Bax
IL, USA Status: offline
If you're building the fuselage from plans, then just make the wing saddle in the fuse to fit the wing. A small mod, really. Then balance the airplane at the proper percentage of the wing's chord. If you're talking 3/8", then just use the plans. That's too little to worry about. I'd build the fuselage with the leading edge per the plans, and move the former at the trailing edge aft so that it's in the proper relationship to the wing's trailing edge. Use some paper to make a template for the airfoil and cut it into the fuselage at the proper incidence angle.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America 3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA Service Phone: 217 398-0007 Email: hobbyservices@hobbico.com
