Tip Stals and CG
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> Tip Stals and CG
Page: [1] 2   next >   >>
Login
Tip Stals and CG - 8/19/2006 3:23:46 AM
Tim Taylor
Status: offline
I should know this but can't remember...
What is the relationship between the center of gravity and a tip stall?
       Post #: 1
RE: Tip Stals and CG - 8/19/2006 3:58:25 AM
Tall Paul
Status: offline
Aft c.g. and too much elevator can produce tip stalls.
_____________________________
Sparky Paul
http://www.angelfire.com/indie/aerostuff
(in reply to Tim Taylor)
       Post #: 2
RE: Tip Stals and CG - 8/19/2006 7:19:48 AM
Jimmbbo
Status: offline
The two are indirectly related...
Tip stalls are usually caused by an excessive AOA at the wingtip due to inadequate washout (downward twisting of the wing LE as you move toward the tip). Most wings are tapered, with smaller ribs toward the tip. Those smaller ribs (wing sections) stall at a lower AOA, so the wing must be twisted toward the tip to compensate for that difference..
If you have an aft CG, the wing will stall sooner - if the tips do not have proper washout, they will be the first to stall.
Cheers!
Jim
Have you flogged your crew today?
       Post #: 3
RE: Tip Stals and CG - 8/19/2006 7:23:50 PM
RaceCity
Status: offline
Stalls have NOTHING to do with CG. Stalls are the result of exceeding the critical AOA for a given airfoil - Period. An aft CG simply makes this easier to accomplish, but it has no effect whatsoever on the actual stall AOA of the wing.
Washout is incorporated to get the wing to stall at it's root before it stalls at the tip in order to maintain some semblance of roll stability.
AMA 63990
(in reply to Jimmbbo)
       Post #: 4
RE: Tip Stals and CG - 8/22/2006 4:47:53 AM
Tim Taylor
Status: offline
I added 3/4 ounce to the nose of this plane and it helped conciderably. It's a pleasure to fly this plane now. It's almost an inch off from the makers specs.
Thanks All.
(in reply to RaceCity)
       Post #: 5
RE: Tip Stals and CG - 8/22/2006 10:49:29 AM
Jimmbbo
Status: offline
quote:
ORIGINAL: RaceCity
Hmm... In the absence of AOA indicators, we fly models based on their apparent airspeed, so I submit that ignoring airspeed when predicting when a model will stall is an invitation to use the hobby rake and trash bag at the end of the flight. The airspeed at which any airplane reaches its critical AOA depends on the CG, weight and load factor.
Since we use airspeed to retain a margin above the stall, and the original post asked about the connection between CG and stalls, to ignore its effect is to ignore a relevant part of the initial post.
FYI, in FAA Advisory Circular 61-67c, Stall and Spin Awareness Training:
"The CG location has a direct effect on the effective lift and AOA of the wing... A forward CG location will often cause the stalling AOA to be reached at a higher airspeed."
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/a2fdf912342e575786256ca20061e343/$FILE/AC61-67C.pdf ) Page 2, para 100, subpara h.
This makes sense, because as the CG moves forward, the tail must produce more down force to retain the balance of the aircraft. To maintain level flight, that downforce must be counteracted by additional lift from the wing, which gets it from a higher AOA, reducing the margin above the stall AOA....
For example, if a wing stalls at 10 deg AOA and it is in level flight at 3 degrees AOA, that leaves a 7 degree margin... If we move the CG forward, the wing must increase its AOA by, say 2 degrees, that makes the level flight AOA 5 degrees at the same airspeed. The wing now has a stall margin of 5 degrees, which it will reach at a higher airspeed than if the CG hadn't been moved.
In answer to the original post, the farther forward the CG is, the higher the stall speed will be, even though the airfoil stalls at the same AOA. Since we use apparent airspeed for determining our stall margin, I suggest we cannot ignore the CG location in the context of this discussion.
In practice, since we balance our models at the location specified in the plans, and the CG moves very little, it's a moot point, but the original post asked the relationship between CG and stall, which is relevant and real...
