Cutting out bodies
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Painting, Detailing & Bodies >> Cutting out bodies
Page: [1]
Login
Cutting out bodies - 1/5/2003 8:48:59 PM
Hondaracer03
Status: offline
Do you guys have any special techniques on cutting out rc touring car bodies? I can cut out the wheel wells, but can't get the straight lines to look right. They always come out jaggedy, and when I sand them, it becomes wavy. Do you recommend any special tools? Thanks, Josh
       Post #: 1
Cutting out bodies - 1/6/2003 5:19:58 AM
coro kid
Status: offline
Nitro
Most bodies I have done had a line on them,but you can mask the line and cut on tape or set the body flat on bench before cutting,set a sharpie pen flat on the bench and mark the body line.just trace all around body and trim with curved scissors.
Good luck
Coro
(in reply to Hondaracer03)
       Post #: 2
Cutting out bodies - 1/22/2003 5:01:15 AM
nopistonRX7
Status: offline
I use a circle cutter for my wheel wells. (home depot) it's made by exacto. You just poke a hole in the center a move it like you would a compass with a pencil. Looks good. good luck finding one they're hard to find. Cost about 10 or 14 bucks.
_____________________________
the world was meant to go round not up and down!
       Post #: 3
Cutting out bodies - 1/24/2003 2:42:15 AM
mbba2002
Status: offline
I use a dremel too finish with a sanding drum leave at (least1/4" . I rough cut lexan with the scisors (sometimes crack plastic and cause body to start cracking).
       Post #: 4
Cutting out bodies - 1/26/2003 2:37:31 PM
nopistonRX7
Status: offline
Yeah my friend uses a dremel tool for his bodies. They look flawless. I don't have a dremel so I opted to use a circle cutter. Someday I'll own a dremel though. You can use them for everything.
       Post #: 5
Cutting out bodies - 2/2/2003 2:28:41 AM
7185
Status: offline
All these tips are great but he wants to cut straight lines, The easiest way is to get hold of a tray table, after you cut out the wheel wells hang the body over the edge of the small table then between the two wheel wells line up a ruler and just score the body with an exacto knife. then just bend over the junk piece and tear off whala a perfect line between the wheels
       Post #: 6
cutting straight - 2/10/2003 2:03:18 AM
r2drift2
Status: offline
hey there guys, i had that problem before, but if you got the time and patience, just go real slow and use a pair of fine sharp scissors and go at it under a good lighted room, and sanding is a good way to finish it off.
       Post #: 7
Cutting out bodies - 2/12/2003 3:13:21 AM
Benny5
Status: offline
the dude at my hobby shop cuts em out for a fee of 5 bucks...he uses extremely sharp rounded off scissors. they cost 10 dollars and are highly effective, i'll be picking some up next trip.
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU4
