wing alignment on profile
Tower Hobbies
Logged in as Guest
  Printable Version
50 Size 3D Profile - RTF
Seller:  DAVIS300
Details:   $300.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> wing alignment on profile
Page: [1]
Login
wing alignment on profile - 1/6/2003 4:44:53 AM
jjoos99
Status: offline
I recently purchased a used cg extreme. When I got it home I noticed that the wing wasnt squared with the tail but was good measured off the front of the plane. It is probably off by 3/4 of an inch measured from wing tip to rudder. Do you think that this will hurt the way this plane will fly? Should I try and cut the glue joint and realign it?
Jeff
       Post #: 1
wing alignment on profile - 1/6/2003 8:38:38 AM
jmulder
Status: offline
It might not fly like its suspose to but if you cut it out and reglue it in then it could add weight. Or.....it could be lighter depending on how you do it. If it were me, I'd fly the snot out of it!........John
(in reply to jjoos99)
       Post #: 2
wing alignment on profile - 1/6/2003 6:23:59 PM
kevin4hsrcm
Status: offline
Do you know if the wing was epoxied in? If so, you can heat up the epoxy with a heat gun. Once soft, you can re-align the wing without adding weight (or very little once you touch it up with epoxy).
As far a flight characteristics - I've seen some stranger misalignments fly pretty good. You can try it first, though if you have never flown one of these, it will be hard to tell if the wing alignment is effecting it.
If is was mine, I'd fix the wing alignment. It would bug me to the extent that I wouldn't enjoy it - but that's just me.
Kevin
_____________________________
Kevin
http://www.hsrcm.com
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU4
