NickLowry
Joined: 1/19/2007 From: Lore City, OH, USA Status: offline
quote:
ORIGINAL: carldav Hi BitHed I intend to buy a LiPo set-up for the stock ESC of E-savage. Labrador told me to use a "LiPo protector" would you happen to know any recommended brand? It's hard to get alot of them to work with the dual battery packs. Most of them plug into the balancing tabs and being that you are using 2 batteries you would have to buy two. They also make some for 4S lipos, but you would have to buy an expensive 4S pack, and mount it on one side or another, making your truck of balance. Check out the LOA (Loud Obnoxious Alarm) at ApogeePacks.com, it will take some wiring modifications to make it work, but it will work. If you splice the positive inputs togeter on the esc, and connect the LOA there, then run both packs into the LOA in series, and set the LOA for 4S lipos, it will work. (The LOA is selectable between 2s & 4S lipos.) You could also use connectors to make it easy to plug the LOA in and out of your car, so you can still use nimh packs, or use the LOA in another car. Oh, and by the way, the LOA does NOT cut power to your truck, it has a LED indicator and loud alarm to let you know it's time to shut it down.