Cheers!
Jim
       Post #: 6
RE: Tip Stals and CG - 8/22/2006 12:19:33 PM
mesae
Status: offline
Seems to me Jimmbbo just re-stated what RaceCity said, while still taking exception to his post for some reason. I did not get the impression RaceCity was suggesting we ignore the CG position. What he said is correct in that as CG moves forward, it becomes "harder" for the elevator to cause the wing to reach the critical AOA, and the critical AOA does not change with CG position, weight, load factor or speed.
What nobody seems to have mentioned is that a tip stall, not just any stall, is an asymmetrical stall, caused by being in a slip or skid at the moment of stall. This can be accomplished by applying excessive or insufficient rudder at the moment of stall. Since it's difficult for an inexperienced model pilot (or any model pilot) to know when their models are exactly coordinated under all conditions, a tip stall can be considered evidence that when the stall occurred, the airplane was not flying in a coordinated fashion, assuming the airplane was built straight. In the above context, "coordinated" means ball centered. In aerobatics, "coordinated" means the airplane is doing what it is supposed to be doing, whether it is slipping, skidding or neither.
One way to test this is to perform power off stalls with the wings exactly level, applying rudder as necessary to prevent the airplane from changing heading up to the stall. Even a small rate of heading change or skid in this case can cause a tip stall with a snappy airplane so this must be done accurately. All but the very snappiest airplanes can be made to stall straight ahead without rolling in this manner. Without active and accurate rudder input, it is unlikely that the airplane will be exactly coordinated during any given stall, due to the many variables involved, not least of which are the turning and rolling tendencies generated by a propeller, and the vertical stab and/or rudder offsets applied at "neutral" to compensate for these in "cruising" or normal flight.
Stalls are generally easier to accomplish, and tend to progress farther before recovery, with an aft CG position. If one wing stalls before the other, the "ball" was off center at the moment of stall (for any number of possible reasons). Put another way, the resultant lift vector was not perpendicular to the wingspan, again assuming the airplane was built straight and true.
Also, I fly my models based on attitude and power setting (same way I fly full-scale), not 'apparent airspeed', by which I assume Jimmbbo means groundspeed (please correct me if I'm wrong here) since we have no immediate way of knowing airspeed without telemetry. Using only groundspeed to estimate airspeed is dangerous. I have seen model pilots get into trouble many times by using groundspeed instead of attitude. I have seen this most often in the case of a downwind deadstick landing. The pilot thinks the airplane is going too fast because of its high groundspeed, and continues to raise the nose, causing a stall. Another common trouble spot is at fields where it is usually windy (like in Hawaii, Texas and Oklahoma). On calm days, pilots sometimes (perhaps subconsciously) attempt to slow the airplane to near the same groundspeed they see on a windy day and accidentally stall or develop a high sink rate and land hard. This type of accident can be prevented by knowing and using appropriate attitudes and power settings for landing approaches. The same attitudes and power settings for a given model, with small adjustments, will work for all wind conditions and density altitudes, without regard to groundspeed.
< Message edited by mesae -- 8/22/2006 4:49:22 PM >
"The purpose of time is to prevent everything from happening all at once."
       Post #: 7
RE: Tip Stals and CG - 8/22/2006 2:27:18 PM
dick Hanson
Status: offline
Frankly -I don't like that FAA "advisory--Especially the "it will often" phrase .
To be quite blunt - I find thru experience -on models - that forward CG is more desireable and prevents unwanted , loss of control stalls .
