ct420
TX, USA Status: offline
I like my trim almost all the way up for hovering in calm wind. I pull to just below center if hovering in a gentle breeze. This gives me a tiny bit of negative pitch at center stick, so I can 'fight' the wind if needed. Regardless of where you put the trim, the ESC is going to give full throttle to the motor somewhere around 3/4 stick, therefore, the trim is mostly just adjusting pitch. It does effect the throttle some, but it is minimal.
