HS needle not sensitive enough?
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler for Saito's
Seller:  RC Specialties
Details:   $49.95   |  10/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> HS needle not sensitive enough?
Page: [1]
Login
HS needle not sensitive enough? - 8/14/2006 6:18:48 PM
jzinckgra
Status: offline
I have an older OS 25SF, that has a very insensitive high speed needle. The end of the needle is very sharp and I was wondering if it would be wise to grind it down a little, so it is a little more blunt. When I go to adjust the HS, seems like it takes a half turn to get it running right, and just when I think it is good, it ends up being too lean. It's not like all my other motors where a slight click or two one way or the other is very noticeable.
_____________________________
http://www.rcflyr.com
       Post #: 1
RE: HS needle not sensitive enough? - 8/14/2006 9:26:19 PM
w8ye
Status: online
Before you go cutting your high speed needle, open up your low speed needle about a quarter turn an see how your high speed needle does?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to jzinckgra)
       Post #: 2
RE: HS needle not sensitive enough? - 8/14/2006 9:29:48 PM
BillS
Status: offline
Making the needle blunt probably will not help. More muffler pressure and a higher tank will usually make the HS needle more sensitive.
Maybe there is some trash somewhere.
Bill
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU4
