RE: How safe are homebuilt planes?
Tower Hobbies
Logged in as Guest
  Printable Version
Eurokit - RTF
Seller:  Roger Shipley
Details:   $68.00   |  11/11/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Airplanes - Full Scale >> RE: How safe are homebuilt planes?
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: How safe are homebuilt planes? - 8/28/2006 8:48:25 PM
flycfii
Status: offline
quote:
ORIGINAL: Sport_Pilot
Yes it is easy duty. Its the stop and start driving, and more often starts that isn't. Flying at 2500 RPM is the same duty as driving on the freeway. Look at your auto tach if you have one, it will do about the same, they the car can rev much higer and drive on the Autobaun screaming at 5000 or more and still be more reliable than an aircraft engine.
You make a good attempt at a point, however the bottom line is this: 2500RPM in an autmotive engine is what, 40% power, while 2500RPM for a Lycoming is 75-100% power, depending on altitude. Its the percentages, not the RPMs. Sorry.
_____________________________
#26 Club Saito
RIP, W.R.
(in reply to Sport_Pilot)
       Post #: 76
RE: How safe are homebuilt planes? - 8/28/2006 9:22:30 PM
ShoestringRacer
Status: online
You are right you did not say anything about convective weather. But you did say “bad weather” so that is just one logical type of “bad weather” one would associate with flying. So is icing, windshear, clear air turbulence, and a few others I can’t think of right now; at least with respect to operating airplanes in. And getting out of “bad weather” is the reason you cite for all airplanes needing a minimum of 1500 FPM climb. So now you are adding by saying 1500 FPM is needed to get above an overcast. So that must mean overcast weather is also “bad”. And if you think it is mandatory that all airplanes have this 1500 climb in order to get above the overcast it must mean you think that flying in the overcast (IMC) should be prohibited as well; otherwise there would be no reason to be required to climb above it when one could otherwise fly through it.
Well there can be IMC conditions (cloud) at any altitude, say 4000 feet, FL 260, or FL 450, etc. or whatever. So having 1500 fpm climb possibility doesn’t do any good when IMC conditions can exist right up into the high flight levels. IFR airplanes are not operated with the idea to get out of cloud that is otherwise not convective or ice laden. Not to mention normally aspirated singles and twins can’t get much higher than the mid teens or so where much weather is located. So we should retire all those airplanes to the scrap heap if they can’t fly at FL 450 to get above clouds? You are right, IFR flying wrecks do happen and mostly to GA pilots. But crashes happen every day on the highway. So should all cars be limited to 35 mph which would put the same operational restriction on them as to preventing aircraft that can't climb 1500 FPM from flying IFR in cloud?? I don’t mean to be hard on you, but you are just saying flippant, unsophisticated, and very impractical comments without much practical flying, or at least IFR, experience and knowledge. I am only pointing out these things to really address what I think are the issues at hand overall.
“If they lasted over 1000 as they do in a car, then they would be more reliable.” With that statement you are commingling two different things: reliability and service life. If something is reliable it means it has a low failure rate/occurrence. So to say mags would be more reliable if they lasted 1000hrs makes no sense. Consumables, like spark plugs, (and mags but they can be rebuilt) have an estimated service life (which can and does vary a lot actually), and a failure rate which are two totally different things. So a mag or spark plug would be no more reliable regardless of how long it is capable of lasting. If it fails often before the expected/planned service life is a reliability issue, not a service life length issue. High service life and high reliability is obviously ideal.
Modern day aircraft engines (which means they are not really modern at all) were designed to be simple and reliable. They are air-cooled for simplicity and low weight. For one an electric fan would not help all that much because cowl flaps are usually spec’d, and just adding an electric fan would not allow any significant change in tolerances. That could only come with precise, thermostat controlled liquid cooling. Even if one was used to supplement ground cooling, which is pretty much impractical and unnecessary given all the deficiencies of air-cooling as it is, it would add complexity. The very slight benefit of one would be a waste of time and money. Once the airplane moves to fly you have the best natural ram air fan going for cooling. An electric fan, especially in the operating environment of an aircraft piston engine, would have a high failure rate, add unnecessary and impractical complexity; at least if it was the quality that existed 50 years ago when our present day aircraft engines were born. Anything that adds weight, complexity, and extra systems was avoided as much as practical. Engineers didn’t pace up and down saying that if only they could add a fan they could really tighten up an air-cooled engine. A fan isn’t the solution to tolerances with an air-cooled engine. ( I will note that liquid cooling is superior for many reasons like shock cooling and tighter tolerances, etc. but an often over looked benefit is one of cooling drag: air-cooling creates drag; most of which can be eliminated with a sealed cowling when using liquid cooling)
The same complexity (and cost too) reason goes for liquid cooling. Up until maybe 20 or 25 years ago the cooling system on a car was one of the most failure prone systems it had. Water pumps quit, hoses burst, radiators leaked, thermostats stuck, etc. Only in the last 2 decades, and more like 10 years, did auto engines become much more reliable to the point that the cooling system as a whole is just as reliable as the engine as a whole. Look back to the 50’s, 60’s, and 70’s how often cars broke down. (and I wasn’t even around 50’s and 60’s) Can you imagine how many airplane engines would have quit in flight if they had water cooling and electronic ignition back then?? Today it is much more practical because of design/engineering and manufacturing advancements. Those complex items can be made to be much more reliable today. And being that those advancements come slowly in aviation powerplant options is another, yet valid, argument.
