Anomie
Joined: 4/15/2005 From: Liverwurst, CA, USA Status: online
Do you wish to build a fuel rig, or electric? This thread is only pertaining to the nitro drive ideas. Most members who design and build their own rig are not likely going to share the details. You can look around in some of the threads, or search within this forum using keywords such as 'custom' or 'home built'. Depending upon the type of drive you plan to use, there are many options for both a layout and suspension setup. For example, if you want to use a single motor and tranny to solid axles, you'll find that the most common will be a TLT-based rig. On the other hand, you can use a dual motor system like a Clodbuster. Both have their advantages. Look around at some of the builds within this forum and you'll see quite a few different types and designs. As for this discussion, keep it nitro-related. Good luck!
_____________________________
~Reiko~ RCU Car Forums Moderator http://www.rcuniverse.com/forum/m_377662/tm.htm
