SIG Wonder needs advice
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> SIG Wonder needs advice
Page: [1] 2   next >   >>
Login
SIG Wonder needs advice - 8/21/2006 5:07:31 PM
brenzo
Status: offline
Hi all, I just picked up my newest kit "the SIG Wonder." I've been in the hobby about five years now, but this is my first venture into the faster more agile planes. As I look around for advice on this kit there seems to be a wide range of thought on the subject as to what engine is best. I have been told anywhere from a .09 to a .40(flying brick comes to mindwith this one). I would apreciate any advice that you could give me. By the was has anyone tried to put landing gear on this kit. I guess I'm a little nervous about hand launching on my own and I'm lazy I wanna drive this puppy right up to my truch when I'm done flring and be on my way.
Thanks for the Advice. Please remember this is my first sport plane but not my first plane. I have made several piles of balsa and monocote at my local flight club
       Post #: 1
RE: SIG Wonder needs advice - 8/21/2006 5:26:26 PM
MinnFlyer
Status: offline
If this is your first Sport Plane, I would highly recommend a .10
This little thing is a rocket ship. and believe me, even with a .10 it will be all you can handle.
I have one with a .25 on it - I am an expert flier and I wish I had put a .15 instead!
PS, I think Landing Gear would be a mistake.
_____________________________
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to brenzo)
       Post #: 2
RE: SIG Wonder needs advice - 8/21/2006 7:05:34 PM
Lotus72D
Status: offline
I totally agree, no gear on this lil model.
I have had them w/ the OS 10FSR, OS 15FP and an OS 25. The 15 with micro sevos was by far the best choice...keep it light and have fun. If I were to do another I might spring for the OS 15CV-A but it doesnt need anymore than a sport 15.
(in reply to MinnFlyer)
       Post #: 3
RE: SIG Wonder needs advice - 8/21/2006 10:21:07 PM
RCKen
Status: online
What Minn and Lotus have said is right on the money. I have one with a 25 and it is a rocketship, pretty much way too much engine. And yes, landing gear will ruin this bird. A 10-15 engine and a by the plans build will give you a fantastic flying plane.
Ken
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner''s, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
(in reply to Lotus72D)
       Post #: 4
RE: SIG Wonder needs advice - 8/22/2006 3:03:49 AM
garys
Status: offline
I had one with a bushing Thunder Tiger 25. I replaced all the balsa sheeting with contest grade 4-6lb wood, micro servos (Futaba 3101's), 270 NiCad batt., and got the weight down to 2lbs even. Hand launching was easy, I just held it in front of me with the nose up about 45 degrees and let it fly out of my hand... Several other guys in my club built straight from the kit, and they flew noticeably heavier...
GS
(in reply to RCKen)
       Post #: 5
RE: SIG Wonder needs advice - 8/22/2006 3:42:48 AM
Riley
Status: offline
I think the OS fp-15 is just right! Seeing this is your first sport plane .
It's easy to fly > Just don't get "ham" hands with the sticks.....Smooth and easy.The VERY most important thing is the CG! CG! CG! Just like the plan say's. Set the throw's as per plan and all surfaces at netural when launched !Best have your Bud do the launch the first few times, until ya get the trim set. O ya..........Full throttle at launch. It's a great flyer...............Your go'na like it .
