RE: KAOS AND RELATED PLANES AND INFO
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: KAOS AND RELATED PLANES AND INFO
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: KAOS AND RELATED PLANES AND INFO - 8/21/2007 9:17:56 PM
tommytorino
Status: offline
Hey Guys.
I just ordered the Kaos ARF from Tower. If I may, I would like to ask a couple of questions about the model.
It's red and white. My guess is I can peel the trim covering off that separates the red from the white. Is the Red covering installed over an all white covering job? I would like to remove all the red from the wing <Its on the leading edge> and it sure would be nice to have a nice white underside!
Do the landing blocks in the wing need work, or are they ok "out of the box". I expect to go to a 3" foam wheel all the way around.
My last question <for now> is in regard to the use of a single servo for the ailerons. Can I substitute say 2 HS 225 servos side by side <to get a little flexibility and differential>
instead of the 1 standard size servo.
Thanks much for the help!
Tommy D
(in reply to dhal22)
       Post #: 101
RE: KAOS AND RELATED PLANES AND INFO - 9/2/2007 4:06:49 AM
scottrc
Status: offline
Hello Tommy.
I have a few of these Tower KAOS's because of the price and since they fly so well.
1.) As to the covering, it is the only defect in the kit. My first kit had the red peel off the wings like a bananna peel. It is easy to seperate the covering from the plane, brush some Balsa Rite on it, and recover the plane in what ever trim you want.
2.) The landing blocks are very solid and will take hard landings. I use 2.75" rubber DueBros on the mains a 2" on the nose.
3.) I have kept all mine with single servo ailerons. The roll rate is plenty fast enough and a standard ballbearing servo will hold up just fine to the pressure. There is not a lot of room where the fuse and wing meet. Even the extra length in wire cause by either a Y harness or two leads for dual ailerons would make a tight fit under there. Having the two servos side by side would really make it too cozy and may not allow for the rudder and elevator linkages to move without interference.
Scott
_____________________________
If you love that plane, set it free, if it doesn't return, you should've checked your battery.
(in reply to tommytorino)
       Post #: 102
RE: KAOS AND RELATED PLANES AND INFO - 9/5/2007 3:28:39 AM
tommytorino
Status: offline
Thanks for the heads up Scott. Your right, being a mid wing ship I can see it getting tight fast. So tight infact it looks like my battery will have to be well forward of the wing saddel. Yes mine is going to be electric powered.
The covering stripped right quick off the fuse. Only the red on the tair fethers was difficult to get off. Not sure if it was self stick trim paper, or had some nasty spray stick-em on it.
Recovered the tail in white Ultracote and red solite. Not very big on translucent, so I ordered some red Ultracote.
Going to go with 2 servos for the ailerons, mounted in the wing. Not in the stock location, but out further in the wing.
Funny, its actually a pretty darn light model. The firewall is so lightly built I added some triangle stock and extra glue. Hard to believe it dosent pop off with the vibrations of a 2 stroke and a nose wheel out front.
Has been a fun project so far, and if it flys 1/2 as good as my last glow to electric conversion Ill be very happy!
Tommy D
Click to see fullsize image.
Click for fullsize
(in reply to scottrc)
       Post #: 103
RE: KAOS AND RELATED PLANES AND INFO - 9/12/2007 8:19:55 PM
mred33
Status: offline
I love the Kaos. I have had three over the years and every one of them flew GREAT. I got every one of mine to do a knife edge, it's just a down hill knife edge. Didn't care about that though. It is one of the most forgiving pattern plans I have every flown and I love the way it lands. I am in the process of building a Super Kaos from RCM plans right now and am going to put two servos in the wing just out board of the sheeting. I also made it a tail dragger instead of the trike. I'm a slow builder, so it should be ready in about a month or so. Looking forward to flying another Kaos. I just love them.
Ed
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
       Post #: 104
RE: KAOS AND RELATED PLANES AND INFO - 9/30/2007 12:31:55 AM
Chondar
Status: offline
quote:
ORIGINAL: tommytorino
Did you have to do anything special to get the covering off, or did you just find a seam and start pulling?
I'd love to re-cover mine, and it seems like it'd be a good candidate for a different covering job. I'd love to give it something to make it stand out a bit at the field.
