cblandin
quote:
ORIGINAL: The_Mongrel OOOhhh! She looks as ugly as my battered bird! I just swapped out the fuse yesterday. I am sorry to ask stupid questions of you, but do you understand the meaning of 1C? I am just curious as to why your batteries take so long to charge. 1C on a 2200mah battery is 2.2Amp. Now considering that the battery will still be reading above 9Volts, it should not take that long to stick the last 4 Volts back in the battery and 2.2Amp. If you look at the maths... 2.2Amp = 2200mah Charging at this rate will take 1 hour to put all 2200mah back in the battery - but that is from dead flat. We don't run dead flat so it should be a bit under this. Now if you do what I do and charge my 2200mah batteries at 3A, they charge even quicker. Cheers mate. -J Mongrel, Actually, I'm not 100% on the whole mah vs. volts thing, but I don't think zero volts equals zero milliamps. The way I understand it the lowest safe voltage for a 3 cell lipo is about 8.4 volts. At that voltage I think the pack (regardless of milliamp capacity) is essentially depleted (or pretty dang close). For my 1300mah pack I charge at 1.3 amps (i.e. 1C), and for my 2000 mah pack I charge at 2.0 amps (i.e. 1C). If I run a pack all the way down to the ESC's lipo cutoff it seems like it is almost fully depleted from a mah perspective. You are right though, my 1300 mah pack seems to "fill" at about 1100 mah implying it still had a 200 mah reserve or so...still, that's generally about an hour because it starts to trickle as it gets right on top of the 12.6v mark. Now, I could push them above 1C as you are doign and substantially reduce the charge time. Now, on to my next dilemma. I put the new tail feathers on and had a great flight this afternoon, but after several minutes she nose-dived in and now the motor won't run (tried two seperate batteries). The servos all move, but I get nothing from the motor. Now, this is the original stock brushed motor and I have run more than one full throttle lipo pack thru it (anf this was my longest flight yet with the new 2000 mah lipo...but part throttle most of the time). It's either the ESC (a GWS unit) or the motor...any thoughts? Thanks!
