littlehammer
CA, USA Status: offline
First of all I like to say, I was just thinking about this and am glad to see this thread. I have a few ideals that I wanted to throw out. 1) How about putting the power-plant forward, shifting some of the weight onto the front axle? The four stroke sounds good to me. Maybe a heavy flywheel to help with the climbing. 2) How about going to a four channel or higher radio, that would help with independent four wheel steering and also allow the control of the brake separately. 3) Also thinking about setting up a series of (let's say Savage) transmissions. Reasons being: A - gear reduction. B - the last transmission could also incorporated the reverse mechanism. C - somewhat more durable than the airplane reduction gears. D - Can still leave the 2-speed mechanisms in, Awesome to hear it shift 4 or 6 times right after coming off of a rock crawl. Simulating real life, some people do drive to the crawling spots. Not many, most people trailer their trucks in. (Drawbacks I see so far: The power-plant and transmissions would have to be transversed and the use of dual spooled diffs for the center drive-shaft outputs, the first to reverse the engine tranny position and the second to reorient the center output shafts. Also the weight will be an issue. But if positioned correctly that might come out to our advantage.) The first three ideals are based on staying on the 1/10th - 1/8th scale and that I am using tools I have around. I don't have access to any machining equipment. If I had the proper equipment I am sure I can think of some less cumbersome ideals. These other ideals I have are if the scale is changed to 1/4 or 1/3rd scale. 4) The use of Go Kart Live axle for the front and rear. This would allow the use of front and rear disk brakes, and the rim and tire combos are greatly increased. This could open us up all the ATV tires out there. We would lose the lexan bodies but I like the tube frame look much better anyway. Again weight will be a factor, so what do we need? More power!!! This brings me to my next ideal. 5) Power-plant - Love the sound of a thumper (4-stroke), I love churning out of thick mud on my motorcycle, but I have to admit I have never rock crawled with my thumper. I figure there are a lot of kart motors out there most of the high performance ones are setup for speed though. I think a 5 hp motor will have enough torque for what I am thinking. There are also torque converters designed for these motors as well. But again there is the problem of reducing the gear ratio again. Let me know what you guys think
< Message edited by littlehammer -- 8/21/2006 4:38:09 PM >
