Canopy Tinting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Canopy Tinting
Page: <<   < prev  1 [2] 3   next >   >>
Login
Canopy Tinting - 2/7/2003 8:50:06 AM
Calmo2
Status: offline
eagle4442; Thanks for the reply. The next time I am up town I am going to go to a fabric shop and see if they can get Rit liquid. I did not know it came in a liquid form so I never bothered to ask, but I will now. Thanks again, Cal.
(in reply to flyindude)
       Post #: 26
Canopy Tinting - 2/7/2003 10:02:13 AM
CHassan
Status: offline
I used the crystal stuff works fine
_____________________________
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy--
       Post #: 27
Canopy Tinting - 2/7/2003 10:12:02 AM
Calmo2
Status: offline
Thanks, CHassan. If i can't get the liquid I'll try the crystals.
Thanks guys, Cal.
       Post #: 28
Canopy Tinting - 2/7/2003 8:54:11 PM
davey_flyer
Status: offline
Is there any way to tape off/cover areas that you do not want tinted when you place it in the dye?
       Post #: 29
Canopy Tinting - 2/7/2003 9:13:41 PM
CHassan
Status: offline
I would assume wax, or a masking liquid. I figure it would be like Dyeing eggs, wax should keep the dye from reaching the surface. Only thing is I don't know how crisp the edges would be.
       Post #: 30
Rit Dye Crystals - 2/8/2003 11:15:58 AM
David_Moen
Status: offline
This is my GP Ultra Sport + Canopy after about 5 minutes in a sink full of hot tap water, one box of black, and one box of navy blue...
Click to see fullsize image.
Click for fullsize
David Moen
www.mvvs-canada.com
       Post #: 31
Canopy Tinting - 2/8/2003 12:23:13 PM
Steve Guinn
Status: offline
I type this with dark hands and a happy heart.
Just dyed two canopies with the Rit box (crystal) dye.
Used 1 box ea. black and blue. Had the water at 140 and added a cup of salt. VERY PLEASED with the results.
This was my second attempt. First time the water was not hot enough.
"The weather is here, wish you were beautiful."
J. Buffett
       Post #: 32
Canopy Tinting - 2/8/2003 11:35:20 PM
Steve Guinn
Status: offline
Was so pleased with myself I forgot to thank you guy's for posting the methods.
[SIZE=3]Thank You[/SIZE]
I heated water on the stove and poured it in a 5 gal. plastic bucket.
If the water is not hot enough, you will get absolutely no tint and may believe ( like I did ) this method doesn't work.
[SIZE=3]It works ![/SIZE]
J. Buffett
       Post #: 33
he-he - 2/9/2003 1:43:18 AM
tinker-RCU
Status: offline
easter egg dye works well also...............
tinker
where's the glue?
       Post #: 34
TINTING SIG EXTRA 300SX CANOPY - 2/9/2003 2:21:14 AM
nedyob
Status: offline
I see from some of the previous post here and in past post the Sig Extra 300XS canopy wont tint with Ryt dye. Has anybody tinted there Sig canopy with die or spray tint? What method did you use and what where your results.
NEDYOB
       Post #: 35
Tinting SIG Canopys - 2/9/2003 10:48:47 PM
Bob Yeager
Status: offline
I was unable to get a SIG Someth'in Extra canopy to tint, using the dye method. I was also unsuccessful in tinting a Venture 60 canopy. I see some Venture 60s on the V60 WEB site with tinted canopys. I suspect the builders sprayed the inside of the canopy with window tinting spray,
Wyoming Windsock
"A fool and his money can throw one hell of a party."
       Post #: 36
PIC. - 2/10/2003 12:43:49 AM
Steve Guinn
Status: offline
You sure you had the water hot enough?
The smaller Starduster canopy was done with Navy blue.
The Midwest Extra canopy was Navy blue and black.
Click for fullsize
J. Buffett
       Post #: 37
Canopy Tinting - 2/10/2003 12:57:58 AM
A.T.
Status: offline
refer to my earlier post
"Covering Materials & Instructions" at
http://homepages.ihug.co.nz/~atong/ .
Easiest is to use the Polycarbonate spray paints e.g. Tamiya "Smoke" used by the card racing boys - clean inside of canopy and spray thin layers until darkness required is met
Advantage is the paint is made for the job and stays flexible and does not chip or break away. Painting on inside also stops any scratches in the paint. Check your LHS.
I neglected to mention that PET and food grade plastics are supposed to be resist to all dyes. Canopies are molded from many varied "clear" plastic.
regards
Alan T.
       Post #: 38
Canopy Tinting - 2/10/2003 3:37:28 AM
eagle4442
Status: offline
Bob,
The canopy I dyed for my Fiberclassic Extra 330L using the method in my earlier post was made of pet material. Another owner had already tried to dye his canopy without success. The factory said that to dye this material you have to get the water temp. to 140 deg.F and use 10 times the dye as with clothes. As you can see it is possible to dye this material. I had tried earlier to tint the canopy using spray tint but it looked bad. This is a very large canopy a smaller one may be easier to spray.
Click for fullsize
       Post #: 39
Canopy Tinting - 2/11/2003 3:57:07 AM
Bob Yeager
Status: offline
O.K., you guys have talked me into running this drill again! I am newly armed with another $6.00 worth of Rit Dye.
In the morning I am going to break out "the little brides" turkey roaster, heat the water to 140 degrees Fahrenheit, dump in one package of Navy Blue, one package of Black, one cup of salt; submerge the V60 canopy and see what happens. (I think that I had the water at approximately 130 degrees Fahrenheit last time.)
I painted the canopy of a 4*40 with that transparent paint one time and was not happy with the result. Last winter I dyed the canopy of my Uproar 40 using two packages of dye and hot water out of the tap. I thought that it came out great.
Nice job Steve and Eagle
Wish me luck!
Wyoming Windsock
       Post #: 40
Canopy Tinting - 2/11/2003 5:07:14 AM
Steve Guinn
Status: offline
I'm on pins and needles here. Let us know the results.
Good Luck,
Steve
"The weather is here, wish you were beautiful.&q
