RE: Sirio 23 Air Leaks UNITE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> RE: Sirio 23 Air Leaks UNITE
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Sirio 23 Air Leaks UNITE - 8/22/2006 5:31:13 PM
1brent1
Status: offline
the dimensions for the front bearing is 7x17x5 mm its the same size bearing that is in the traxxas 2.5r and possible many other engines.
Don't order from bocabearing. I recently ordered their best package (ceramic) for the sirio .23 to find out that their seals are crap. I installed their front bearing and it leaks terribly.
I found out that my stock revo 2.5r has the same size front bearing (same numbers on the side too) so I swapped it since I'm not using the 2.5 and now I'm back in business!
Save yourself the trouble and don't order from bocabearings, I probably wouldn't order from acr either, probably uses the same seals. You can use the front stock bearing from your traxxas 2.5r and I'm sure its the same as the 3.3 too. I would imagine your local hobby store stocks the traxxas bearing so you might not even have to order and wait.
Good Luck!
ScRacing.. I take it the 12x19x6 and 12x18x6 you earlier ordered didn't work?
quote:
ORIGINAL: ScRacing
ask them what the demensions are ? so we can get it from acr or boca
< Message edited by 1brent1 -- 8/22/2006 5:33:09 PM >
(in reply to ScRacing)
       Post #: 26
RE: Sirio 23 Air Leaks UNITE - 8/22/2006 10:07:38 PM
bennyblanco
Status: offline
quote:
ORIGINAL: 1brent1
Good Luck!
quote:
ORIGINAL: ScRacing
i just called boca and they said the bearing size is 7x18x5! im confused now!! but im going to my lhs to get that bearing from the trx .15! thanks for the info!!
_____________________________
Revo rb523::: Jato tm18::: Team Magic g4 tz.18 :::
Spektrum 3.0:::Sportwerks Mayhem buggy stock:::
(in reply to 1brent1)
       Post #: 27
RE: Sirio 23 Air Leaks UNITE - 8/22/2006 10:10:17 PM
ScRacing
Status: offline
The trx barings are not the same size, i got my baring in yesterday, and 7x18x6 is the perfect size, so im sending my barings back to acer and having them send me one back.
All men die, but few men actually live
Are you alive? im looking for gasser
(in reply to bennyblanco)
       Post #: 28
RE: Sirio 23 Air Leaks UNITE - 8/22/2006 10:50:12 PM
savagelover
Status: offline
i had a sirio and hated it wouldnt tune right always leaked and the rab was a piece of ****
cna somebody help me find this guys savage? its in the dust of my revo!
       Post #: 29
RE: Sirio 23 Air Leaks UNITE - 8/22/2006 10:55:26 PM
bennyblanco
Status: offline
ahhhhhhhhhhhhhhhh!!!
(in reply to savagelover)
       Post #: 30
RE: Sirio 23 Air Leaks UNITE - 8/23/2006 7:35:31 AM
1brent1
Status: offline
7x18x6... thats strange? they must make different sirio monster .23's because my front bearing is a 7x17x5, same size bearing as my traxxas 25r
quote:
ORIGINAL: ScRacing
       Post #: 31
RE: Sirio 23 Air Leaks UNITE - 8/23/2006 9:58:17 PM
ScRacing
Status: offline
well my trx baring didn't fit? The diamiter was to small? And the corect mesurement is 7x18x5, bit i would rater have th baring a bit wide 7x18x6
       Post #: 32
RE: Sirio 23 Air Leaks UNITE - 8/23/2006 10:17:40 PM
bennyblanco
Status: offline
my bearing from boca is on is way and yesterday i went to my lhs and they didnt have the 2.5r bearing so still waiting!!
       Post #: 33
RE: Sirio 23 Air Leaks UNITE - 8/23/2006 11:14:53 PM
408Revo
Status: offline
hi
i also need to get the front bearing for my sirio
but before i do that i need to pull my old one out first
the problem is the rubber that seals the bearing came of
so when i pulled the crankshaft out the center piece of the bearing just fell out
now im left with a hollow bearing and i cant think of a way to pull it out
any help would appreciated
thanks
       Post #: 34
RE: Sirio 23 Air Leaks UNITE - 8/23/2006 11:51:25 PM
ScRacing
Status: offline
ummm ..... thats a hard one.... you could try using a really small hex rench and pull/push it out
(in reply to 408Revo)
       Post #: 35
RE: Sirio 23 Air Leaks UNITE - 8/24/2006 12:36:29 AM
bennyblanco
Status: offline
try a flathead from the other side like the part where the pullstart goes but be gentle!!!
       Post #: 36
RE: Sirio 23 Air Leaks UNITE - 8/24/2006 1:24:48 AM
408Revo
Status: offline
hi
did you guys heat up the block before removing the bearing or just at normal temps
thanks
       Post #: 37
RE: Sirio 23 Air Leaks UNITE - 8/24/2006 2:59:22 AM
bennyblanco
Status: offline
i didnt heat the engine just popped the bearing off with the bottom of a screwdriver. im talking about the old bearing whenever my new one get here i will heat the engine to put it back on.
       Post #: 38
RE: Sirio 23 Air Leaks UNITE - 8/24/2006 6:28:50 AM
1brent1
Status: offline
let us know what size your new bearing is and if it fit or not? wondering if they make different models? cause ScRacing outer diameter is 18 where mine is 17mm.
I would definitely suggest not ordering from boca cause the bearing they sent me leaked just as bad as my old one and they are way over priced. I would order directly from sirio's distributer kyosha. I left the detail for ordering in a earlier post. The bearing is only $9.
quote:
ORIGINAL: savage.27
       Post #: 39
RE: Sirio 23 Air Leaks UNITE - 8/24/2006 2:18:01 PM
bennyblanco
Status: offline
yeah i order one from boca and the other from kyosho ill let you know what happens when it get here.
quote:
ORIGINAL: 1brent1
quote:
ORIGINAL: savage.27
       Post #: 40
RE: Sirio 23 Air Leaks UNITE - 8/24/2006 9:14:14 PM
ScRacing
