BBW Walt
IN, USA Status: offline
My other comment to the guy building this particular 40% Extra, is be very careful about putting your rudder servos in the tail. The airplane is going to be hard to balance. I have my rudder servos just aft of the motor box, all my radio and battery equipment forward, and two 8611's in the stabs and I have my batteries in the forward part of the motor box. You might have hard time balancing the airplane set-up that way. This has been the case with both of my 40% Extra's. Good Luck and enjoy the build. Pete Us Indiana boys are mounting the rudder servo's in the tail on all the Carden Extra's. 35's and 40's..None have had a balance issue. Seen a problem with balance once doing this on a 40% 540. "Extra's" all in the tail. Waynes plane we didn't even check, we put it up and its real close as is. Walt
