Reiko
CA, USA Status: online
quote:
ORIGINAL: The Real Dogman Back to the subject........A torque converter is an excellent idea..I am just curious how hot it would get...I dont how many of you have touched a torque converter on a 1:1 when it is being overworked, but damn thing can burn you good!!I like the idea , I think it could work...but lots of testing....However, in reality the torque converter is really a liquid clutch, operating on rotational speed(RPM) that never truely locks up(electronic or mechanical assistants aside), so I'm not sure there would be any real advantage... I think you're right about the heat. That may be a tough one to overcome. A model converter would seem to act similar to a centrifugal clutch, but likely more difficult to adjust the stall speed. A high-stall converter in a 1:1 tends to hook up quickly, and doesn't necessarily 'slip' with ease. Perhaps a servo-actuated clutch with a pressure plate and thrust bearing would be a more controllable and consistent means of transmitting the rotation. A 'wet' clutch would keep the heating to a manageable level. Now, I realize that these ideas could be complex to implement on a small scale, but overcoming the low-speed issues inherent in a nitro vehicle may require such engineering.
_____________________________
~Reiko~ RCU Car Forums Moderator Not-so-proud builder of the most ridiculous vehicle ever. Maybe I will run away and join the circus!
