savagecommander
MI, USA Status: online
clod axles wouldnt work very well for this application. tlt axles might work alright, ust dont use a motor over say .25 . i've heard of a nitro rustler, but i dont think the trans is the same as the electric, which is popular for crawling. as far as the clutch goes, if you gear it down enough, the clutch will engauge at a low enough rpm that wear wll be minimized. example- lets say you use the tlt axles, and you are going for a scale look, so you get some moab 2.2's. 4 mph is about how fast the rig should go, and thats 270 tire rpm. if my memory serves me they have a 2.5 ratio, so that means 675 rpm out from the trans, so you would need a 37:1 or better ratio in the trans, but that also means your clutch would be kicking in at about 3/4 mph (roughly). easier sad than done though....
_____________________________
its funny, he said "I am the dread pirate roberts" long live andre the giant
