Wing pin suggestions: QQ Yak 54- 72 inch
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> Wing pin suggestions: QQ Yak 54- 72 inch
Page: [1]
Login
Wing pin suggestions: QQ Yak 54- 72 inch - 8/13/2006 2:50:00 PM
jigeye
Status: offline
I bought this used and I love it. Question: I'm having trouble with getting the correct size pins to pin the wings inside the fuselage. The ones I have now have are thick, however, they are cotter type pins that easily want to come out. I have plastic washers with a small rubber crommet that go on first. No problem with these. Are there any locking pins or other suggestions?
Mike
Memphis
       Post #: 1
RE: Wing pin suggestions: QQ Yak 54- 72 inch - 8/13/2006 4:24:21 PM
Rezagh
Status: offline
Hi Mike,
There is nothng wrong to use the cutter pins. If yours is damaged take it to Lowes or a local hardware store and pick new ones up. I'm not sure about the size, so I think your best bet is to take one with you.
Thank you,
Reza Gh.
_____________________________
Quique's Aircraft Company
(in reply to jigeye)
       Post #: 2
RE: Wing pin suggestions: QQ Yak 54- 72 inch - 8/14/2006 2:40:00 PM
arobatx
Status: offline
I opted to try something different on mine, and use dual threaded adapters (threaded studs) instead of the supplied antirotation pins and assembly. Basically these are 'screws/bolts' with threads at both ends. I picked up four of these, threaded for wood at one end and 1/4-20 machine thread on the other. I epoxied the wood threaded end into the anti-rotation pin sockets, leaving plenty of the machine thread remaining to extend through the fuse. on the inside of the fuse I use a 1/4 inch O-ring and 1/4-20 nylon winnuts. They don't budge! Attached is a picture to give you an idea, this one is machine threaded on both sides. you can find the ones with wood threads and machine threads at any hardware store! Good luck!
Click to see fullsize image.
Click for fullsize
< Message edited by arobatx -- 8/14/2006 2:44:21 PM >
Chad
(in reply to Rezagh)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU4
