Anomie
Joined: 4/15/2005 From: Liverwurst, CA, USA Status: offline
I finished more work on the drivelines, and there are now 6 out of 8 pieces complete. The lower shafts that connect to the differentials are still awaiting some measurements (mainly because I kept changing my mind ). The first three shots show the yokes, trunnions, and upper shafts. The next pictures show the assembled upper shafts connected to the center diff, and everything mounted on the motor plate which I made some 5 years ago before plans started changing. I found that assembly in the garage, and realized that it would work much better than the TMaxx tranny. It will also help to ease the reduction gear between the motor and center diff. The next pictures show the plate mounted between the frame rails the way it originally looked before I decided to go with nitro power. The 24v electric motor and double-reduction gearbox are mounted on top of the plate, along with a small fan to cool the motor. There is still the possibility of electric propulsion with a nitro engine generating power, but I just don't know right now. As things stand, I will finish the drivetrain with everything in place as it is here, and then run it off a power supply to ensure proper turning of all this weight. Once I have a good idea of the operational limits, I'll start on the gearbox and engine mounts. The steering will have to wait while I have all this time in the shop to make some mechanical progress. Also, the weight with everything on board is 21lbs., and still no batteries, engine, radio gear, or remaining cooling system
_____________________________
~Reiko~ RCU Car Forums Moderator http://www.rcuniverse.com/forum/m_377662/tm.htm
