ACH
Joined: 7/27/2004 From: Sheffield, UNITED KINGDOM Status: offline
Lets get back to the original question. Canalise or Canalize means to channel. If you have any doubts about its gimmickry, fit one to your model and find out, but it has to be made and fitted to the designers exact specification. Although this was designed for the Oxalys it works on the Synergy, whether it would work on any other model I do not know. The Synergy had no deficiencies in its design or control that were not part of a long and progressive family of very good aircraft, designed a World Champion who has been at the top for a very long time. No one can tell a pilot which aircraft design is best suited to them. It is a relationship between model and pilot and can only be a feeling that builds up after a long relationship and a natural follow-on from knowing every part of the model through the build. If after the build you can then have had a couple of years to hone that relationship, and then, by adding something new to the model it improves some part of its flight characteristics for you, that is fine, If it works for you and improves some aspect of the flight without detracting from any other part, that is the result of a really great designer. That the World class designer wants to share that detail with everyone, just confirms his confidence in his models and demonstrates just how nice the guy is. Many fliers will not have the ability to tell the difference the canaliser makes, others will not make the effort to find out for themselves, and most who use the canaliser will never know how the model performed without it. Don't they say beauty is in the eye of the beholder. I would like to take that one step further, beauty is not just what you see, but part what you feel as well. Ashley C Hoyland
