Blade wont take flight    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Blade wont take flight
Page: [1]
Login
Blade wont take flight - 8/19/2006 2:21 AM
wrh117
Score: 100
Last Login: 4/28/2010
Status: offline
Ok guys I need help. I bought a blade CP used. I have been playing with it for 3 days now I just figured out that it wont lift off. the blades are alittle damaged but not enough to prevent lift. I am not sure if the battery is bad? I am thinking about a lipo and some new blades but not sure if there is something else I should check.
< Message edited by wrh117 -- 8/19/2006 4:31 PM >
Hide Signatures
       Post #: 1
RE: Blade wont take flight - 8/19/2006 3:17 AM
hutchpba
Score: 100
Last Login: 7/18/2009
Status: offline
Could be a number of things......Bad battery, worn out main motor,pitch not set correctley, damaged blades...any or all of these could be the problem...I would start with making sure your pitch is set correctley and maybe a new set of blades and go from there.
Hutch
Hide Signatures
(in reply to wrh117)
       Post #: 2
RE: Blade wont take flight - 8/19/2006 3:32 AM
choppersrule
Score: 100
Last Login: 7/19/2012
Status: offline
wrh117,
I agree with Hutch, new blades and check the pitch...
If the motor sounds okay and appears to come up to good head speed, then pitch is probably your problem.
If the motor sounds loud or straining, maybe the motor..
Check the gear mesh, turn the main rotor and see if it turns smoothly. If not, try putting a little light oil, graphite or teflon spray on the main gear.
I'm guessing by your post that you have the NI-MH battery, you should get at least a full 6 minutes or more with this battery, if not, you battery is going astray.
So many things to check,
Dave / Choppersrule
Hide Signatures
(in reply to hutchpba)
       Post #: 3
RE: Blade wont take flight - 8/19/2006 3:47 AM
wrh117
Score: 100
Status: offline
How can i check pitch?The blade came with no instructions.
Hide Signatures
(in reply to choppersrule)
       Post #: 4
RE: Blade wont take flight - 8/19/2006 3:53 AM
hutchpba
Score: 100
Status: offline
Try this.....
http://www.bladecprepair.com/man_mr_setup_and_adjustment#zero
This site is great if your a beginner....Lots of info..Hope this helps!
Hutch
Hide Signatures
       Post #: 5
RE: Blade wont take flight - 8/19/2006 7:24 AM
choppersrule
Score: 100
Status: offline
wrh117,
Here's a link that you can download a CP manual, it's about 2.5 megabits.
http://h1070250.hobbyshopnow.com/ProdInfo/Files/BladeCP-Manual.pdf
Dave / Choppersrule
Hide Signatures
       Post #: 6
RE: Blade wont take flight - 8/19/2006 4:32 PM
wrh117
Score: 100
Status: offline
Great! Thanks for the manual link, that should be really handy as this is my first heli.
< Message edited by wrh117 -- 8/19/2006 4:43 PM >
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
