RE: KAOS AND RELATED PLANES AND INFO
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: KAOS AND RELATED PLANES AND INFO
Page: <<   < prev  1 2 3 4 5 6 [7] 8 9 10   next >   >>
Login
RE: KAOS AND RELATED PLANES AND INFO - 4/11/2008 6:08:59 PM
Ed Cregger
Status: offline
quote:
ORIGINAL: tommytorino
Did some covering today. Not my best work, but I really don't like covering.
Wings next.
Tommy D
What's that in the nose? A pencil sharpener? 8>
It looks fine.
Ed Cregger
_____________________________
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
(in reply to tommytorino)
       Post #: 151
RE: KAOS AND RELATED PLANES AND INFO - 4/18/2008 4:01:19 PM
MostlyKaos
Status: offline
I have a Tower Kaos ARF, running a .46AX. Runs and flys great. I want to experiment by putting a Saito Golden Knight engine in it. I am thinking an FA-62a would fit and perform well. The Saito weighs 15 oz, while the OS weighs 12oz.
What do you think?
(in reply to Ed Cregger)
       Post #: 152
RE: KAOS AND RELATED PLANES AND INFO - 4/18/2008 6:21:55 PM
Ed Cregger
Status: offline
quote:
ORIGINAL: Ironhands
What do you think?
I'm sure it will fly the Kaos, but don't expect it to fly as powerfully as it did with the OS .46AX two-stroke. Now this assumes that you were flying the two-stroke at mostly full throttle. If you were throttling back and cruising around, you may not notice a serious/significant difference in power between the two engines. Move your battery to behind the servos, if your model comes out nose heavy, which it probably will with the four-stroke engine.
I have several Tower Kaos ARFs NIB and I'm thinking of doing the same thing as you with one of them, but I will use a Saito .82 instead of the .62. You might want to replace the stock fuel tank with a smaller unit for the Saito .62 (6 oz.). Why? Because four-strokes vibrate a bit more than most two-strokes. With the fuel tank neck passing through the firewall, the extra vibration of a four-stroke might lead to fuel foaming and lots of in flight grief (deadsticking, etc.). With the four-stroke requiring less fuel, you can get away using a smaller fuel tank that is entirely encapsulated in soft, uncompressed foam. The latter will prevent fuel foaming and you from ruining a really nice engine. You might want to plug the hole in the firewall to allow just the fuel lines to pass, but to keep out as much fuel goop as possible.
I'm thinking of building a battery box behind the rear wing saddle bulkhead, as I usually do when using a heavier than stock engine in a model. This permits me to rebalance the model without having to add any weight by redistributing the existing weight of model components. The battery box has its own removable door for installing the battery. Leave enough room in there to run a couple of strips of foam tape on the bagged flight battery (you do use a plastic bag on your battery to prevent fuel creep, don't you?).
Ed Cregger
Artisan
(in reply to MostlyKaos)
       Post #: 153
RE: KAOS AND RELATED PLANES AND INFO - 4/18/2008 9:55:34 PM
cloudancer03
Status: offline
great looking planes.brings back fond flying memories.I am in florida for the moment and have flown electrics most of the winter but when I get home theres a rebuilt kaos waiting to bore new holes in the sky.I PLAN TO USE EITHER A OS 61 OR MAGNUM 61 ..I love the pics gave me some covering ideas.
(in reply to Moodyman)
       Post #: 154
RE: KAOS AND RELATED PLANES AND INFO - 4/18/2008 11:20:52 PM
Wblakeney
Status: offline
I am still flying a 25 year old Bridi Super Kaos 40 with an OS 46 FX. Even then I don't run full throttle all the time. I have an OS 46AX but haven't tried it on it yet. Looking at pictures at one time it had a Como 50 on it but that was so long ago I don't remember how it did. Of course my first Kaos 40 had a K&B 40 on and that seemed like plenty of engine.
If it aint right, fix it. If you can't fix it, don't fly it.
       Post #: 155
RE: KAOS AND RELATED PLANES AND INFO - 4/19/2008 2:06:22 AM
Ed Cregger
Status: offline
My first Super Kaos .40 (Bridi kit) was powered by a K&B .40 too. I then bought the then new schneurle ported Super Tigre .40S, but that turned out to be less powerful than the K&B .40, believe it or not, so I went back to the K&B .40. The ST .40S was a good engine, but it was a disappointment power wise. It ended up in a helicopter and was sold after powering my Phaeton biplane for a year or two. I didn't miss it at all.
Today's Tower Kaos ARFs are sized in between the original Kaos 60 and the Kaos 40. I suspect that it would fly well with a .40 or a .60. You'd have to widen the stock engine mount a bit to use the Rossi .53, OS .55AX or Enya .61CX (built in the .40CX crankcase and actually a .58), but they should brighten up the performance a bit for this slightly larger version of the Kaos .40 (note, not Super Kaos).
