hpi apollo
KY, USA Status: offline
if you want a 12r xs then here is the link for it http://www.hpiracing.com/piw4.php?part=1301 but assuming you are running a rotary carb setup you would need a conversion peice for your servo, and a starter box to start the engine, the hpi 12r xs is $156.75 plus shipping to you, or if i were you i would get this $130 OS 12 cv-rx http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXXA44&P=7 or thi $110 os 18 cv-rx http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP7&P=ML os has good engines, very reliable, durable, and easy to tune, if i were you i would replace it with an OS, but since you're in pakistan i would run lots of filters and clean them all the time for optmal engine life (its sandy there isnt it?) and make sure you run a fuel with good oil content, i ahve the os 18 cv-rx and its a very good engine and i dont think you would be dissapointed by it, also if you are running 20% fuel, the OS 8 plug is best so maybe get an extra one if you decide to order, hope this helps
_____________________________
95% of statistics are made up on the spot
