Replacing Tail Boom
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Replacing Tail Boom
Page: [1]
Login
Replacing Tail Boom - 8/18/2006 8:02:36 PM
charcoaldabs
Status: offline
I just got my helidirect package, and I was about to replace the tail boom, when I realized the stock tail boom is really in there. How is it stock attached? If it is CA, how can I unstick it? And how should I attach the new tail boom, CA?
_____________________________
I reject your reality, and substitute my own.
       Post #: 1
RE: Replacing Tail Boom - 8/18/2006 8:36:08 PM
hover_lover
Status: offline
I use a heat gun to defeat the CA. Works great in the proper hands, but can melt your junk in the wrong hands. The trick is to apply a liitle heat and test it. Repeat as needed. Remove servos etc. so you don't melt them.
I've got a strong urge to fly but I've got no where to fly to... fly to... fly to...
(in reply to charcoaldabs)
       Post #: 2
RE: Replacing Tail Boom - 8/18/2006 11:42:38 PM
charcoaldabs
Status: offline
Is brute force a possibility, is there any other way then buying a heat gun?
(in reply to hover_lover)
       Post #: 3
RE: Replacing Tail Boom - 8/19/2006 12:28:46 AM
hover_lover
Status: offline
Its all paper-rock-scissors. Heat gun beats CA but CA beats carbon fiber. Brute force will break the CF (more than likely) before the CA lets go.
Others have cut off the boom flush at the airframe and then drilled it out to the proper size. You could simply use a new airframe.
       Post #: 4
RE: Replacing Tail Boom - 8/19/2006 12:37:30 AM
choppersrule
Status: offline
charcoaldabs,
I got this from another thread, from Psikelly, I believe.
Try soaking it in paint thinner.. remove all the servos and stuff before you do..
I think the heat gun would be a sure beat thou... DON'T USE any kind of tourch, like fire.. Instant ashes.
Dave / Choppersrule
Left skid low....
       Post #: 5
RE: Replacing Tail Boom - 8/19/2006 12:54:03 AM
charcoaldabs
Status: offline
So what kind of heat gun are we talking specifically? While a hair dryer work? I should be out at a CVS tonight, I'll look for a heat gun, but I have a feeling I'll have to get to a radio shack.
(in reply to choppersrule)
       Post #: 6
RE: Replacing Tail Boom - 8/19/2006 12:57:45 AM
ct420
Status: offline
I have this very heat gun, and it works great:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHZ16&P=7
Pops that CA loose in no time...
I don't think a hair dryer would work. They just don't get hot enough.
You could probably use one of those heat guns made for stipping paint, although those get VERY hot, so you would have to be extra careful...
       Post #: 7
RE: Replacing Tail Boom - 8/19/2006 1:16:38 AM
choppersrule
Status: offline
charcoaldabs,
If you get the heat gun, be very careful, they get hot enough to catch paper on fire.
Since, your tail boom is already toast. Test the heat gun in the middle of the boom to see, how close or far awayyou should be from the carbon fiber structure before it melts..
You don't want to melt the main frame.
Dave / Choppersrule
Left skid low....
(in reply to ct420)
       Post #: 8
RE: Replacing Tail Boom - 8/19/2006 8:10:31 PM
charcoaldabs
Status: offline
Hmm, well I bought a heat gun guys... and it didn't seem to do much. After about an hour of trying I decided to turn the heat on to high, and hold it reaaaaal close, part of the plastic holding a servo started to bubble. However, the old boom would not budge! I am at a loss of what to do, besides the paint thinner which seems extremely hard, any tips guys?
       Post #: 9
RE: Replacing Tail Boom - 8/19/2006 8:28:39 PM
choppersrule
Status: offline
charcoaldabs,
Hmmm, heat gun didin't work.. Only thing left I can think of is to drill it out with a bit just a tiny smaller than the boom diameter and then one the same size. Just have to be real careful.
Good luck,
Dave / Choppersrule
PS... At worst, you can always get a main frame assembly for about $12. Comes with main frame, tail boom and tail motor housing.
Click to see fullsize image.
Click for fullsize
Left skid low....
       Post #: 10
RE: Replacing Tail Boom - 8/19/2006 9:51:50 PM
charcoaldabs
Status: offline
Hmm, I'll keep trying this heat gun cause it set me back 30 dollars, any more tips for using it anyone? Psi, CT420, wanna pipe up?
       Post #: 11
RE: Replacing Tail Boom - 8/20/2006 2:13:10 AM
Psikelly
Status: offline
Well if money is a factor then youre gonna wanna fix it so strip that frame down and soak it in a jug of paint thinner for at least a couple hours. Soon as you pull it out try twisting it out. If it doesnt work then hit it with heat as well. If it still doesnt work let it soak a couple more hours and repeat. You will get it out like this cuz Ive done it. Just takes a bit of waiting.
NO I did not just crash!! Im making it flop around on the ground like that on purpose. Its a new stunt.
       Post #: 12
RE: Replacing Tail Boom - 8/20/2006 5:24:08 AM
charcoaldabs
Status: offline
Yea, I am just most worried about re assembling everything, but I guess I'm already screwed, so I might as well go all in. Any particular paint thinner to use?
(in reply to Psikelly)
       Post #: 13
RE: Replacing Tail Boom - 8/20/2006 8:06:27 AM
ct420
Status: offline
The heat should have worked. How hot does the heat gun get? Mine is 400F when I close the vent on the back almost all the way, and put on the attachment that squeezes the air down to a thin flow.
You have to get it really hot. Just do it slowly. Heat for several seconds with the end of the gun about 1-2 inches from the plastic. Move the heat gun around it constantly. Don't let it sit in one spot too long. Heat it a bit, then twist to see if it's loose. If not, heat again immediately, and repeat. I can usually get it off in about 5mins using this technique...
The paint thinner would certainly make it easier to come off, so if you just don't think you can get it with the heat, then follow PSI's advice, and it should come off for sure.
Just remember, a whole new frame and boom is only about $15.00, and that's your worse-case scenario. Don't be too afraid of breaking it...
       Post #: 14
RE: Replacing Tail Boom - 8/20/2006 4:51:27 PM
Psikelly
Status: offline
JUst normal paint thinner is good enough. Like Varsol or Varasol not sure how its spelled. Just look in the paint section. If youre not sure just ask the counter guy for it and tell him its for cleaning paint brushes. He'll know what it is
Dont worry bout getting it back together . It looks way more complicated than it actually is. Itll be a breeze goin back together and theres lots of online help to get it together again. Itll also give you experience youre gonna need sooner or later anyway replacing broken parts
(in reply to ct420)
       Post #: 15
RE: Replacing Tail Boom - 8/20/2006 5:27:12 PM
charcoaldabs
Status: offline
CT420, my heat gun is 750/1000 according to the package, though I can hold my hand in front of it with out burning myself, however heating my
