Fourtypluskid
NY, USA Status: offline
Zeta, my first plane was the PZ J-3 Cub, which the kid at the LHS recommended as a good trainer, and the first time I threw it in the air (my first time with an R/C plane) I smacked it into the ground about fourty feet away. A new prop and shaft, a little packing tape and foam re-inforcements later I was up in the air, and a little wiser. Over the years I've replaced a number of props, shafts, and gear boxes but overall it's a pretty tough plane. In this past year I finally gave it a new fuslage, cowl, decals, etc. to make it look nice again and have been more cautious when and where I fly it since. For my second plane I was originally going to go for a warbird like the Spifire but if your going to drop almost $200 on one of those for not much more the T-28 comes brushless and with Li-Po amd steerable gear. But I figured that jumping from just rudder to ailerons and rudder without aileron experience might be too much. The Swift is a fairly inexpensive aileron plane that is a designed to be a stepping stone to something like the T-28 or the warbirds. I agree with the Swift's flight characterics, you do need to give it throttle when turning, probably due to the weight, but if you give it some height it glides well, depending on the wind. I think that for me to become proficient at barrell rolls, Immelmans, and inverted flight the throttle will need to be at 100% most of the time. Which is why I was concerned about the Swift's control possibly being lost if the battery gets too low. I'll just be cautious with it and keep the flight time down, not a problem since I have 4 batteries. For now I need to put my hobby money into my Xtreme to set it up as an aerial video/photography platform so I can check out the neighborhood from above. Happy flying and happier landings!