I am not defending current old technology aircraft engines. I would love to fly behind a liquid cooled, full FADEC aircraft engine for sure. I practically fantasize about it. Just variable ignition would be leaps and bounds ahead of fixed ignition we have now. (and the lead fuels we use are primarily designed to prevent detonation and preignition with the fixed timing and especially turbocharged engines) Better yet, a diesel, which is superior in so many ways, and are just becoming certified now for light singles and twins. There is certainly better technology available than what exists in current old tech aircraft piston engines, but the tried and true is also proven, and was the most reliable thing in its day.
New technology is becoming available with the aforementioned diesels from Thielert (which is liquid cooled), and true FADEC from Continental in some applications and Lycoming’s EPiC FADEC. Each has comparable or better specific fuel consumptions with as good or better reliability. And parts like plugs can last even longer because of the precise computer controlled mixture in each cylinder, and the oil becomes less contaminated from precise mixture control and variable ignition thwarts detonation and preignition. So those and various other things in the certification/approval stage are on the way. Better late than never…
“Flying at 2500 RPM is the same duty as driving on the freeway.” No it is not. 2500 RPM represents 92% of the redline speed of an airplane engine that redlines at 2700 RPM. (and also about 60-100% of the engine power depending on such things like temp and altitude: anytime you operate an engine above a temp of 59F and 29.92 baro and above sea level it won’t be able to make the 100% power that it was rated for on the ground) So no, your car engine isn’t putting out 75% or whatever of its total power when strolling down the highway. That is probably pulling somewhere around 30% total power. Those low power of autos also mean much lower cylinder pressures, so when run at higher power setting, nearly all things, but especially cylinders, take a beating. And except for a few minutes during descent and landing an airplane engine is usually at or above 65% power whereas your auto engine is loafing; meaning the aircraft engine cylinders are taking a constant and unrelenting beating.
It is really pointless to compare RPM range between car and airplane engines because they are so fundamentally different: the crank speed is so low (but not low stress) compared to auto engines which have higher crank speeds with much smaller displacements to get approximately comparable power. (like the previously linked articles state that aircraft engine speed was deliberately made slow to prevent near sonic prop tip speeds without the use of more complicated (failure prone) gearing boxes) I can almost guarantee you that unless an auto engine is specifically designed for such, the typical luxury sedan engine wont last 2000 hours when run at a constant 5000 RPM. And look at high performance race engines; they are only capable of lasting a few hours of racing if they are lucky; not one would last 2000 hrs flat out.
If you are so confident about your car, then just keep it downshifted whenever you drive (you can do this with an automatic or manual) so that the RPM stays up about 90% plus of its redline value. That should give roughly 75% or more of its rated power which is comparable duty. Drive it all the time everywhere you go at that engine speed/power and report back to us after 2000hrs. One or more of your engine parts may protest before 2000hrs.
< Message edited by wantsaneagle -- 8/28/2006 9:28:09 PM >
       Post #: 77
RE: How safe are homebuilt planes? - 8/29/2006 1:32:40 PM
Sport_Pilot
Status: offline
They are loafing at 100% power. With few mods they can rev almost as much as an automobile engine. Air boat operators regularly put smaller props on aircraft engines and rev them to well over 3000 RPM, at least for short periods.
“I Saw Elvis at 1000 Feet” John Force
(in reply to ShoestringRacer)
       Post #: 78
RE: How safe are homebuilt planes? - 8/29/2006 1:35:04 PM
Sport_Pilot
Status: offline
The aircraft engine ony goes to 2700 RPM because the prop is limited to that speed. With no modifications the engine can rev much higer. With stronger rods it can rev even higer still.
       Post #: 79
RE: How safe are homebuilt planes? - 8/29/2006 7:48:30 PM
APIA
Status: offline
Airboats run NON Certificated engines. Was test flying a Beech Travelair a few years back, On take off at about 300 feet the #2 engine started to violently shake ( propeller threw a counter weight) and the engine RPM increased to 3200 RPM. Kept the throttles forward to 1200 AGL and shut #2 down. Got back to the airport on one and found the spinner with a 4" hole in it. The owner did not want to tear the engine down for an overspeed inspection and kept flying it. The engine ultimately came apart due to a cracked case 52 hours later. Moral of this story: Airplane engines are not designed to turn high RPMs, they do not need to as they are very efficient for the intended design. I have seen a few damaged due to exceeding the red line. If you want to turn higher rpms stick to cars.
