RE: KAOS AND RELATED PLANES AND INFO
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: KAOS AND RELATED PLANES AND INFO
Page: <<   < prev  1 2 3 4 5 [6] 7 8 9 10   next >   >>
Login
RE: KAOS AND RELATED PLANES AND INFO - 11/26/2007 5:01:20 PM
tommytorino
Status: offline
Just a quick FWIW as it seems this thread is pretty much dead.
While stripping the fuse/tail on the Kaos the covering came off very easy. Today I did the wing.
I took notice on the wing the joints between the red and white covering had a milky look. I feel that are sealing it to some degree at the factory now. The black/yellow pinstripe comes right off with heat. The red and white did come off pretty easily but there is a sticky residue left on the wing. I feel again at the factory they are spraying the wing with something to help the covering stay put.
All good things if you want the factory covering to stay on. I do think you better seal the pin stripes with something or they will be gone right quick.
Tommy D
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by tommytorino -- 11/26/2007 5:02:18 PM >
(in reply to tommytorino)
       Post #: 126
RE: KAOS AND RELATED PLANES AND INFO - 11/26/2007 10:19:35 PM
juggernaut47203
Status: offline
Ron,
Thanks for for your response. So, the Super Tigre G51 puts out as much as Fox Eagle... humm. I am new to pattern, so I am assuming that the Fox Eagle is like a typical engine used back in the late 70's through 80's? I ran a quick experimant this past weekend and got the following:
Engine..Prop Brand..Prop Dia. (in)..Prop Pitch..RPM..Horsepower..Speed (mph)..Static Thrust (lb)..Fuel
Super
Tigre G51
.....Master Airscrew.......10................6.....14700.....1.36............83.5..............6.8..........10% Omega
.....Master Airscrew.......11................7.....12600.....1.46............83.5..............7.3..........10% Omega
.....APC........................10................7.....14300.....1.46............94.8..............6.4..........10% Omega
.....APC........................11................6.....12700.....1.29............72.2..............7.4..........10% Omega
MDS 61
.....Master Airscrew.......11................7.....13000.....1.61............86.2..............7.8...........10% Omega
Here is the kick. The Super Tigre G51 weights in at 18oz. with muffler and any of the typical new .61s (nothing exotic) will tip the scale at 24 oz. So, ther is 1/2 lb difference on just the engine alone. Now with the G51 I can use a smaller fuel tank (10 to 12 oz.) and still have the same flight time as a .61 with (14 to 16 oz), more weight savings and the engine profile is samller more compact... It start to sound pretty good. I am curently flying a Tower Kaos .60 with the MDS swing a MA 11x7, but the plane is heavy at least 7.5 lb. (dry) using 16 oz tank. Looking at the Thrust and HP numbers the G51 looks like a good choice. Thoughts?
Click for fullsize
< Message edited by juggernaut47203 -- 11/27/2007 2:29:07 AM >
(in reply to roncoleman)
       Post #: 127
RE: KAOS AND RELATED PLANES AND INFO - 12/5/2007 2:41:32 AM
scottrc
Status: offline
quote:
ORIGINAL: tommytorino
Tommy D
It is looking really good Tommy.
Scott
_____________________________
If you love that plane, set it free, if it doesn't return, you should've checked your battery.
       Post #: 128
RE: KAOS AND RELATED PLANES AND INFO - 12/9/2007 1:50:19 AM
tommytorino
Status: offline
Thank You Scott.
I'm dead in the water right now. One of my NIB H 225MG servos was DOA NIB!
FWIW I have decided to extend the Kaos ailerons to 1.5"s and also turn the inside 7"s or so into flaps. The ailerons will be independent on the servos and the flaps will use the factory cinter servo off torque rods.
My hope is extending the ailerons 50% to 1.5"s will increase the roll rate even with the inboard section converted to flaps.
My memory of my Pops Contender slowing for a landing back in the 70s is still stuck in my head!
Tommy D
Click for fullsize
Click for fullsize
< Message edited by tommytorino -- 12/9/2007 1:51:36 AM >
(in reply to scottrc)
       Post #: 129
RE: KAOS AND RELATED PLANES AND INFO - 12/9/2007 2:49:53 AM
Mad Man Marko-RCU
Status: offline
Tommy:
Doesn't surprise me that you had a DOA servo NIB. I bought 4 HS475HB's local and 1 was DOA. Dealer replaced OK. Also bought 4 HS425BB's from Tower and 1 was DOA, also replaced OK.
I'm going to buy Hitecs 3 at a time now because the 4th is always dead. Always holds you up in building though.
Peace
Mark O
You''''ll be Glad You went Mad!
