rcpattern
TX, USA Status: offline
David, I have PERSONALLY flown the Pinnacle, a Brio, a Twister, Nedim Bek's Mantis, Smaragd, Partner's and also Mike's personal Black Magic. NOTHING has flown better than Mike's black magic. In about 2 minutes I was more comfortable with that airplane than anything I've ever flown, other than my Mantis. I have never flown a plane that came close to snapping like that one does...it rolls like you wouldnt believe...it flies better than my Mantis, and my poor Mantis certainly kicked some serious tail this year at the NATS..likely would've won Masters had it not been for a faulty pipe mount that in 3 years had never had a problem. I also go to see Sean's Astrall XX by Naruke, and other than a little finish details, I think the pure construction of the black magic is definitely up to par. After seeing photo's of Mike's other planes..I think if you come to the NATS next year, you will agree..the guy can flat out build...I know that he rushed these 2 Black Magic's he is flying now. I have seen the ZN stuff, and I have heard NUMEROUS complaints about them..ask Mickey Lasardo what he thinks of ZN...as usual the Chicago gang ordered multiple airplanes, and he had TERRIBLE luck with their wings and he is one of the top builders in the US..all of the manufactures have faults..and here is another little secret...guys can happily go spend 5000 on a pro built pattern plane, but put a 500 ARF in the hands of the right pilot and sit back and enjoy the show...I have definitely enjoyed winning MANY contests with my poor 3 year old Mantis...I have new planes coming now..but that plane has served me well, and it has certainly beaten its share of Oxai's, ZN's, PL, Piedmont's and any other manufacturer you want to throw in there. You should try flying one of these "wood roaches" as you call them before you knock them...I've flown the rest, and other than Sean's Astral XX (which was also wood by the way), I will happily choose the wood airframe. I felt that way years ago when the Prophecy's were THE plane to have..and I was flying a Viper...an airplane which also whipped it's share of Prophecy's and the like. They are so much more rigid than ANY composite airframe..and before you decide to tell me otherwise, please note I do composite work daily for the military and have worked with the best of the best of materials. I have built and flown many different UAV's, with about every imaginable combination of materials, and i still believe in the hands of the right builder, a well build wood airplane, is lighter (YES, lighter) and more rigid than any other type of material. Yes, you can build a composite aircraft maybe a little lighter, but you sacrifice rigidity, and there is ZERO advantage to a pattern plane under 10lbs in my opinion..on a calm day, sure..but try flying in the weather we had at the NATS on thursday this year with a VERY light plane..you are definitely at a disadvantage. I can promise you, if flying a 9lb airframe, which I still have no personally seen a plane that light; was that big of an advantage, then NONE of the top FAI guys would be flying planes that way 10 - 10.5, which they all are, some even heavier. I know Andrew likes his to be in the 10 1/4-10 1/2 range. I think about 100 sq inches per pound is the best ratio...You have to be VERY careful and selective in the quality of wood, but it can be done. I personally despise building. I like the kevlar/carbon aircraft from a time stand point and repeatability stand point, but that is the builder, not the kit.. Just my 2 cents... and by the way, i love the look of this Zeque Arch Stafford
< Message edited by rcpatt |
