Ken Erickson
IN, USA Status: offline
opa, My LA is flush with the front of the beams. SK2 is assembled exactly as in the book. Due to the softness of the needle valve assembly, the metric machine screw threads in the body strip quite easily. It is now screwed to the front of the firewall. Jared, You are the first person to believe, as I do, that there is not a need to add weight to the front of the SK2, when using an LA. With a Full tank, the thing is actually a bit nose-heavy. Still, some feel more comfortable racing with a bit of weight in the nose. It does make the elevator less effective and promotes level flight. Ken Erickson