J
Hangar: Pulse XT, AviStar, Kaos, CG 67" Yak 54 (eventually)
       Post #: 105
RE: KAOS AND RELATED PLANES AND INFO - 9/30/2007 3:25:44 AM
rainedave
Status: offline
Tommy, that's kind of brilliant. At $99 it really does make a lot of sense to get one of these, strip off the covering, inspect the structure and then do your own covering job. The factory covering is probably the main thing that keeps me from buying ARF's (I like my planes to look like mine). I wonder how hard it would be to remove the covering from a GP Venus or a Cermark Javelin?
It's funny, when the ARF craze was first taking off several companies offered ARC's as well as ARF's. I only know of a few still doing it.
David
(in reply to Chondar)
       Post #: 106
RE: KAOS AND RELATED PLANES AND INFO - 9/30/2007 11:13:20 AM
Ed Cregger
Status: offline
quote:
ORIGINAL: rainedave
David
I used to enjoy the Model Tech ARCs. The hard part was done (framing/sanding) and I enjoy covering models, so that was fun. I still buy some of their products, but they aren't as much fun to assemble. I would gladly pay the same price for a well sanded ARC as what they are charging for their current ARFs. Anyone else?
Ed Cregger
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
(in reply to rainedave)
       Post #: 107
RE: KAOS AND RELATED PLANES AND INFO - 9/30/2007 3:04:40 PM
cllaurit
Status: offline
I agree wholeheartedly, I loved ModelTech kits (can you call them that?) and I always did like covering. I would love to see the ARF planes available in ARC form.
Maneuver complete
(in reply to Ed Cregger)
       Post #: 108
RE: KAOS AND RELATED PLANES AND INFO - 9/30/2007 9:32:32 PM
Ed Cregger
Status: offline
Now, if we could just get Model Tech to offer ARC versions of Kaos, Dirty Birdy, UFO, Daddy Rabbit, etc., foam-wing equipped clones!!!
Ed Cregger
Artisan
(in reply to cllaurit)
       Post #: 109
RE: KAOS AND RELATED PLANES AND INFO - 10/6/2007 11:46:57 PM
tommytorino
Status: offline
I'm going to try and get back on the Kaos tomorrow. After being out of work for 5 months <on the job injury> I'm trying to get used to working again! So while I have found time to fly, building time is limited.
In all fairness I did remove the Kaos from the bench for 2 days to assemble <note I did not say build!> a new electric Multiplex Gemini sport bi-plane. Guys, this little chunk of foam is going to be my pattern primer for learning! Fast to repair <with good old CA on foam, who would have thunk it!> and easy to fly in small quaters this thing is a dream to fly!
Back to the Kaos, my club field just changed the runway orientation to keep from over flying a trailer sales lot. So while the approach is longer on on side, its a LOT shorter on the other. Also the runway is shorter. So back out with my Graupner pattern conversion to help with landing. Guess I'm just used to landing these little 2lb electric models at my feet. Not so easy with a 6lb+ pattern plane.
Nice to see the thread is alive and well!
Tommy D
Click for fullsize
Click for fullsize
< Message edited by tommytorino -- 10/6/2007 11:48:38 PM >
       Post #: 110
RE: KAOS AND RELATED PLANES AND INFO - 10/15/2007 2:46:36 PM
bobybayo
Status: offline
Does anyone knows the recommended CG for the Tower Kaos 40 Kit ( about 10 years old) that was listed in the manual?
(in reply to pimmnz)
       Post #: 111
RE: KAOS AND RELATED PLANES AND INFO - 10/16/2007 2:02:07 AM
modegrande
Status: offline
C.G. is 4 inches back from the leading edge holding the plane upsidedown.
(in reply to bobybayo)
       Post #: 112
RE: KAOS AND RELATED PLANES AND INFO - 11/3/2007 2:30:33 AM
DRonland
Status: offline
Here is a loud Kaos everyone....Eagle One.
Eagle 1
Super Kaos
Totally Original - 30 years old this year...Aerogloss Dope (buffed out of course)
Happy Flying!
(in reply to roncoleman)
       Post #: 113
RE: KAOS AND RELATED PLANES AND INFO - 11/3/2007 4:02:29 PM
Free Bird
