question about himoto rapida pro or yoko gt4 car    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> question about himoto rapida pro or yoko gt4 car
Page: [1] 2 3   next >   >>
Login
question about himoto rapida pro or yoko gt4 car - 8/21/2006 7:10 AM
mannyfresh
Score: 100
Last Login: 10/4/2006
Status: offline
hey i have a used gt4 and im planning maybe selling the car to buy the himoto rapida pro car.. what should i do.. which is faster. thanks for replying if you did..
Hide Signatures
       Post #: 1
RE: question about himoto rapida pro or yoko gt4 car - 8/21/2006 8:45 AM
Kemo
Score: 105
Last Login: 10/19/2008
Status: offline
the yoke is of better quality
_____________________________
There are only 10 types of people in this world: those that understand binary, and those that don''t.
AMA: 722748
Hide Signatures
(in reply to mannyfresh)
       Post #: 2
RE: question about himoto rapida pro or yoko gt4 car - 8/21/2006 2:32 PM
Himoto Racing Canada
Score: 100
Last Login: 7/20/2008
Status: offline
Hello
In response to your question both vehicles are excellent when they are properly broken-in and well adjusted.
A few notes on the Himoto Rapida Pro.
Factory setting for the 2 speed transmission (is locked in first gear) EA The vehicle will need to have the engine break-in completed before you start adjusting the second gear setting (ccw to have it shift faster).
And from experience i would adjust the tranny to shift early at first and then adjust it to your style of driving.
If the transmission shifts at very high RPM it can and will break a tooth on the gear. ( i know from experience)
If you are not using a starter box ... cover the opening under the chassis to prevent the car from sucking up dirt and foreign objects in the transmission gears from the holes under the chassis.
Once your engine is going fine and the transmission shifts properly, you will have a fine vehicle.
NOTE: The stock wheels have a small hole machined in them, do not ride the vehicle in water. The water will unbalance your tires and can even un-glue them in 2nd gear ( believe me it is scary to see)
Service/Parts and technical support provided for Himoto Racing .Qualified technical support.
Hide Signatures
(in reply to Kemo)
       Post #: 3
RE: question about himoto rapida pro or yoko gt4 car - 8/21/2006 7:27 PM
mannyfresh
Score: 100
Status: offline
but which one is a better car and faster..
Hide Signatures
(in reply to Himoto Racing Canada)
       Post #: 4
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 3:41 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
cool, someone who seems to have some answers. You should talk to redcat about a job!!!! I like the set from factory in first gear answer.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 5
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 4:29 AM
Kemo
Score: 105
Status: offline
in the end, yokomo is better, and always has been. Yokomo is a purebred racing company.
AMA: 722748
Hide Signatures
(in reply to ehroof)
       Post #: 6
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 5:04 AM
Score: 100
Status: offline
quote:
ORIGINAL: ehoof
I would call that a conflict of interest.
I am the distributor for Himoto Racing in Canada
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Kemo)
       Post #: 7
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 5:55 AM
ehroof
Score: 105
Status: offline
would you know any reason the spur gears rip out, especially in the 2 speeds? i have other brand 2 speeds and they are fine, no problems. these redcats rip the gears out without a problem. i make sure the engine is straight and tight, good mesh.
Hide Signatures
       Post #: 8
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:07 AM
ThunderbirdJunkie
Score: 1040
Last Login: 6/25/2012
Status: offline
quote:
ORIGINAL: ehroof
Wow, the guy whips out some blatantly obvious suggestions and all of a sudden he's a demi-God. "don't drive your car through water." Gee, ya think?
No offense, Himoto Racing Canada, you shouldn't be one talking about conflict of interests. you're posting in a competitor's forum. Go peddle your wares elsewhere unless you buy from RCR.
< Message edited by ThunderbirdJunkie -- 8/22/2006 6:08 AM >
"Some people can mess up an anvil with a rubber hammer" -46u
If you don''t allow yourself to fail, you''ll never allow yourself to succeed-ThunderbirdJunkie
Hide Signatures
       Post #: 9
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:11 AM
phoenex1
Score: 100
Last Login: 5/11/2013
Status: offline
Hello Himoto Racing Canada-I have 2 Himoto touring cars and love them both ---One electric and one nitro. Maybe you can answer a question ---If I want to replace the electric motor what would be a good replacement for more top end speed without having to change the stock electronics. Thanks
Hide Signatures
       Post #: 10
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:12 AM
mannyfresh
Score: 100
Status: offline
but which one is faster
Hide Signatures
(in reply to ThunderbirdJunkie)
       Post #: 11
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:16 AM
Kemo
Score: 105
Status: offline
whats it matter if its faster? The yokomo will smoke it on the track, even if they share same engines.
AMA: 722748
Hide Signatures
       Post #: 12
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:30 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: ThunderbirdJunkie
quote:
ORIGINAL: ehroof
Its not the driving thru water, any fool would know that, i like the other one, and i quote
"Factory setting for the 2 speed transmission (is locked in first gear) EA The vehicle will need to have the engine break-in completed before you start adjusting the second gear setting (ccw to have it shift faster).
If the transmission shifts at very high RPM it can and will break a tooth on the gear. ( i know from experience) "
Much better than redcats (big news on page 5) on the why do the gears strip thread
< Message edited by ehroof -- 8/22/2006 6:31 AM >
Hide Signatures
       Post #: 13
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:46 AM
ThunderbirdJunkie
Score: 1040
Status: offline
ehroof...the "big news" is that the problem was brought to the manufacturer's attention, and to TRY to get an accurate count as to how many would have to be replaced.