The more forward the cg - the greater the "balancing load " at the tail required
That load ,to me was ,is and will remain ; INDUCED DRAG
In order to hold wing at constant AOA whilst increasing this drag (moving CG forward ) , the speed has to increase. Obviously
So tho the wing will oerate at a higher AOA for a given airspeed -- the wing loading (true loading not induced load) remains the same------------- the actual stall will be more predictable and actually easier to manage due to the high elevator inputs required to get there. On the aft CG- it is far easier to accidently induce the excessive AOA There - I just wasted 5 minutes .
and edited the darn thing 5 times
< Message edited by dick Hanson -- 8/22/2006 2:35:23 PM >
I am watching you
Libby
(in reply to mesae)
       Post #: 8
RE: Tip Stals and CG - 8/23/2006 1:13:09 AM
Tim Taylor
Status: offline
The plane I was writing about is a 46 size composit pattern plane. The plane never flew like it was tail heavy at all, I just had major unexpected tip stalling to the left at any speed. I wrote the makers and they said, "It's suppose to do that." Well, I could see a little tip stalling but not unrecoverable tip stalls, like getting control back 5 feet off the ground? I've have other planes that may tip stall but they're nothing like this one was. The problem came as I was removing weight from the nose after the maiden. I originally had about 1/2 ounce lead in the nose and I removed it. It was a couple weeks before flying the plane again and I had not placed the correlation between the tip stalls and the removal of lead. Now it seems to fly well with almost no tendencies to tip stall. It's about 1/2 ounce nose heavy now by the makers specs.
Thanks All.
(in reply to dick Hanson)
       Post #: 9
RE: Tip Stals and CG - 8/23/2006 5:51:10 AM
Jimmbbo
Status: offline
quote:
ORIGINAL: mesae
WADR, my response was narrowly aimed at the comment that "Stalls have NOTHING to do with CG" which is incorrect. My comments addressed that point, and I believe them correct within the context of that remark. Since there are a number of new pilots on this site, I think it important to address statements that I believe incorrect, so as to minimize confusion or misunderstanding among folks who are trying to learn the fine points of the hobby.
With regard to flying attitude or airspeed, I should have added that attitude works great if you have a good view of the model close up, but when the model is farther away, the speed of the model is the only guide available, considering current winds, that gives control of the margin above a stall..
Cheers!
Jim
(in reply to mesae)
       Post #: 10
RE: Tip Stals and CG - 8/23/2006 5:53:17 AM
Jimmbbo
Status: offline
quote:
ORIGINAL: dick Hanson
Guess I could have just answered the post based on my 11000+ hours of FS airplane flying including 2300 hours of dual given, but some folks just need a verifiable source
Cheers!
Jim
       Post #: 11
RE: Tip Stals and CG - 8/23/2006 6:56:27 AM
dick Hanson
Status: offline
It isn't you I am questioning - it is the friggen FAA advisory I did not-do not -never will like the way it is presented..
Note the phrase "often cause".
might as well say "mebbe"
No offence -
I am watching you
Libby
       Post #: 12
RE: Tip Stals and CG - 8/23/2006 1:21:24 PM
mesae
Status: offline
quote:
ORIGINAL: Jimmbbo
...WADR, my response was narrowly aimed at the comment that "Stalls have NOTHING to do with CG" which is incorrect. My comments addressed that point, and I believe them correct within the context of that remark. Since there are a number of new pilots on this site, I think it important to address statements that I believe incorrect, so as to minimize confusion or misunderstanding among folks who are trying to learn the fine points of the hobby.
Cheers!
Jim
Your point about new pilots is well taken. That statement taken in isolation is not true, but my point is that it was qualified well enough within the post to be correct and understood the way the author intended.
I was referring primarily to attitude flying during landing approaches where the airplane is always close enough to see well. For my part, even far away, I still use attitude when maneuvering at low speed, but I tend not to do a lot of slow flight very far away. IMAC type precision spins entries are one exception.
It seems unlikely that if you and I were to have a face to face conversation about aeronautics (FS or RC), that we would disagree significantly about any fundamental point.
I truly appreciate that it seems you read my post carefully. I consider it an honor, and ask no more than that of anyone who answers one of my posts. I endeavor to do the same for any post I answer, and hope I am largely successful.
Regards,
Ed
P.S. Sorry, what is WADR?
< Message edited by mesae -- 8/23/2006 1:37:53 PM >
       Post #: 13
RE: Tip Stals and CG - 8/23/2006 2:08:20 PM
RaceCity
Status: offline
