RE: Echo 2400T Short blocks    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Echo 2400T Short blocks
Page: <<   < prev  3 4 5 6 7 8 9 [10] 11 12   next >   >>
Login
RE: Echo 2400T Short blocks - 2/10/2007 3:23 PM
oldtimer2
Score: 100
Last Login: 9/4/2011
Status: offline
captjohn,
Very nice work on your hub. I already have the hub and prop washer/nut from Roy Sholl for my eng. set up for glow/gas. All I need for the other eng. is the prop adapter, washer to butt up aginst the flywheel, with the L/H threads that I can run as a stright ignition. No taper required. Any way you are doing some good R&D work there plus getting some good practice using your new equipment. Keep up the good work. I see you are still in the deep freeze up there. We are still in the 30 to 40 range here.
Later George
Hide Signatures
(in reply to captinjohn)
       Post #: 226
RE: Echo 2400T Short blocks - 2/10/2007 5:42 PM
captinjohn
Score: 247
Last Login: 5/25/2013
Status: offline
mikenlapaz: The prop hub itself will NOT have internal threads to engage crank threads, but a hole bored for clearance. To keep both parts on center a ..030 deep hole will be bored in the flywheel center to keep the extended part on center. The extended part will be a sung fit in that hole. The three bolts will come from back side and thread into the extended part. Then it will be possible to machine the extended part to what ever length you want and knurl it. Then drill and tap for right hand threads. Before I can do this I need to get some larger dia aluminum stock. Yes the key will be in what is left of flywheel. That with locltite on taper and left hand nut will work good I believe. The idea of all this is to be able to machine the assembly like its all one piece. The three bolts can go all the way through and have pal nuts on them if you want. That is a option. Another option is do not cut as much of a "neck" in the extended part and use longer bolts from backside. Now I hope it works!! Capt,n
< Message edited by captinjohn -- 2/10/2007 5:49 PM >
_____________________________
I never met a engine I did not like !
Hide Signatures
(in reply to mikenlapaz)
       Post #: 227
RE: Echo 2400T Short blocks - 2/10/2007 7:06 PM
flipflop
Score: 100
Last Login: 12/23/2012
Status: offline
So, you're going to have approximately .630 in. open space between the back of your hub and the front of the engine??? What you are doing should work fine on the test stand where the only loads that your turned flywheel center section will see are torque loads. OK, for the loads on your center section you have to add the front section of your prop hub (moment arm), then you need to consider the gyroscopic loads (bending) of a 16 or 17 inch prop plus the moment arm. You are going to be putting a lot of stress on a very small area of CAST ALUMINUM that was designed for torque loads only when you are actually flying this setup. Just my opinion, others may disagree. Good luck with it.
Hide Signatures
       Post #: 228
RE: Echo 2400T Short blocks - 2/10/2007 7:59 PM
captinjohn
Score: 247
Status: offline
flipflop...you have a good point. There is a lot of engines with far more power than this one and that same center piece is holding a complete flywheel and extension with bolt. prop washer and prop and I have not heard of any coming loose yet. No one is going to be in front of or in line of any prop set-up of mine, or one I buy. If it explodes in air...so be it. I have seen a engine come off a airplane and the guy still did not crash his plane. Thanks for you input...even better would be posting more photos of each step on how you think it should be done. Capt,n
Hide Signatures
(in reply to flipflop)
       Post #: 229
RE: Echo 2400T Short blocks - 2/10/2007 8:24 PM
captinjohn
Score: 247
Status: offline
I would like to finnish up and try this set-up if I could find a Left-hand tap that did not oversize the threads like the 2 taps I did get. Flipflop...just how tight was the left-hand threads you did? Thanks Capt,n P.S. This adapter could be shorter by over 1/4 inch and still have plenty of threads past crank nut.
Click to see fullsize image.
Click for fullsize
< Message edited by captinjohn -- 2/10/2007 10:59 PM >
Hide Signatures
       Post #: 230
RE: Echo 2400T Short blocks - 2/10/2007 9:41 PM
tim220225
Score: 100
Last Login: 4/17/2013
Status: offline
quote:
ORIGINAL: mikenlapaz
Capt: A) Will the bolt-on part have the LH threads?; B) Will you retain the key and keyway? ; C) Will the the final product have the bolt heads on the back of the flywheel center? Just having trouble visualizing rotational alignment of 'drilled nut' and fixed relative position of the threaded holes in the 'back plate / flywheel center' Looking forward to explanation of just how to accomplish this procedure. Good Luck.
The key is soft metal and will shear and has no use in our application. The sole purpose of it is in final assembly in the factory to install the flywheel at the correct otientation for timing. I still don't trust the LH threads. Maybe on this size engine but I wouldn't do it on anything bigger for sure Loctite or not it scares me.