My problem is that I have more engines available than I truly need and it is creating a problem for me when it comes to deciding which one to use. Fortunately, this type of engine mount just clamps the engine in place, so I guess I can try all of them.
Ed Cregger
Artisan
(in reply to Wblakeney)
       Post #: 156
RE: KAOS AND RELATED PLANES AND INFO - 4/19/2008 3:33:53 AM
MostlyKaos
Status: offline
Ed, did you cut into the bottom of the fuselage to install your battery box?
did you cut into the tank area to fully pad your fuel tank?
Fuel creep? Is that the stuff that enters the tank area through the hole in the firewall? or the exhaust that creeps past the wing root into the servo bay?
No I have not used a plastic bag for my battery.
       Post #: 157
RE: KAOS AND RELATED PLANES AND INFO - 4/19/2008 12:40:23 PM
Ed Cregger
Status: offline
I haven't made the battery box in this Tower Kaos because I'm sticking with two-strokes that fit in the stock mount as it is. However, I have three more NIB Tower Kaos ARFs, so I'm sure that I'll get to doing the battery box and tank/firewall mods later when I install the Saito .82 four-stroke engine in one of the other models.
Yes, I'll seal up the hole in the firewall to keep out the carb spit and random exhaust/crankcase nose area leakage/swirlings when I drop to the smaller sized fuel tank when using the four-stroke engine.
The fuel creep at the wing saddle can be taken care of by laying some Saran Wrap over the top of the wing and taping it in place. Then apply a bead of silicone rubber glue to the inverted fuselage's wing mating surfaces. Then assemble the wing to the fuselage and bolt it down normally. This squeezes out the excess silicone glue and seals the gap between the wing and fuselage sides. Let sit for a day or two, then remove the wing and trim the silicone to shape. Voila! (Wah-Lah!). A sealed and cushioned wing saddle junction. No fuel creep there.
Ed Cregger
Artisan
       Post #: 158
RE: KAOS AND RELATED PLANES AND INFO - 4/19/2008 1:37:22 PM
MostlyKaos
Status: offline
ED, Thanks for the wing saddle advice.
Question, Do you put your battery in a plastic bag and wrap a zip tie around the wires and bag?
       Post #: 159
RE: KAOS AND RELATED PLANES AND INFO - 4/19/2008 1:38:23 PM
MostlyKaos
Status: offline
Do all of you Kaos flyers balance your Kaos inverted?
       Post #: 160
RE: KAOS AND RELATED PLANES AND INFO - 4/19/2008 6:31:55 PM
Ed Cregger
Status: offline
quote:
ORIGINAL: Ironhands
Yes, it is a do as I do thing with me.
Although, I don't use a zip tie to keep it sealed. I use tape.
Ed Cregger
Artisan
       Post #: 161
RE: KAOS AND RELATED PLANES AND INFO - 4/21/2008 12:37:43 PM
Ed Cregger
Status: offline
quote:
ORIGINAL: Ironhands
I just get the Kaos to balance on the main spar and then go from there. Balancing the model inverted would probably be more accurate and easier to do, but I just pop my fingers under the wings and make a quick check. That's enough to tell if it is going to be safe to fly. After you get flying, then you start moving the balance point around until it flies the way you like.
Ed Cregger
Artisan
       Post #: 162
RE: KAOS AND RELATED PLANES AND INFO - 5/25/2008 8:48:49 PM
Marian
Status: offline
Hi everybody.
My story started about two years ago when I entered this forum by chance. I was very curious what "pattern planes" could be.
I ret a lot about them and finally I decide to build my own Kaos. I changed a little bit the fuselage (mainly the tail part), but as there is no SPA in Spain, it is not a big deal.
I was strongly influenced by Rainedave´s UFO thread.
Thand you Dave. Your help was very important for my introduction to classic pattern planes.
When the fuselage was covered by oracover, I decided to follow Dave and cover the wing with Koverall. Suddenly my workshop smelt to dope equally as twenty years ago, when I was making free flying gliders.
Then I decided to experiment with HVLP gun. (the desing of upper side is borrowed from Dave´s Ufo, and of bottom from another gentleman on this forum).
I have finished the plane last Christmas, but due to problems with our club´s flying field I could not make the first fly until this weekend.
What to say about the first experience?
I like it much more than fun fly plane that I had been flying before. Everything is so smooth ... and landing is almost so slow as with a 3D plane...
Anyway, as problems with our runway and not fully solved, I have already started to build .15 Peppermint Pattie without landing gear. The wing (all balsa) is almost finished and I hope I'll have the plane ready by the end of June.
Regards,
Marian
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
