EdMan-RCU
Joined: 3/5/2002 From: tallahassee, FL, USA Status: offline
[QUOTE]Originally posted by sfaust It has two port. Port one can change up to 7amps, 1 to 30 cells I believe. The other can do 4 to 8 cells, but I couldn't figure out at what charge rate. If it will do up to .5 amp, you basically have half an Alpha 4. I've seen it in stock for $160 on the network. For $320, you could have the same capabilities of the Alpha 4, for about $60 more and in two boxes instead of one. Pretty close for those that don't want to wait for the Alpha. I have no idea what the user interface is like, but with only the 4 buttons, the design can be anything from ok, to nasty. Only using it for a while will tell. Its worth investigating a bit more. I know I will. [/QUOTE] Where can this beast be found? Does it charge lithium? EdMan