Hide Signatures
       Post #: 231
RE: Echo 2400T Short blocks - 2/10/2007 10:54 PM
captinjohn
Score: 247
Status: offline
Tim220225: I see what you mean about the soft keyway. What do you think of making a steel duplicate of flywheel center out of steel and use a steel key-way? Should be a lot stronger for sure. Capt,n
Hide Signatures
(in reply to tim220225)
       Post #: 232
RE: Echo 2400T Short blocks - 2/10/2007 10:56 PM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
You might want to get a better bolt than that one in the picture....Grade 8 is way stronger and not that expansive....
RC Ignition
Hide Signatures
       Post #: 233
RE: Echo 2400T Short blocks - 2/10/2007 11:09 PM
captinjohn
Score: 247
Status: offline
RCIGN1: I was thinking about using a allen head bolt. I will make sure that is Grade 8. If it was your engine...how would you go about this Left hand thread deal? Thanks Capt,n
Hide Signatures
(in reply to Antique)
       Post #: 234
RE: Echo 2400T Short blocks - 2/10/2007 11:14 PM
av8tor1977
Score: 665
Status: offline
Wasn't addressed to me, but I still think the ideal fix is to bore a pilot hole in the crank, then cut off the left hand threads, then bore and tap the crank for a right hand thread grade 8 stud. It's a lot less work than the two piece prop hub as well...
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
       Post #: 235
RE: Echo 2400T Short blocks - 2/10/2007 11:31 PM
captinjohn
Score: 247
Status: offline
av8tor1977: What about the taper on the crank? Explain your complete process. Thanks Capt,n
Hide Signatures
(in reply to av8tor1977)
       Post #: 236
RE: Echo 2400T Short blocks - 2/10/2007 11:33 PM
Antique
Score: 557
Status: offline
Av8tor's method will work fine.....I converted a few 3W 106s this way, but it takes a really good drill and tap, the crank material is pretty hard...If you do it that way cut the threads off first, then use a small center drill on the end of the crank..Use a good cobalt drill, maybe a #21, to drill a pilot hole, then use the correct drill size for the tap..Makes it easier...
Go slow, it's hard material and going too fast will just burn up the drill and work harden the crank, making it even harder...I usually lock the chuck and put the tap in a drill chuck in the tailstock and turn it by hand into the crank...
The cheaper bolts work OK on small engines, but if you tap the bolt for a 10-32 spinner bolt the head can break off a grade 5..Been there, the spinner went about 100 yards across El Mirage dry lake when the head came off...
Most hardware stores have grade 8 hex bolts, a 5/16 is less than a buck....
RC Ignition
Hide Signatures
       Post #: 237
RE: Echo 2400T Short blocks - 2/10/2007 11:47 PM
captinjohn
Score: 247
Status: offline
RCIGN1: Sounds good to me. Where is a good place to buy cobalt drills? Is a place called Drill Bit City 1-800-950-3938 a good place to buy drills? Thanks Capt,n OH ..What about tap magic fluid?
< Message edited by captinjohn -- 2/10/2007 11:50 PM >
Hide Signatures
       Post #: 238
RE: Echo 2400T Short blocks - 2/11/2007 3:00 AM
av8tor1977
Score: 665
Status: offline
The end of the crank with the threads has a machine centering hole in it. I was thinking of using that to center the pilot hole drilling operation. Then cut off the threaded portion, and then drill the hole to final size for tapping. Eliminates the need for a center drill. But if you have center drills Captain, you can do it that way as well.
AV8TOR
Hide Signatures
       Post #: 239
RE: Echo 2400T Short blocks - 2/11/2007 4:20 AM
captinjohn
Score: 247
Status: offline
av8tor: I know there is a center in the end of crank already. If you use that center you will have drill .625 or 5/8 of a inch further. The further you drill the more chance of getting off center. May be best to cut off threads grind flat and use a new precision center drill which I have 2 of. Maybe a #21 pilot drill like RCIGN1 recomended. I do not know if fine threads would be best or coarse threads? You never did say what you are going to do about the taper? Capt,n
Hide Signatures
       Post #: 240
RE: Echo 2400T Short blocks - 2/11/2007 5:42 AM
mikenlapaz
Score: 100
Last Login: 2/26/2013
Status: offline
captnjohn:
www.mcmaster.com/ for left hand jamb nuts and drill the second one on crank and the crank for safety wire. This is for IF and only IF you do the 2 part hub.
Is there a minimum diameter where if become unsafe to use safety wire? I would think that if the hub did loosen it would be apparent before it became a safety issue, maybe not. Opinions?
Gee how about canning the crank and having a spare flywheel? NIB Echo Trimmer or Blower Short Block No Reserve!! 8 shipping and currently under 25 bid.