       Post #: 130
RE: KAOS AND RELATED PLANES AND INFO - 12/9/2007 11:23:36 PM
roncoleman
Status: offline
juggernaut47203
Those are good number for the G51 and you answered your own question.
By the way, per the Fox page that old FOX weights 14 oz. and puts out
11,500 on 11-8 prop. Nothing was say about what type of fuel used (maybe
FAI) nor brand of prop (back in those days maybe Rev-Up or Top Flite Super
M). The added weight if a muffler should bring that old fox to about the same
weight as your G51. Give that Fox some 5 or 10 % fuel and a APC prop, it's
numbers on a 11-7 might be just a little off from the G51. Can't really say but
I do know you have the better made, user friendly engine, and could/should
out do the Fox somewhat. Maybe you should try one of those new OS 55AX.
The numbers are even better than the G51 and about the same weight. So
have at it and keep us posted.
Ron
< Message edited by roncoleman -- 12/10/2007 12:04:23 AM >
(in reply to juggernaut47203)
       Post #: 131
RE: KAOS AND RELATED PLANES AND INFO - 12/11/2007 12:55:37 PM
matt13
Status: offline
Had a KAOS moment today....Was in the back yard doing some over due gardening for the second day and not feel very motivated about the job to say the least! Anyway I started to notice around 10am that there was not a breath of wind, into the shed, behind the pattern model my old KAOS which had just recently had a heart transplant with a new OS was beckoning. Down to the field (only ten minutes away) and I had two flights just cruising doing what ever came to mind, spins, rolls etc, flying until the fuel ran out, then gliding in to try to land at my feet. By the time I was back home I had only used up 1.5hours, but the rest of the gardening was a breeze!
Click for fullsize
Click for fullsize
       Post #: 132
RE: KAOS AND RELATED PLANES AND INFO - 1/8/2008 5:39:20 AM
Thomas B
Status: offline
I have been cleaning up and organizing the garage and found a classic NIB Bridi Kaos kit out there I had forgotten about....
I used to fly the Kaos in pattern in the late 1970's, a little after it's day in the sun. I never liked the looks of the Super Kaos, the regular Kaos was always my fav. Won a few Novice Pattern events with it in 1976 and 1977.
I mostly do electric these days...thinking about building it up for a big Axi outrunner....
Electric Coolhunter
(in reply to matt13)
       Post #: 133
RE: KAOS AND RELATED PLANES AND INFO - 1/12/2008 5:28:43 AM
LS171Malibu
Status: offline
Thomas, I just finished an Original Kaos. I fly at the FW Thunderbird's club, and am puting together a "SPA" pattern contest late March. You should build that bird and come fly with us!
Click for fullsize
Blake
(in reply to Thomas B)
       Post #: 134
RE: KAOS AND RELATED PLANES AND INFO - 1/14/2008 1:17:15 AM
Thomas B
Status: offline
quote:
ORIGINAL: LS171Malibu
Hey there...I am a T-bird...Tom Blakeney, here. I was at the meeting when you talked about it. I'd love to fly in it, but no time to get it built that fast.
I flew pattern extensively in the late 1970s. Southwestern regionals winner in Novice in 1976, lots of local and regional Novice and Advanced wins with my std Kaos, LHX-1 and then my newfangled Phoenix 7....)
< Message edited by Thomas B -- 1/14/2008 5:22:15 AM >
Electric Coolhunter
(in reply to LS171Malibu)
       Post #: 135
RE: KAOS AND RELATED PLANES AND INFO - 1/14/2008 3:52:53 AM
LS171Malibu
Status: offline
Darned small world? See ya at the meeting. BTW, if that Kaos box is taking up too much space, let me know!
Blake
       Post #: 136
RE: KAOS AND RELATED PLANES AND INFO - 2/6/2008 9:15:32 PM
fg56
Status: offline
HELLO FELLOW R/C PILOTS I WAS WONDERING IF ANY OF YOU HAVE HEARD OF A CORSAIR (NOT THE F4U) PATTERN PLANE I HAVE THIS KIT AND I'M BUILDING IT THE BOX SAYS IT WAS THE JAPANESE CHAMPION BUT GIVES NO DATE IT BELIEVE IT IS PROBABLY IN THE VINCINITY OF 35 TO 40 YEARS OLD ANY INPUT WOULD BE GREAT I'LL POST PICS DURING THE BUILD AND TRY TO GET A PLAN PIC UP IN THE NEAR FUTURE
Fortune Favors the Bold
       Post #: 137
RE: KAOS AND RELATED PLANES AND INFO - 3/2/2008 6:10:06 AM
rainedave
Status: online
I finally scanned the Kaos plans. PM me if you need a copy.
David
Click for fullsize
(in reply to fg56)