Hide Signatures
       Post #: 14
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:48 AM
ehroof
Score: 105
Status: offline
hey bro, fix the problem,make a suggestion or keep your trap shut, the big news was months ago and havent heard of a fix since.
Hide Signatures
       Post #: 15
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 6:59 AM
ThunderbirdJunkie
Score: 1040
Status: offline
quote:
ORIGINAL: ehroof
it's still being worked out, nothing like this gets solved overnight. HPI is still fighting their issues iwth the Savage X, and it's been longer that the manufacturer has been contacted about it than it has with the spur gears.
I don't see Himoto doing anything about it, they've known about it for four years, and it took RCR ONE email to get them doing R&D on it.
I'm done with responding to your comments to get me into a flame war...
Hide Signatures
       Post #: 16
RE: question about himoto rapida pro or yoko gt4 car - 8/22/2006 7:06 AM
Kemo
Score: 105
Status: offline
NOW they decide to fix it? wow.
AMA: 722748
Hide Signatures
       Post #: 17
RE: question about himoto rapida pro or yoko gt4 car - 8/23/2006 2:15 PM
Score: 100
Status: offline
ThunderbirdJunkie
Have a look at thread header it says Himoto , i represent Himoto Racing and being a representive of the brand i will answer any question i can answer to satisfy a fellow hobbyist.
If you dont like my answer then just dont take the time and effort to read what i post.
and yes their are some people that still go through water .... i fix them , i see them.
*** Most issues of stripped gears have been traced down to 3 problems ***
1.) Missalligned gear mesh (both backlash and perpendicularity of the teeth alignment)
2.) Improper adjustment of second gear speed activation
3.) Foreign debris in gears (rocks and sand)
Regards
Hide Signatures
(in reply to Kemo)
       Post #: 18
RE: question about himoto rapida pro or yoko gt4 car - 8/23/2006 5:50 PM
{GBI}Harryball
Score: 100
Last Login: 7/10/2009
Status: offline
quote:
ORIGINAL: Himoto Racing Canada
ThunderbirdJunkie
Regards
Agreed, not sure what the confusion on this issue is. OMG. Make sure that your allignment is right, and that your vehicle is cleaned after each run. A little maintenence goes along way.
Sponsered by: ALL ABOUT FUN HOBBIES /ALL ABOUT FUN HOBBIES PRODUCT REVIEWER
Hide Signatures
       Post #: 19
RE: question about himoto rapida pro or yoko gt4 car - 8/23/2006 11:10 PM
jguitarsandcars
Score: 100
Last Login: 12/22/2006
Status: offline
Yes it does...
Hide Signatures
(in reply to {GBI}Harryball)
       Post #: 20
RE: question about himoto rapida pro or yoko gt4 car - 8/24/2006 1:20 AM
ehroof
Score: 105
Status: offline
thunderbird, what are you like 15 or 16 yrs old?? at least this guy came up with an answer for the gears no one else has yet to say. The part about the 2 speed shifting to late stripping gears. Why are you in such a huff?
Hide Signatures
(in reply to jguitarsandcars)
       Post #: 21
RE: question about himoto rapida pro or yoko gt4 car - 8/24/2006 5:37 AM
Kemo
Score: 105
Status: offline
all of it is common sense!
But if those were the obvious problems, the company wouldn't have such a HUGE failure of those!
AMA: 722748
Hide Signatures
       Post #: 22
RE: question about himoto rapida pro or yoko gt4 car - 8/24/2006 5:41 AM
ThunderbirdJunkie
Score: 1040
Status: offline
Maybe I was a little rough on the Himoto guy. Sorry about that, I know you were only tryin to help.
ehroof...you're one to talk about lack of maturity. Anybody that's ever worked in any industry knows that things are not solved overnight...or even in the course of months, or even YEARS (for example, my 2002 Jeep JUST got recalled for a problem that's been known by every enthusiast owner since the FIRST time there was a recall on it over 3 years ago), ESPECIALLY when you're dealing with an outside manufacturer. This is why I'm not making stupid posts on Superlift's website forum for them taking a long time with their new 4" lift for it, so for now I'm dealing with dragging my skidplates on stuff. Have you ever worked in any manufacturing-related industry, or do you just get your jollies from trying to stir crap up? I don't mean that as an insult, it's a legitimate question, because you obviously don't understand that R&D and testing of new parts takes time.
Hide Signatures
       Post #: 23
RE: question about himoto rapida pro or yoko gt4 car - 8/24/2006 6:26 AM
nbluehell
Score: 100
Last Login: 5/7/2007
Status: offline
hey thunderbird.. will you please stop posting your opinion as fact and then criticizing others for their's. IT'S GETTING REALLY OLD! oh yea..i thought you where a forum moderator? whats up with your behavior?
1/10 himoto syclone .18 infinity 2 speed.
Hide Signatures
       Post #: 24
RE: question about himoto rapida pro or yoko gt4 car - 8/24/2006 6:29 AM
Kemo
Score: 105
Status: offline
opinion? its not opinion, its strictly fact. Think of how many possible ways there are to correct the problem, but only ONE is obviously the right way. Its going to take a LOT of testing to find out if they (manufacturer) found that one way.
AMA: 722748
Hide Signatures
(in reply to nbluehell)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.750RCU1