       Post #: 80
RE: How safe are homebuilt planes? - 8/29/2006 8:00:38 PM
Sport_Pilot
Status: offline
Most overspeed inspections turn up nothing, and I suspect many that do have nothing to do with the overspeed. In your case it was more likely from the unbalanced prop load. Many of those airboats use the same engine as aircraft. But because of the expense and higher maintenance as well as lower reliability they have mostly switched to automobile engines. C O-200's turn 4,500 RPM with stock bottem end in Formula One racers, no problem with the bottom end, I think they use lighter pushrods and stiffer valve springs.
(in reply to APIA)
       Post #: 81
RE: How safe are homebuilt planes? - 8/29/2006 9:51:30 PM
APIA
Status: offline
You have obviously have never performed an overspeed inspection... The NDT (Non Destructive Inspection) usually turns up either case damage or connecting rods or fastener yielding, without this process the engine is a ticking time bomb. As far as the Formula One racers and their 0-200s, The engines are torn down and inspected every 50 hours, Yes I said torn down and inspected. I had the pleasure of talking to an owner/pilot of one of these machines at the Air Races at Tunica. He even told me that sometimes " these things" dont even last that long between inspections. By the way Sport Pilot I would like to come visit your shop sometime, sounds like you have more than my mere 27yrs hands on experience with airplanes and such...
< Message edited by APIA -- 8/29/2006 9:52:24 PM >
       Post #: 82
RE: How safe are homebuilt planes? - 8/30/2006 4:58:13 AM
Sport_Pilot
Status: offline
No, just trying to point out that the comparison of running constant at 70% is not as severe a duty as running start and stop with occasional duty to higher speeds. I am aware that those engines are inspected often. I thought it was after every race or series of heats. So if they last 50 hours that is amazing. The O-300 was made in a geared version that ran I think 3200 RPM but I am not sure if there were any mods to the bottom end. I do know the TBO was shortened to 1200 RPM. Had a problem with overheating when run at 2400 RPM and less. Some gear problems as well, but I think the major problem was overheating.
The short of it is that aircraft engines are built to loose tolerances, do not last as long, and have antiquated ignition and fuel injection systems. Reliability would be much improved if they used electronic ignition, electronic fuel injection, computer control, and improved cooling systems. The latter would allow tighter tolerance and longevity. But the industry seems to just let oportunity slip by. I guess when they get sued for this they will again cry foul and try to get Congress to protect them.
(in reply to APIA)
       Post #: 83
RE: How safe are homebuilt planes? - 8/30/2006 8:19:24 AM
Jimmbbo
Status: offline
This horse has been beaten well past dead... Everyone appears to get that you think automobile engines are God's answer to everything aeronautic, that certified engines are collective POSs, and that evil GA manufacturers are responsible for all aviation's anguish and that pilots never screw up...
May I reitierate my request for substantiating data? Your statements fail to pass the common sense test, as evidenced by numerous posts agreeing to disagree with your assertions. While your opinions are noted, your stating them does not make them true...
Cheers!
Jim
Have you flogged your crew today?
       Post #: 84
RE: How safe are homebuilt planes? - 8/30/2006 1:42:48 PM
Sport_Pilot
Status: offline
First, most automobile engines would not make a good aircraft engine. They are too heavy and a large low speed engine is preferable. Some autoengines with a good reduction drive would work well. And not all are reliable. My gripe is with the lack of effort to improve the systems with modern electronic systems which have proved to be more reliable. As well as better cooling systems. Continental had the right idea with the water cooled engines, however much could be done to improve air cooled engines by using cooling fans. They don't have to be used when the aircraft is at speed.
What data do you want? I posted statistics that showed how dangerous GA aircraft are. I suggest you subscribe to Aviation Consumer which had more information, also there are some discussions on the rec.aviation.piloting newsgroup. I would say more than half seem to be aware that GA is more dangerous than automobiles.
(in reply to Jimmbbo)
       Post #: 85
RE: How safe are homebuilt planes? - 8/30/2006 1:49:06 PM
Sport_Pilot
Status: offline
Actually it does. Mags fail often. Points open and close over 7 million times every 100 hours. The mag drive shaft must also rotate 7 million times. The modern car ignition has no moving part other than the magnets imbedded in the flywheel or harmonic balancer. Yes they have done away with the distributer.
       Post #: 86
RE: How safe are homebuilt planes? - 8/30/2006 2:34:35 PM
Flyfalcons
Status: offline
You should write to Lycoming and tell them to shut down production in favor of using Chevy small blocks, because I don't think anyone here is getting convinced that an auto engine is the anser that GA is looking for, or needs. Why is it that when you read an article in Sport Aviation about how someone installed an auto engine, that most of the article involves troubleshooting the engine installation, while if they install an aircraft engine, it is almost always a case of set and forget?
Ryan Winslow
Cub flying - the new EXTREME SPORT!!! (evarrr)
       Post #: 87
RE: How safe are homebuilt planes? - 8/30/2006 3:08:51 PM
Sport_Pilot