< Message edited by mikenlapaz -- 2/11/2007 5:53 AM >
trying to tax into prosperity is like a man standing in a bucket and trying to lift himself up by the handle W. Churchill
Hide Signatures
       Post #: 241
RE: Echo 2400T Short blocks - 2/11/2007 6:00 AM
mikenlapaz
Score: 100
Status: offline
MIKE-O-CUT No. 87 If you can find it and if you do post source, please.
Hide Signatures
       Post #: 242
RE: Echo 2400T Short blocks - 2/11/2007 6:04 AM
w8ye
Score: 318
Status: offline
MIKE-O-CUT No. 87 is down the page a ways
http://www.ashburnchemical.com/FrontEnd/ProductDocs.php?rootID=1
< Message edited by w8ye -- 2/11/2007 6:06 AM >
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 243
RE: Echo 2400T Short blocks - 2/11/2007 6:16 AM
av8tor1977
Score: 665
Status: offline
Well I would just leave the taper, and handle it in the ways we always do. Either use the center out of a flywheel and a magneto type prop hub, or buy/make a prop hub for use on the taper.
AV8TOR
Hide Signatures
(in reply to w8ye)
       Post #: 244
RE: Echo 2400T Short blocks - 2/11/2007 9:11 AM
mikenlapaz
Score: 100
Status: offline
A retail outlet is what I was looking for. It was hard to find in small containers on West Coast even 10 years ago.
As per their site; An extreme duty tapping and drilling fluid. Considered environmentally safe. It is thick like honey and sticks to the tap throughout the operation. It is ideal for tapping and drilling stainless steel, carbon steel, inconel, monel, hastalloy, titanium, aluminum and other alloys and exotics.
Working stainless it is super. You don't work harden the material as it does a good cooling job, as well, even when working with hand held drills.
< Message edited by mikenlapaz -- 2/12/2007 10:56 AM >
Hide Signatures
       Post #: 245
RE: Echo 2400T Short blocks - 2/11/2007 5:33 PM
tim220225
Score: 100
Status: offline
Capt,n Flipflop is referring to the area between the back of your machined flywheel and the seal in the front of your engine. Basically all the forces or loads are on the threaded portion of the crank. Not too stable and can break off. Ideally the hubs should fit closely over the area behind the threads on the crank and be an 1/8th inch in front of the seal as in this picture. This is a 16cc Echo I did some time ago. You don't need the key. Just use a good Loctite type sealer. I use 620 and it is tough stuff. The taper on the crank and hub will lock together even without Loctite.
Click for fullsize
Hide Signatures
       Post #: 246
RE: Echo 2400T Short blocks - 2/11/2007 10:42 PM
captinjohn
Score: 247
Status: offline
tim220225: That is a very good looking job you did on that engine. Also a very good job on explaining about the possible breakage. Do you plan on the same set-up even if you cut and re-tap crankshaft for right hand threads? I am wanting to get to another project. I will put the Echo on shelf for now. I have 2 of them and will take one to the next swap meet. I want to trade Echo 2400T off and get a big Moki or something simular. I plan to make a gas head and see how that works. There is a place that will install needle bearings in rod. May even try Gas/glow in one. Just want to try something else right now. Capt,n
Hide Signatures
       Post #: 247
RE: Echo 2400T Short blocks - 2/11/2007 11:10 PM
w8ye
Score: 318
Status: offline
These people are listed as being retailers of MIKE-O-CUT No. 87. They are in Houston
http://www.eagle-tool.com/Page384.htm
Here's their catalog in PDF
http://www.eagle-tool.com/EagleCatalog2006c%203%2028%2006.pdf
Here's another place that lists the Mike-O-Cut No. 87
http://www.clymertool.com/catalogue/index.html
< Message edited by w8ye -- 2/11/2007 11:32 PM >
Original AMA #31261
Hide Signatures
       Post #: 248
RE: Echo 2400T Short blocks - 2/12/2007 1:31 AM
mikenlapaz
Score: 100
Status: offline
QUITE A CATALOG FOR THE MACHINIST. Thlanks
Hide Signatures
(in reply to w8ye)
       Post #: 249
RE: Echo 2400T Short blocks - 2/12/2007 3:11 AM
tim220225
Score: 100
Status: offline
Thanks Capt,n. I do all my hubs the same way. In the case of the LH threads on the Echo the stud replaces the machined threads on the crank. So from the outside everything will be the same as far as looks go. There will be no difference in the machining of the hub, threads, taper, etc. I could take one from a motor with regular RH threads and it will bolt on the one with the bored and tapped shaft with the stud.
Hide Signatures
       Post #: 250
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: Echo 2400T Short blocks
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