Dennis
(in reply to garys)
       Post #: 6
RE: SIG Wonder needs advice - 8/23/2006 1:16:56 AM
jsn
Status: offline
15 size engine, mini servo's and build it as LIGHT as you can... no sloping extra epoxy and glue here and there I flew mine with a Magnum .25 and pipe WAY to fast but fun! mine came in at 38 oz and that's just to heavy... in a little plane like this you notice an ounce... 6 ounces is like adding a pound to a forty size plane. Hand launches are fairly easy since you have the fuse to grab onto... full throttle and a good toss is all it takes... try hand launching a Magnum by yourself with a 8x8 prop... it can get real interesting QUICK. Landing is easy to if you keep the weight down... mine lands like a brick and needs throttle management until just before touch down...not much fun but doable. Gear is not needed... if your flying of anything but grass use some epoxy and cloth inside the bottom of the fuse for added strength... easy on the epoxy though 2 strips of clear packing tape over the covering will protect it some what without adding much weight... replace as needed. Keep it light and and have fun... fast, even with a .15 is a given
John
(in reply to Riley)
       Post #: 7
RE: SIG Wonder needs advice - 8/23/2006 3:02:33 PM
stupidaso
Status: offline
I have built 2 of them, and these guys are giving very good advice. I used a magnum 15 in one and an os la 25 in the other. the LA is plenty. I also pylon race, and the wonder with the 25 reminds me of racing.
Don't worry about hand launching, the wonder ddoes very well with this. Consider walking to the plane a good opportunity to practice landing placement and get some exercise.
I used no epoxy on both of mine....no problems and saves weight. the rate of climb with the magnum pro 15 is pretty impressive, considering the small engine size.
Good luck, it's a fun little plane!
Speed without control is........well......SPEED!
(in reply to jsn)
       Post #: 8
RE: SIG Wonder needs advice - 8/23/2006 6:58:59 PM
brenzo
Status: offline
Thanks for the advise everyone it is really appreciated. Here's what Ive decide on, the norvel big mig 15 and micro servos, You think that'll be OK? Also is this kit cool outta the box or is there something that need beefing up or lightening? One more thing, ya think it's ok if I leave the caonopy off? Seem s like a waste of time and wieght to me.
Thanks again for the advice
Sould have some built photos for you soon.
(in reply to stupidaso)
       Post #: 9
RE: SIG Wonder needs advice - 8/23/2006 7:07:58 PM
MinnFlyer
Status: offline
Sounds like a good combo.
This thing needs no modification, it's great as-is
You can leave the canopy off (I did) but the canopy makes for a nice place to hold it for underhand launches.
Mike B.
       Post #: 10
RE: SIG Wonder needs advice - 8/24/2006 3:10:10 AM
WCB
Status: offline
I have an OS .32 SX on mine and clocked it (Time/Distance) at 98 mph.
       Post #: 11
RE: SIG Wonder needs advice - 8/26/2006 4:08:44 AM
jsn
Status: offline
brenzo... sounds like you have a good plan... the words Micro servo's bother's me... if your talking something like the 3101's that garys used or say HS-81MG's then fine BUT if your thinking 3107's HS-55/50's or the like then NO... the surfaces would destroy them in the first flight.
Canopy is up to you... I used it and it does help a bit in flight IMHO... one more point to reference right side up from up side down With a 15 the balsa main spar is fine... I used spruce(IIRC... it was hard wood) since I went .25 on a pipe. Beef up F-2(IIRC) the main former that the wing dowel pins go into with some tri stock..two small pieces give LOT's more glue surface. sand the heck out of the wing tip's!
John
(in reply to WCB)
       Post #: 12
RE: SIG Wonder needs advice - 8/28/2006 3:36:21 PM
brenzo
Status: offline
Thanks for the heads-up on the micro servos. I have a couple of s3110m Futaba servoes laying around from another project. Do you think that this would be ok?
(in reply to jsn)
       Post #: 13
RE: SIG Wonder needs advice - 8/28/2006 11:12:26 PM
brenzo
Status: offline
One more thing does anyone really carve that crazy vortex wing tip, looks like a covering nightmare?
       Post #: 14
RE: SIG Wonder needs advice - 8/29/2006 4:40:11 AM
slowmover
Status: offline
My first full build was a wonder with a o.s. 15. It is great.Fast 95 to 100 by a police radar. Wing tips? Leave it be.
       Post #: 15
RE: SIG Wonder needs advice - 9/19/2006 8:11:13 PM
