mechanicalbob
AK, USA Status: offline
I see I have a few questions to answer. quote:
ORIGINAL: savagecommander hey mechanicalbob, didnt you build a sweet twin engine tuber with machined axles? i saw pics of one and i swear it was you..... dont forget that hpi is making a reverse module that engauges reverse only when the brakes are applied for five seconds. i know that may be an issue, but it frees up the third channel on the radio for the proposed "transfer case".......... this idea has been in my head for years and i'm glad somebody came thruogh all the hype and made a good board.. I did not build that one, I do belive you are talkin about the PIE WAGON. It is a sweet truck but I do not remember who built it. The only twin engine car I built was a NTC3 with twin OS .12's with a three speed. With the reverse that I am using I will not need a third channel. I will be using a Airplane "Mixer" to shift from forward and reverse Basicly I will have the throttle trigger set at 50/50, when I pull the trigger it will be in forward and have full throttle control, when the norm would be pushing on the trigger for brakes, mine will shift to reverse and have full throttle control. That leaves the third channel for full brake control. For the Linear servos, the reason I went with these is that they put out 1 FT LB of torque, that should be enough to turn any tire on the rocks I think. From STYLES is my name One day we will all have Nitro Crawlers.... Mark my words. Remember back in 85 when the RC-10 was the only car to have? Well its going to happen to Crawlers too, as soon as some one ( the Japanese) figure out the clutch problem, Nitro Crawlers will be everywhere. And Yes I currently own a Clod and TXT. But I would love to bolt a Saito 4- stroke in-line twin to one.. pa-thump pa-thump pa-thump. ..... Good luck guys, sonds like you've got some good ideas. I do argee that the RC-10 was the car back then. As for the clutch it is not a problim I use a Heli clutch to get the get the job done, and the cooling is another one to look at too from the Heli world. The real problim is getting the gearing down to a crawl at a cheep price. So far my custom tranny is just over $500.00 and going, but it is a prototype. I hope to get the price down to a more affordable price for people. And Styles when I do I will let you know and I will build one for you. Feel free to ask Any questions Steve
