what size prop
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> what size prop
Page: [1]
Login
what size prop - 8/17/2006 2:01:48 AM
YZF Desert
Status: offline
I am building a 16" cracker box with a trinity green machine 27 turn motor on 6 cells and need some suggestions on what millimeter prop to start with. Im going to get the plastic props I think octura makes some but I need to know a size to start with so I can buy one and then get a few bigger and a few smaller to see what works the best.
       Post #: 1
RE: what size prop - 8/17/2006 2:32:24 AM
CadillacETC2000
Status: offline
well is it submerged drive or a surface drive ?
_____________________________
Pity , with all my extra cash , just waiting to line someone''s pockets.
(in reply to YZF Desert)
       Post #: 2
RE: what size prop - 8/17/2006 2:43:10 AM
YZF Desert
Status: offline
Sorry about that its a surface drive
(in reply to CadillacETC2000)
       Post #: 3
RE: what size prop - 8/17/2006 4:19:06 AM
ryan_t888
Status: offline
Assuming it is a stock 550, I would start with a low-medium, 30'smm prop. Maybe smaller/bigger.
Ryan
A theory may be so rich in descriptive possibilities that it can be made to fit any data. - P.J.L.
       Post #: 4
RE: what size prop - 8/17/2006 4:25:18 AM
YZF Desert
Status: offline
Thats what I was thinking but I wanted to check befor I went and bought a couple.
(in reply to ryan_t888)
       Post #: 5
RE: what size prop - 8/17/2006 4:30:15 AM
ryan_t888
Status: offline
You have to start somewhere. I can almost guarantee the first prop you try won't be the perfect one, no matter where you start.
Ryan
       Post #: 6
RE: what size prop - 8/17/2006 1:45:48 PM
jdoug
Status: offline
I used to run a 27T in my 19" scratch built cat. It ran well with a 32mm (Octura x432). It would push a 35mm but sacrificed just a little run time. Octura makes a plastic y531 (31mm) and couple other plastic ones in that range that I tried before selecting one in beryllium copper.
       Post #: 7
RE: what size prop - 8/17/2006 6:07:38 PM
YZF Desert
Status: offline
I put bearings in the motor instead of bushing so, I guess that helps a little. I will probably get 31-35 millimeter maybe a 37 also. A long time ago I ran a 13 inch cat with the traxxas trive system but direct drive with the traxxas prop and it was fast and the motor was fine, but I think the motor was able to rev out with that big of a prop was because it was a small boat. (surface drive)
< Message edited by YZF Desert -- 8/17/2006 6:14:22 PM >
(in reply to jdoug)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU4
