RE: Sirio 23 Air Leaks UNITE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> RE: Sirio 23 Air Leaks UNITE Page: <<   < prev  1 2 [3]
Login
RE: Sirio 23 Air Leaks UNITE - 9/13/2006 5:49:47 AM
bennyblanco
Status: offline
http://www.bocabearings.com/ call them and order by phone and ask them if they fix the problem with this bearing remember they send me the wrong one the first time and tell them about my case!!!
_____________________________
Revo rb523::: Jato tm18::: Team Magic g4 tz.18 :::
Spektrum 3.0:::Sportwerks Mayhem buggy stock:::
(in reply to ScRacing)
       Post #: 51
RE: Sirio 23 Air Leaks UNITE - 9/13/2006 7:32:11 AM
willjeffw
Status: offline
so which one is it? size , material part#?
(in reply to bennyblanco)
       Post #: 52
RE: Sirio 23 Air Leaks UNITE - 9/13/2006 2:42:26 PM
bennyblanco
Status: offline
just call boca and tell them you want a front bearing for a sirio .23!! i think is a 7x18x5 but dont hold me on that!!!
(in reply to willjeffw)
       Post #: 53
RE: Sirio 23 Air Leaks UNITE - 9/14/2006 5:45:40 AM
ScRacing
Status: offline
ok lol i will and if i don't get the right one i'm coming to marrero, LA just to uhhh....visit savage 27...
All men die, but few men actually live
Are you alive? im looking for gasser
       Post #: 54
RE: Sirio 23 Air Leaks UNITE - 9/14/2006 5:54:03 AM
ScRacing
Status: offline
Can you get a part number?
       Post #: 55
RE: Sirio 23 Air Leaks UNITE - 9/14/2006 2:54:46 PM
bennyblanco
Status: offline
sorry i have no part#
       Post #: 56
RE: Sirio 23 Air Leaks UNITE - 9/17/2006 5:20:48 AM
REVOTMAXX.O.S.18
Status: offline
quote:
ORIGINAL: 408Revo
hi
i also need to get the front bearing for my sirio
but before i do that i need to pull my old one out first
the problem is the rubber that seals the bearing came of
so when i pulled the crankshaft out the center piece of the bearing just fell out
now im left with a hollow bearing and i cant think of a way to pull it out
any help would appreciated
thanks
Try heating block in oven to 270 to 300 degrees, then try to slam block
on a piece of hardwood, if lucky should fall out. Can try again
@ 325 if first time doesn't work.
< Message edited by REVOTMAXX.O.S.18 -- 9/17/2006 11:40:15 PM >
REVO OS.18TM/T-MAXX 2.5R/RUSTLER-NOVAK GTB 5.5,/STAMPEDE 12T Orion, 12T duratrax ESC.
(in reply to 408Revo)
       Post #: 57
RE: Sirio 23 Air Leaks UNITE - 9/17/2006 2:50:25 PM
Nathan9492
Status: offline
hmm so many air leaks on these engines
Click to see fullsize image.
Click for fullsize
(in reply to REVOTMAXX.O.S.18)
       Post #: 58
RE: Sirio 23 Air Leaks UNITE - 9/17/2006 11:45:25 PM
REVOTMAXX.O.S.18
Status: offline
I am also having air leak issue's with a 2.5R and a 2.5 my OS .18TM is fine, I think Traxxas motors are pretty much junk>>???!!!!
(in reply to Nathan9492)
       Post #: 59
RE: Sirio 23 Air Leaks UNITE - 9/26/2006 4:06:32 AM
ScRacing
Status: offline
ok Everyone the , go get boca barings, you need 7x17x5, the part number is 697, i ordered mine tonight.
       Post #: 60
RE: Sirio 23 Air Leaks UNITE - 10/3/2006 4:32:54 AM
bennyblanco
Status: offline
ScRacing i just found out that the sts.28 and the rb .23 front bearing fits the sirio .23 i dont know if you know it but just letting you know later!
       Post #: 61
RE: Sirio 23 Air Leaks UNITE - 10/3/2006 5:00:05 AM
aznherb36
Status: offline
quote:
ORIGINAL: savage.27
bocabearing over charges cause is a better bearing! but im going to order from kyosho thanks for the info!!
+1
manufactures usually always have a weak spot in engines and its usually the bearings. Dont skimp out on engine bearings. and plus its safe than sorry
       Post #: 62
Jump to:
