit - 4/15/2007 4:02:56 PM
rclynx
Status: offline
Hey your avitar looks like one of those guys who bought a supercharger
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
       Post #: 138
RE: were to find a turbo or supercharger kit - 4/15/2007 5:38:17 PM
type-R-mad
Status: offline
i mean a fuel rail as a pressurised injection other than the carb option, and its not an ecu as such, its not hard to make up a loom to switch off and on in time, and you aint exactly gonna need a car battery to power a small circuit are you???, as you said if i go ahead it will be full of question marks but theres only one way to find out.....
(in reply to Anthoop)
       Post #: 139
RE: were to find a turbo or supercharger kit - 4/15/2007 6:06:40 PM
Anthoop
Status: offline
I really do not mean to be rude,but(there always is a but)i really do think that you are out of your depth.Start of with basic modifications first.
< Message edited by Anthoop -- 4/15/2007 6:10:10 PM >
